8th May 2008, 03:44 PM
Registration Date: May 2008
Karma Power: 7 Karma: 10
PED (Pressure Equipment Directive) Certification - We hold an ASME 'S' stamp
We build pipe fabrication for the petro/chemical industry. There are a variety of process material flowing through it at a variety of pressures.
We hold an ASME 'S' stamp but are not ISO or any other certification.
I have been mandated to 'revise' our QC Manual to include this.
Should the existing manual be rewriten to include this, or an addendum...?
Kenny
8th May 2008, 03:51 PM
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 657
Karma Power: 191
Re: PED certification
I have moved this post to this forum since it really didn't apply to the Use of the Forum Software.
This forum addresses other standards, where you may get better responses.
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
8th May 2008, 04:03 PM
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
the PED (pressure equipment directive) gives you all the information you need to comply to, do you have a copy? if not, you really should get a copy. I cannot directly answer your questions because we fell into the whole "if you are ISO 9001 registered, and your CB has a European presence, then you are automatically in compliance to the directive" clause. Find a copy of the directive, it really isn't very complicated compared to some of the directives out there. pretty straightforward in its requirements.
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
8th May 2008, 04:23 PM
What is the name of the document I need?
Is it free issue or does it cost?
Where can I obtain it from?
Thanks so very much!!
8th May 2008, 04:24 PM
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 122
Karma Power: 109
Hi again kennycat.
There is more to it than simply revising your quality manual.
There are tables in Annex II of the directive that mandate what modules you may need to follow to comply with PED.
Here is the directive, it's free. http://ec.europa.eu/enterprise/press.../index_en.html
If you are CE marking to anything beyond Category I you will need the involvement of a Notified Body.
Digest this and get back to us with more specific questions.
Thanks to ScottK for your informative Post and/or Attachment!
8th May 2008, 05:18 PM
Karma Power: 255
Re: PED (Pressure Equipment Directive) Certification - We hold an ASME 'S' stamp
Thanks Scott, I knew somebody would come up with the proper references! u da man!
just for some added info....the need for PED compliance does not necessarily require CE marking....it depends upon the customer/location of customer. We held PED compliance for at least 2 years before we ever got into the CE scheme.
8th May 2008, 05:28 PM
We are a very large pipe manufacturer and are obviously entering into the market over seas.
Three of our shops are mandated to move forward now. We are all thre ASME stamp holders.
We are well established but not ISO certified. We build pipe fabrication from 1/4" OD to 66"+ OD and have some in our shop now over 5-3/4" thick. It is used for many applications but most is pressurized in service.
8th May 2008, 05:51 PM
Karma Power: 109
Having the ASME stamp will certainly help in getting your documentation in order. What Steel says is important... you can comply with PED and not CE mark. You can even CE mark to the PED and not need notified body approval.
The tables in Annex II dictate the "level" of compliance.
If you don't need notified body approval you will still need an "Authorized Representative in the community". Basically an EU rep for your products. If you have a sister company in the EU that makes it easy. If not, you'll need to find someone to partner with in that regard.
In our case, we have a distributor in Germany who is our authorized rep. That doesn't mean we can't sell direct to customers - but the authorized rep must be listed on your Declaration of Conformity.
The Tables in Annex Two for piping are read by pressure PS (in bar) and Nominal Size (DN). We do safety accessories, not piping so I'm not an expert at DN numbers. Choosing the table is based on Article 3 section 1.3. Choose the indent for the application you want to sell for.
