Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO/TS 16949 - International Automotive Quality Systems Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 24th March 2000, 03:43 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
Laughing Tools & Techniques
Here's a hot one:
4.2.4.5 "The supplier shall perform process studies on all new processes to verify process capability and to provide additional input for process control. The results of process studies shall be documented with specifications where applicable for means of production, measurement and test, and maintenance instructions. These documents shall include objectives for process capability, reliability, maintainability and availability, as well as acceptance criteria."
This is one h___ of a paragraph. Does it mean we shall do capability studies on every part; every dimension?
The TS Checklist states an auditor will look for related actions based on the results; defined acceptance criteria based on objectives;and if the studies include objectives for capability, reliability, maintainability, availability and the acceptance criteria.
HELP!!!!!!
Sponsored Links
Old 27th March 2000, 09:10 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I would think these would be limited to critical characteristics. As far as The results of process studies shall be documented with specifications where applicable for means of production, measurement and test, and maintenance instructions. the sentence sorta sucks. But I read it to say that your process studies have to drive production, measurement and test, and maintenance considerations.
...shall include objectives for process capability, reliability, maintainability and availability, as well as acceptance criteria... I would think these would be developed early on. I can only think they want to ensure these aspects documented.
I don't think so. Critical characteristics.
Sponsored Links
Old 29th March 2000, 10:41 PM
Karma Power: 0
I'm not sure on this. This is not atated in QS, it is added. So I'm thinking we need to state evidence of how we determine reliability, etc. and I am clueless how to show evidence of this. (Thanks, Marc)
Old 30th March 2000, 04:50 AM
Marc's Avatar
Karma Power: 605
Yin Yang
Well, it is and it isn't. Only the wording has changed. For example, where it says "...shall be documented with specifications where applicable.." - this simply means that you have to cite any specs you use. Let's say you use an ANSI spec for a characteristic - you have to cite the spec. No different than if you sample to the old mil standard. Stating the standard you use and not stating it are two different situations.
They're looking to make sure you are basing the stuff you do on something and where there's a spec you name it. Instead of saying "...We have maintenance instructions..." you have to say "...Maintenance instructions were derived from the manufacturers recommendations (or the equipment manual or where ever) and consideration to use of the equipment was considered..."
Look at "...defined acceptance criteria based on objectives..." You have an acceptance test. What is it based upon? The objective is to meet or exceed a threshold (the 'pass' point) and to reach (or improve upon) a specified (by you) capability.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Value Stream Mapping Tools - Seeking VSM tools (i.e. clipart, icons, symbols, etc) Fatboy Quality Tools, Improvement and Analysis 18 8th April 2009 02:18 PM
PCBA Visual Inspection Tools & Methods - discounting Optical Tools quality1 Manufacturing and Related Processes 11 29th October 2008 01:42 PM
List of QA (Quality Assurance) Tools and Techniques shushd Quality Tools, Improvement and Analysis 13 21st April 2007 03:06 AM
What tools and techniques are used in paper gaging? apestate Inspection and Test, Sampling and Related Topics 8 12th May 2006 10:45 AM
ISO/TS 16949:2002 - 6.2.2.1 Product Design Skills - Tools and techniques needed GaneshKumar.Vatturi Design and Development - Process and Product 4 4th November 2005 10:41 AM
The time now is 12:47 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
