Elsmar Cove Quality DiscussionsWhat is meant by two throws, three throws etc, when applied to Compressors?The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
compressors
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 5th June 2008, 02:02 AM
chvijin
Question What is meant by two throws, three throws etc, when applied to Compressors?
What is meant by two throw, three throw etc., in the compressors?
Sponsored Links
  Post Number #2
Old 5th June 2008, 05:43 AM
Umang Vidyarthi
Yin Yang Re: What is meant by two throws, three throws etc, when applied to Compressors?
In Reply to Parent Post by chvijin View Post
Hello Chvijin,
Welcome to the cove.
The crank shaft of a compressor has crank pins to which the big end of con.rods are attached. Displacement of a crank pin from crankshaft is called a 'Throw'. The number of throws may be odd or even and vary from 1 to 16 or more in V shape models.
Hope this helps.
Umang
  Post Number #3
Old 8th June 2008, 11:41 PM
chvijin
Thx vidyathri........i thought it means that no. of strokes......
  Post Number #4
Old 9th June 2008, 02:20 AM
Randy's Avatar
Randy
Throw is related to number of cylinders and you'll normally have a 2-stroke type compressor...intake-compression/exhaust
Thanks to Randy for your informative Post and/or Attachment!
  Post Number #5
Old 9th June 2008, 07:29 AM
Umang Vidyarthi
IMO the 'THROW' of a compressor is directly linked to the 'CRANK THROW'. Copied below is a portion from the website of Dresser-Rand which speaks of crank throws.
The Dresser-Rand HHE reciprocating compressor has earned a reputation of conservative, rugged design with high reliability and flexible operational capabilities. Our HHE compressors provide gas compression to more than 60,000 psi and are suited to drivers ranging from 200 to 22,500 hp (16,778 kW). HHE frame configurations are available with up to ten crank throws. The VB, VG, and VL models have a variable crank design with a bearing between each crank throw so that both odd and even crank throw options are possible. This reduces cost and parasitic horsepower as balancing cylinders with connecting rod and crosshead are not required for on odd throw applications. For your application, we carefully match HHE compressor components to suit your specific requirements. Choosing from among our HHE frame sizes and our many cylinder, valve, distance piece and driver options, we engineer the best combination of components to provide the most reliable, efficient compressor for your needs.
2. Also there are variable capacity compressors having adjustable 'Crank Pin Throw' structure - The compressor includes a reversible motor that rotates a crankshaft. The crankshaft is connected to a piston by a mechanical system. The mechanical system drives the piston at a full stroke between a bottom position and a top dead center position when the motor is operated in a forward direction. The mechanical system drives the piston at a reduced stroke between an intermediate position and the top dead center position when the motor is operated in the reverse direction. The compressor also includes a control for selectively operating the motor in either the forward direction at a first preselected, fixed speed or in the reverse direction at a second preselected fixed speed.
Read for more details :http://www.patentstorm.us/patents/6217287/fulltext.html
Hope this helps
Umang
Thanks to Umang Vidyarthi for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Standards or Specifications required for Garbage Truck Compressors quality issue Various Other Specifications, Standards, and related Requirements 1 14th March 2013 02:30 AM
What is meant by a Characteristic Classification within GR&R? TPMB4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 4th October 2012 10:20 AM
Defining the type of Applied Part - Metal Probe (Applied Part) employs Water Cooling Roland chung IEC 60601 - Medical Electrical Equipment Safety Standards Series 2 27th October 2011 08:56 PM
CE Marking for Mobile Air Compressors driven by a Diesel Engine Kalimuthu CE Marking (Conformité Européene) / CB Scheme 2 9th December 2009 12:01 PM
Para 4.6.3c - What is meant by the last part; ...number and issue of...? mibusha QS-9000 - American Automotive Manufacturers Standard 4 15th September 1999 02:42 PM
The time now is 09:46 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
