Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Process Audits and Layered Process Audits
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
View Poll Results: Not sequentially following steps is an audit finding.
If there is evidence, "Yes" it's a finding 4 22.22%
Without more knowledge, I say "No", not a finding 1 5.56%
I would definitely dig deeper before any citation 12 66.67%
Given the limited information, no way to accurately say 4 22.22%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Reply
Old 17th April 2008, 11:52 AM
grego79's Avatar
grego79 grego79 is offline
Getting Involved (6 to 9 Posts)
Registration Date: Dec 2005
Karma Power: 16
grego79 has less than 100 Karma points so far.
Default Not sequentially following steps in a work instruction
Audit scenario...
After reviewing assembly work instructions you find that the operator is performing assembly operation steps #5 & #6 out of sequence. You ask the operator "why would you arbitrarily decide to change work instructions steps" and they respond by saying - "It doesn't matter what steps you do as long as it all gets done."
Just looking for feedback and comments of how you would address this issue.
Grego
Sponsored Links
Old 17th April 2008, 12:00 PM
Randy's Avatar
Randy Randy is offline
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.Randy is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Randy
Default Re: 9001:2000 Auditor Finding or Not!?
What are the requirements?
Are the requirements being met?
What is the definition of NC?
ISO 9000:2005
3.6.2
nonconformity
non-fulfilment of a requirement (3.1.2)
3.1.2
requirement
need or expectation that is stated, generally implied or obligatory
NOTE 1 “Generally implied” means that it is custom or common practice for the organization (3.3.1), its customers (3.3.5) and other interested parties (3.3.7), that the need or expectation under consideration is implied.
NOTE 2 A qualifier can be used to denote a specific type of requirement, e.g. product requirement, quality management
requirement, customer requirement.
NOTE 3 A specified requirement is one that is stated, for example in a document (3.7.2).
NOTE 4 Requirements can be generated by different interested parties (3.3.7).
NOTE 5 This definition differs from that provided in 3.12.1 of ISO/IEC Directives, Part 2:2004.
3.12.1
requirement
expression in the content of a document conveying criteria to be fulfilled if compliance with the document is to be claimed and from which no deviation is permitted
Use the Standard for your answer. When you use the Standard there is nothing left to haggle over. Now as to CA and cause, that is not the auditor's problem.
None of us is as smart as all of us...Ken Blanchard
Sponsored Links
Old 17th April 2008, 12:03 PM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Originally Posted by grego79 View Post
Audit scenario...
Grego
Hello Grego
Is the operator correct? Does it matter?
I would be interested in the situation. If the work instruction was written with a sequential order, someone thought it was important and it should be followed. The operator(s) needs to be trained. If it truly does not matter, the procedure should be rewritten (doesn't matter).
Added Moderator Note: I revised the title for better applicability to the subject. If it is not correct or needs to be changed, please let me or another moderator know
Brad
My idea of housework is to sweep the room with a glance.
Old 17th April 2008, 12:10 PM
GStough's Avatar
GStough GStough is offline
Registration Date: Aug 2006
Thanks Given to Others: 854
Karma Power: 100
GStough is appreciated, and has over 1700 Karma points.
GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.
Send a message via AIM to GStough Send a message via MSN to GStough
Originally Posted by BradM View Post
Added Moderator Note: I revised the title for better applicability to the subject. If it is not correct or needs to be changed, please let me or another auditor know
Or another moderator....
Gidget Stough, ASQ CQA
"It's easier to do a job right than to explain why you didn't." - Martin Van Buren
Thanks to GStough for your informative Post and/or Attachment!
Old 17th April 2008, 12:12 PM
BradM's Avatar
Karma Power: 274
For the love of everything.. please don't let another auditor know. Make them figure it out on their own.
Ok.... back to the ranch.
Brad
Old 17th April 2008, 12:20 PM
Coury Ferguson's Avatar
Coury Ferguson Coury Ferguson is offline
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 657
Karma Power: 191
Coury Ferguson is appreciated, and has over 1700 Karma points.
Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Coury Ferguson
Default Re: Not sequentially following steps in a work instruction
Audit scenario...
Grego
Does it improve the results (Time, Costs, etc)? If so, change the documentation, in my opinion.
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
Old 17th April 2008, 12:26 PM
somerqc's Avatar
somerqc somerqc is offline
Involved - Posts
Registration Date: Oct 2005
Thanks Given to Others: 64
Karma Power: 51
somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.somerqc is appreciated, and has over 1300 Karma points.
As an internal auditor, my first question is "does it really matter?". Next, is it potentially a more efficient way of completing the task? Doesn't matter? Change instructions to indicate that. Is it better? Change it.
If it does matter and isn't better - determine if systemic or localized. May be a personnel issue rather than a system issue.
John
Old 17th April 2008, 12:33 PM
Stijloor's Avatar
Stijloor Stijloor is online now
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,318
Karma Power: 377
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Audit scenario...
Grego
Grego,
Simple approach:
1. Interview other operators.
2. Verify impact of the out-of-sequence operations.
3a. If no impact, no action required.
3b. If impact, write nonconformity report.
Sometimes, in an effort to capture the process/activities, work instructions are written in an unnecessarily complex/detailed manner.
Stijloor.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Work Standard / Work Instruction Template Example wanted P.Natarajan FMEA and Control Plans 3 3rd September 2009 05:54 PM
One Work Instruction or Multiple Work Instructions (WI's) necessary Jmcdonald870 ISO 10013 - Quality Management System (QMS) Manuals 13 24th April 2009 08:50 AM
Humorous work instruction - Relief Station Work Instruction Crusader Funny Stuff - Jokes and Humour 6 28th October 2008 05:53 PM
What are Work Instructions for? Company Owner doesn't like Work Instruction beaser3 Documentation Control Systems, Procedures, Forms and Templates 7 4th December 2007 05:18 PM
Work Instruction - TS 16949 - Is work instruction for packing and delivery mandatory sathis ISO/TS 16949 - International Automotive Quality Systems Standard 6 31st August 2005 02:24 AM
The time now is 06:24 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
