Go Back   The Elsmar Cove Forum > Benchmarking > Benchmarking - Methods and General Discussions
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th May 2008, 12:41 PM
dirkinjo dirkinjo is offline
Registration Date: May 2008
Thanks Given to Others: 1
Karma Power: 7
dirkinjo has less than 100 Karma points so far.
Question Calculating Metrics from the bunch of single/raw data for certain purposes
Hi all,
regarding the pdca(plan-do-act-check)-cycle there's written a lot about plan, act and check but you don't find a lot about do.
What I am searching for is how to get from the bunch of single/raw data to reasonable metrics. There are different ways for calculating for example customer satisfaction indices with weights and dividing them afterwards to get a weighted average. But what I have never seen is a methodology that helps to decide how to calculate a ratio based on an existing framework.
How do you calculate your metrics?
Kindly,
Dirk
Sponsored Links
Old 8th May 2008, 02:20 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Default Re: Calculating metrics for certain purposes
Welcome to The Cove!
I will give you an answer that may seem maddeningly vague.
The metrics are calculated against however it is you would know the process went well. A target time frame, no errors made, customer satisfaction after a service call is at the "I would definitely buy again" level, and so on.
The difficulty lies in calculating qualitative results.
For this I assign a value for each level of success, like a rubric does. I have given a sample of what that would look like in this little paper, Some Options for Risk Based Auditing.
Please let me know if this helps or not.
Stealth quality versus no quality
Thanks to Jennifer Kirley for your informative Post and/or Attachment!
Sponsored Links
Old 9th May 2008, 04:52 AM
Karma Power: 7
Default Re: Calculating Metrics from the bunch of single/raw data for certain purposes
Thank you Jennifer.
It's an interesting and helpfull example for the special situation and gives an insight of on special way to calculate metrics. So it was helpful to me as it has shown one example of a topic with a large scope.
Actually, I am searching for an overview about the possibilities of getting from raw data to metrics. Different calculation methods maybe with a decission tree, helping to decide which method has to be used in which case.
Old 9th May 2008, 03:29 PM
Steve Prevette's Avatar
Steve Prevette Steve Prevette is offline
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
I help a lot of folks develop metrics, and do have the following presentation available on our Department of Energy website:
http://www.hanford.gov/rl/uploadfile...oosing_PIs.ppt
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calculating Ppk on a single sided (unilateral) tolerance Lightning546 Student Research Questions - Any Educational Institution 16 2nd November 2009 06:04 PM
Control Chart CpK dilemma - Defect Per Unit data on a single production line sbickley Capability, Accuracy and Stability - Process, Machine, etc. 16 19th June 2009 08:32 AM
Calculating Cpk on a single sided (unilateral) tolerance lee01 Capability, Accuracy and Stability - Process, Machine, etc. 22 27th January 2009 10:54 AM
No editable (alterable) raw data from outside calibration laboratory? basselope ISO 17025 - Calibration, Measurement Gages and Test Laboratories 20 8th October 2008 02:04 PM
Life of the part - How long should I keep processing data, powder, raw material tests Dawn Documentation Control Systems, Procedures, Forms and Templates 3 14th February 1999 12:45 AM
The time now is 12:31 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
