13th May 2008, 09:54 PM
Involved in Discussions
Registration Date: May 2007
Thanks Given to Others: 114
Karma Power:
14 Karma: 55
Corrective Preventive Action Turtle Diagram example needed
Hi to All,
Does anyone have a CAPA turtle diagram to share?
Thanks in advance
AC
14th May 2008, 05:45 AM
Registration Date: Jan 2008
Karma Power:
8 Karma: 10
Re: Corrective Preventive Action Turtle Diagram example needed
Do you still require this diagram? I will be able to help - Please advise your timescales.
Regards
VivieH
14th May 2008, 08:37 AM
Karma Power:
14 Karma: 55
yes, Ido.
15th May 2008, 05:22 PM
Karma Power:
14 Karma: 55
I'm working on this CAPA turtle map, I'm little stuck on Efectiveness and efficiency of the process;
Effectiveness:
Number of CAR's open/closed
Problem reocurrence
Efficiency
CAPA Closure time
CAPA Answered on time
Am I right?
Also please review my process flow, there are some new things added to the current process.
Thanks for your input.
15th May 2008, 05:47 PM
Karma Power:
14 Karma: 55
Attached file.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
20th May 2008, 03:23 AM
Courtesy Access
Registration Date: Mar 2001
Thanks Given to Others: 225
Karma Power:
73
Anerol C,
You can try viewing link for Key Process Indicator (KPI).
http://wave.prohosting.com/cfo/Turtle.htm
Hope this helps.
Best regards,
Raffy
12th November 2008, 06:26 AM
Getting Involved (6 to 9 Posts)
Registration Date: Aug 2005
Thanks Given to Others: 5
Karma Power:
18 Karma: 10
Originally Posted by
Anerol C
Attached file.
Thanks Anerol C,
The flow you attached is most helpfull. I have however one questions on it: what guideline / requirements / pass criteria are used here to define when a CAR shall be written?
Pierre
Thread Tools
Search this Thread
Display Modes
Rate Thread Content
