Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th April 2008, 11:28 AM
sadhusong sadhusong is offline
Registered Visitor
Registration Date: Apr 2006
Karma Power: 15
sadhusong has less than 100 Karma points so far.
Question Do inserts need to be preheated to tooling temperature in injection molding?
Hello all
as instructed injection with serts such as shaft, the shaft should be pre-heated as tooling temperature,i would like to get help for theory of this and is this mandatory?
and i found some supplier does not do this.
nice to meet you all - evry excellent experts
sadhusong
Sponsored Links
Old 11th April 2008, 11:32 AM
Phil Fields Phil Fields is offline
Registered Visitor
Registration Date: Mar 2006
Thanks Given to Others: 23
Karma Power: 28
Phil Fields is appreciated, and has over 400 Karma points.Phil Fields is appreciated, and has over 400 Karma points.Phil Fields is appreciated, and has over 400 Karma points.Phil Fields is appreciated, and has over 400 Karma points.Phil Fields is appreciated, and has over 400 Karma points.
Default Re: inserts injection
My past experience in injection molding (15 yrs ago), we never pre-heated inserts.
Phil
Sponsored Links
Old 16th April 2008, 02:42 PM
john john is offline
Involved in Discussions
Registration Date: Oct 2002
Karma Power: 29
john has less than 100 Karma points so far.
Default Re: Do inserts need to be preheated to tooling temperature in injection molding?
I have been insert molding for over 30 years and the only time we pre heated inserts was on a small nylon over steel insert part that was machined afterward. The rational for this was to keep the bubbles / shrink voids out of the part so it could be machined smoothly with no pits.
Old 16th April 2008, 03:21 PM
Randy's Avatar
Randy Randy is offline
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Randy
What do your engineers say?
None of us is as smart as all of us...Ken Blanchard
Old 18th April 2008, 11:15 AM
Edward Nell Edward Nell is offline
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2007
Karma Power: 9
Edward Nell has less than 100 Karma points so far.
Originally Posted by sadhusong View Post
Hello all
If you are doing rubber to metal/plastic injection moulding, then preheating will start the adhessive to start reacting before you have had time to inject the product. That would lead to failures
Old 20th April 2008, 09:39 AM
bgwiehle bgwiehle is offline
Involved - Posts
Registration Date: Mar 2004
Thanks Given to Others: 16
Karma Power: 39
bgwiehle is appreciated, and has over 500 Karma points.bgwiehle is appreciated, and has over 500 Karma points.bgwiehle is appreciated, and has over 500 Karma points.bgwiehle is appreciated, and has over 500 Karma points.bgwiehle is appreciated, and has over 500 Karma points.bgwiehle is appreciated, and has over 500 Karma points.
Originally Posted by Edward Nell View Post
If you are doing rubber to metal/plastic injection moulding, then preheating will start the adhesive to start reacting before you have had time to inject the product. That would lead to failures
True, but there are times when it is an advantage -- in our case, we pre-heat when the metals are particularly large or thick and when the rubber portion is especially thin. We control time and temperature of the pre-heating as well as the molding process, and test adhesion as well as dynamic properties. Also, the pre-heat temperatures are not as high as the molding temperature.
B.G. Wiehle
Old 20th April 2008, 11:31 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Hello all
I think the answer is, "it depends." For example, I found the attached PDF from DuPont that says this about some of their plastics:
Inserts should be preheated before molding (200 °F for Delrin® , 250°F for Zytel® , Minlon® and Rynite® ). This minimizes post mold shrinkage, pre-expands the insert and improves the weld line strength.
If your suppliers lack technical resources in their own compaies, it might be best to talk to an application expert from their resin supplier about your parts and the best way to proceed.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Thanks to Jim Wynne for your informative Post and/or Attachment!
Old 20th April 2008, 11:37 AM
Ajit Basrur's Avatar
Ajit Basrur Ajit Basrur is offline
Registration Date: Dec 2005
Thanks Given to Others: 674
Karma Power: 176
Ajit Basrur is appreciated, and has over 1700 Karma points.
Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.Ajit Basrur is appreciated, and has over 1700 Karma points.
Jim, the info provided is very good but the attachment is not correct - it titles 1984 and is something else
I have no special talents. I am only passionately curious - Albert Einstein
Thanks to Ajit Basrur for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
New tooling approval process acceptance procedure - Injection molding - Thermoforming pinal73 Manufacturing and Related Processes 1 17th March 2009 10:07 PM
Short molding issue - Plastic injection molding from a multi cavity mold philiplim Quality Management Related Issues 13 18th February 2009 04:08 PM
Missing inserts in injection molding sadhusong Manufacturing and Related Processes 3 19th August 2008 03:36 PM
Robust Test for Two Data Sets - Tooling on an Injection Molding Machine rmacken SPC Monitoring and Statistical Analysis Techniques 2 11th October 2007 11:27 AM
Injection Molding: Pressure, Time, Temperature and Calibration Bubba ISO 17025 - Calibration, Measurement Gages and Test Laboratories 7 28th August 2007 01:54 PM
The time now is 07:18 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
