The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Medical Devices, Medical Information Technology, Medical Software and Health Informatics > Medical Device Related Standards > ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems
Forum Username
Wooden Line
Sample Retention Requirements - Quality Records procedure - ISO13485
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
physical sample, quality records, samples and sampling plans
Reply
  Post Number #1
Old 14th May 2008, 10:43 AM
Triboyle
Please Help! Sample Retention Requirements - Quality Records procedure - ISO13485
Hello all,
just a quick query.l am writing up a control of Quality Records procedure and under the heading of sample retention, i have hit a block.
We are a start up medical device company and as of yet, have no samples to retain. Is there a requirement to retain a certain amount of samples, when the device is a disposable, transient use, class 1 device (or class 2a MDD)? I know there are regulations around length of time for document retention, but are there any for sample retention? Should it even be in a control of records procedure?
Many thanks in advance,
Tri
Sponsored Links
  Post Number #2
Old 14th May 2008, 02:28 PM
QA-Man
Re: Sample Retention Requirements - Quality Records procedure - ISO13485
ISO 13485 says "The organization shall retain the records for a period of time at least equivalent to the lifetime of the medical device as defined by the organization, but not less than two years from the date of product release by the organization or as specified by relevant regulatory requirements"
It would be a good starting point to define the expected lifetime of the device.
I would take the greatest lifetime of all your devices and add a year or two to make things easy.
We're also a startup and use the following retention times. Note: The numbers are actually based on Japanese MHLW requirements
Physical copies of records are maintained for a minimum of 3 years. If there is no electronic equivalent the following applies:
  • Records related to personnel, training, and human resources will be maintained for 6 years
  • Records related to devices will be maintained for 16 years or the life of the device, whichever is greater.
Electronic records are maintained indefinitely
Thank You to QA-Man for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 15th May 2008, 06:39 AM
Triboyle
In Reply to Parent Post by QA-Man View Post
Many thanks for that. Does your quality record procedure include sample retention? If so, do you retain samples for the same length of time as your paper records?
  Post Number #4
Old 15th May 2008, 09:23 AM
QA-Man
I am not sure what you mean by sample. Do you mean an actual device?
Thanks to QA-Man for your informative Post and/or Attachment!
  Post Number #5
Old 15th May 2008, 11:55 AM
Triboyle
Yes, i have seen in other Control of Quality Records procedures for medical device companies that samples of each batch are held in case of testing needs later?
It seems an unusual place to store such instruction though and i cannot seem to find any regulation that requires it?
  Post Number #6
Old 15th May 2008, 12:20 PM
QA-Man
There are no regulatory requirements governing this (that I'm aware of).
Its not a bad idea to keep product samples but it might be impracticle. How many samples would you retain for each batch. How big are your products? Do you have the room to store them all for the life of the device?
You should absolutely define the controls and retention periods for all records related to the product. This includes design history records (shop/production travelers), manufacturing methods (work instructions), testing methods (incoming, in-process & final), operating procedures, labeling, instructions for use, traceability records, etc.
This way you can build a snapshot of the product at any point in time for any given batch.
  Post Number #7
Old 16th May 2008, 09:13 AM
Triboyle
That's great. Many thanks for your help.
  Post Number #8
Old 19th May 2008, 11:36 AM
Roland Cooke
Records can of course include physical samples (often kept for re-testing in the event of a future complaint investigation being required).
Lifetime may actually mean a person's lifetime, in the case of certain implants.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
ISO 13485 Records Retention Requirements amjadrana Records and Data - Quality, Legal and Other Evidence 19 6th November 2014 04:34 AM
Pharmaceutical Product Sample Retention Requirements mcp47 Manufacturing and Related Processes 1 23rd January 2013 02:32 PM
Keepsakes...Sample retention requirements? WisdomseekerSC Other Medical Device and Orthopedic Related Topics 2 11th October 2009 08:38 PM
Retention and disposal of documents and records procedure ahmed_hasan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5 17th December 2008 12:35 PM
Retention Sample Requirements ISO 13485 and 21 CFR Part 820 Dublin 4 ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems 8 18th June 2007 03:13 AM
The time now is 03:06 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
