Go Back   The Elsmar Cove Forum > Elsmar Cove Forum Essentials > Forum News and General Information
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th May 2008, 11:10 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Question Tags System - Should we use it?
As for the tags, they could be useful, but we will have to look out for people misusing them.
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Sponsored Links
Old 12th May 2008, 11:51 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default Re: Tags System - Should we use it?
I copied this to start a public discussion of using 'Tags' in threads (a new vBulletin 'feature').
Your opinions?
Sponsored Links
Old 12th May 2008, 12:27 PM
Scott Catron's Avatar
Scott Catron Scott Catron is offline
True Artisan
Registration Date: Aug 2003
Thanks Given to Others: 34
Karma Power: 52
Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.
The only negative I see (and this is just from observing tags at Amazon.com*) is folks tagging things in a non-standard way - same article with "calibration", "calibrating" and "callibrating" tags.
How much moderator control is there over tags?
*just as an example, here are the tags on a 7-port USB hub:
usb hub (39)
7 port usb hub (34)
7-port usb hub (25)
7 port (15)
usb 2 (12)
excellent (11)
usb (11)
multi port hub (10)
hub (9)
slim (4)
black (2)
powered hub (2)
7 port usb 2 hub (1)
7 port usb hum (1)
7-port usb 2 hub (1)
best 7 port hub yet (1)
blue light (1)
cool (1)
design (1)
fantabulous (1)
good hub (1)
mac usb2 (1)
metal (1)
mount (1)
poorly designed 7 port hub (1)
portable usb hub (1)
powered usb hub (1)
ps3 (1)
rockband (1)
solid usb hub (1)
the best usb hub period (1)
upstream hub (1)
usb 20 (1)
usb port (1)
usb ports (1)
usb2 (1)
usb2 hub (1)
I don't have a solution, but I admire your problem. -- Steven Wright
I'm a moderator here, so if you need help with something, feel free to ask.
Old 12th May 2008, 12:35 PM
Marc's Avatar
Karma Power: 605
If it's not already set this way, I *think* moderators can delete tags. I'll have to take a look.
Old 12th May 2008, 12:40 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
I really don't understand the tags thing.
Stealth quality versus no quality
Old 12th May 2008, 12:41 PM
Marc's Avatar
Karma Power: 605
Old 12th May 2008, 01:02 PM
True Artisan
Karma Power: 52
It's a way for users to categorize "stuff". Here, it categorizes threads, at Amazon.com, it categorizes their merchandise. When you click on a tag, you see all items (threads) with the same tag.
Hope that helps.
Old 12th May 2008, 06:51 PM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Scott, you make a very good point. I think the tags would be nice, but it is something that would need to be managed. While the "see related threads" isn't perfect, it seems to get the job done, and does it automatically.
Brad
My idea of housework is to sweep the room with a glance.
Reply
Bookmarks
Tags
thread tags
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Reject Tags - Plastic reject tags that can be erased and reused stbushmen Misc. Quality Assurance and Business Systems Related Topics 5 23rd June 2009 02:15 PM
Tags - Thread 'Tags' - New in vBulletin version 3.7 - Will YOU help us? Marc Instructions --> How to use the Forum Software 15 20th May 2009 05:49 PM
Calibration Tags - External company applied their tags - Do I need to apply our tags fregando Documentation Control Systems, Procedures, Forms and Templates 6 28th September 2006 01:13 PM
Supplier for QC stickers, hold tags, etc. apestate Documentation Control Systems, Procedures, Forms and Templates 4 12th March 2004 01:46 PM
The time now is 03:21 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
