Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st April 2008, 06:45 AM
Cassaundra Cassaundra is offline
Registration Date: Apr 2008
Thanks Given to Others: 2
Karma Power: 7
Cassaundra has less than 100 Karma points so far.
Please Help! Exporting Minitab outputs to other programs (Powerpoint)??
Hi Everyone-
I am new to Minitab. My company has just reqeusted that we start using it.
I was wondering if it was possible to export a graph (complete with interactions) to another program, for example: Powerpoint.
I understand I can make reports with Minitab- though we would still like to use PPT's as well.
Also in Excel there is an "auto filter" option. Is there something similar in Minitab? If so, what is the option and how do I find it?
I appreciate any information you may have on this topic. Thanks so much!
Regards,
Cassaundra
Sponsored Links
Old 21st April 2008, 07:17 AM
reynald's Avatar
reynald reynald is offline
Involved in Discussions
Registration Date: Sep 2005
Thanks Given to Others: 68
Karma Power: 33
reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.reynald is appreciated, and has over 700 Karma points.
Default Re: Exporting to other programs??
Yes you can. Follow this link
http://www.units.muohio.edu/mcs/univapps/area351/documentation/quantapps/MiamiOnly/Minitab/ElectronicDoc/MCUSEDDE.pdf
or seach google with the following keywords: "Minitab + "Dynamic Data Exchange"
A word of caution though: Using this technique with considerable volume of data will eat a lot of your PC's Random Access Memory causing slower performance.
Hope that helps :-)
>>rey
"Unless the CEO builds the Company, the Engineers labor in vain"
Thanks to reynald for your informative Post and/or Attachment!
Sponsored Links
Old 21st April 2008, 07:22 AM
harry harry is offline
Thanks Given to Others: 571
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Default Re: Exporting Minitab outputs to other programs (Powerpoint)??
Another google search page.
Thanks to harry for your informative Post and/or Attachment!
Old 21st April 2008, 07:23 AM
Karma Power: 7
Thanks for the tip. Now on to see if I can figure it out.
Old 21st April 2008, 11:24 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
I find it easiest to just copy the graph and paste it as a jpg into Powerpoint, in other words, not set up a dynamic link.
Such embedded links are a real drain on system performance.
In our case at least the Powerpoint presentation just needs a static report/chart.
Any subsequent analysis is better done back in Minitab.
Old 29th April 2008, 05:54 AM
Allattar Allattar is offline
Registration Date: Jan 2008
Thanks Given to Others: 4
Karma Power: 19
Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.Allattar is appreciated, and has over 500 Karma points.
As far as I have seen, you can only move data about with DDE not graphs.
You are better off copy and pasting the graph into power point. Either as a Graph object, or if you paste special you should be able to change the graph to picture.
Alternatives are to right click on the graph in Minitab, and move it to the report pad. A simple trick that can move any graph or session window result across to Minitab's report pad. From here you can export a compiled report into word with a few clicks.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Shipping Non-CE products to EU for exporting to other countries Cinti CE Marking (Conformité Européene) / CB Scheme 4 5th May 2009 06:42 AM
GeoMeasure 6000 - Exporting buffers to a file QC Rick Inspection and Test, Sampling and Related Topics 3 1st December 2008 03:18 PM
Shipping Validations prior to exporting our product Achemd ISO 13485 - Medical Devices - Quality Management Systems 4 23rd July 2008 02:30 AM
Exporting Minitab Data to Excel Michael J. Connell Excel .xls Spreadsheet Templates and Tools 5 29th June 2007 09:30 AM
Exporting Ford's 'FMEA Plus' Files to Excel chrissramey Excel .xls Spreadsheet Templates and Tools 13 5th July 2002 04:26 PM
The time now is 11:56 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
