Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Human Factors and Ergonomics in Engineering
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 5th May 2008, 09:21 AM
VT-IE VT-IE is offline
Involved in Discussions
Registration Date: Apr 2008
Karma Power: 7
VT-IE has less than 100 Karma points so far.
Please Help! Looking for Ergonomics Advice - Operators will run two machines simultaneously
I'm working on a new layout for an area in my plant in which the operators will run two machines simultaneously. After starting machine one, the operator will then walk over and start machine two's cycle. The machines have a 10 second cycle time so the operator walks back and forth between these machine's all day. I've got a new layout in which the machines are directly across from each other which cuts the walking distance down drastically, but at the same time I know the operator would have to turn around 180 degrees before walking to the next machine every cycle. Is this a serious ergonomic concern? Any ideas?
Thanks,
Andy
Sponsored Links
Old 5th May 2008, 10:30 AM
ScottK's Avatar
ScottK ScottK is offline
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 122
Karma Power: 109
ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.
Default Re: Looking for Ergonomics Advice - Operators will run two machines simultaneously
Hi Andy
I'd be happy to put in my 2 cents having done many of the same sort of projects in the past...
But I'll need a little more info if you can give it:
Can you give a description of the process that the operator has to do?
Is it simply start a machine every 10 seconds or is there loading/unloading or other operations involved?
What do the machines do?
How big are the machines?
Including other operations that the operator has to do what is the real cycle time needed to meed production demands?
I'm not a big fan of a 180 degree turn - especially if the operator has to make that turn every 10 seconds. But it all depends on machine and space constraints.
Time for a new sig line.
My LinkedIn Profile
Sponsored Links
Old 5th May 2008, 10:42 AM
Karma Power: 7
Originally Posted by ScottK View Post
Hi Andy
Sure, the operator loads a disc, then the machine sands it, then the operator flips the disc and the machine sands the other side, then the operator unloads the disc.
The sanders vary in size, but are roughly 4 feet wide by 3 feet deep and they're waist high.
The machine cycle time is 10 seconds, but the process cycle time is 27 seconds(10 seconds for the top side, 10 seconds for the bottom side, and 7 seconds of in which the machine isn't running because the operator is at the other machine, etc.).
The takt time is 10 seconds, but note we have 4 machines(2 operators).
I'm seriously consider having the machines at 45 degree angles so the operator only has to turn 90 degrees, BUT it will mean the walking distance will increase slightly.
Thanks,
Andy
Old 5th May 2008, 10:58 AM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Andy, being an electrician, I tend to see life in terms of wires..
What about putting a junction box with an interposing and time delay relay. Put two start buttons for regular use (like you do now) and add another that starts the one, and with time delay, starts the second?
At least that would cut out all the running back and forth for starting.
If you're big enough organization to have an internal electrician, $150.00 materials. Outside job: depends on the area, union, etc.
Brad
My idea of housework is to sweep the room with a glance.
Old 5th May 2008, 11:02 AM
ScottK's Avatar
Karma Power: 109
Thanks,
Andy
Seems the machines are too large to perform the job seated...
Can that be a consideration if they are placed at a right angle?
Maybe one of those "standing" chairs?
Personally I'd prefer an extra step or two over turning around in circles all day. Safety wise if you're at 90 degrees you can peripherally see either machine and have less chance of bumping into something.
My main concern with the 180 is the frequency. That's a whole lot of turns over the course of a day.
My LinkedIn Profile
Old 5th May 2008, 11:06 AM
Karma Power: 7
Haha, that'd be a great idea except the operator has to manually flip the disc over before sanding the other side.
Old 5th May 2008, 11:09 AM
Karma Power: 7
I hadn't considered doing the job sitting down. The machines are at least going to be 36 inches apart because there is a 36" wide converyor beside the machines; the operator must have access to this conveyor because this is where the finished discs will go.
I can see the concern as well. I'm having a hard time deciding which is better to the bottom dollar(e.g. its hard to quantify the 180 degree turns' effect from an ergonomic perspective).
Thanks,
Andy
Old 5th May 2008, 11:31 AM
BradM's Avatar
Karma Power: 274
That'd be a great idea except the operator has to manually flip the disc over before sanding the other side.
True, however you're talking about ergonomics. Each repetitive activity you can minimize, the better. You can do a number of simple things to reduce repetitions. They would still have to flip the disc, but you could cut down on them pushing those two buttons forty thousand times a day. Also, you might could use foot switches; that might cut down on the hand/finger movement.
Brad
Reply
Bookmarks
Tags
ergonomics
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
First article, pilot run and preproduction trial run - Definitions pinpin ISO/TS 16949 - International Automotive Quality Systems Standard 4 26th October 2008 04:51 AM
Ford Run at Rates - Correct Form and Advice needed. martint Customer and Company Specific Requirements 1 8th February 2008 07:24 AM
Attribute R&R Study for 10 Operators - .xls Excel form or advice wanted JoeSlomo Excel .xls Spreadsheet Templates and Tools 5 14th November 2007 08:24 PM
MSA and Number of operators - BSI auditor: 3 operators must be used for Gage R&R DJN Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10 7th March 2006 09:02 PM
Multiple Machines & Fixtures - PPAP run on all 6 machines using all Tombstones? Garry APQP and PPAP 8 23rd April 2004 11:31 PM
The time now is 02:45 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
