Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 16th June 2008, 06:09 AM
Nicco Nicco is offline
Involved - Posts
Registration Date: Mar 2006
Thanks Given to Others: 2
Karma Power: 15
Nicco has less than 100 Karma points so far.
Send a message via Skype™ to Nicco
Please Help! PCBA (Printed Circuit Board Assembly) Conformal coating material and thickness?
Hi, friends,
Did anyone know what standard or protocol has defined the conformal coating thickness and material for PCBA(PCB assembly) for Automotive application.
I knew that's depend on the PCBA's or products located in where, (ex. powertrain, chassis, body). especially environmental temperature, humidity...etc.
Best regards,
Nicco
Sponsored Links
Old 16th June 2008, 09:39 AM
justncredible justncredible is offline
On Holiday
Registration Date: Nov 2006
Thanks Given to Others: 8
Karma Power: 0
justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.
Default Re: PCBA (Printed Circuit Board Assembly) Comformal coating material and thickness?
For automotive I am not sure.
I do think IPC610 does have a section on CC and potting. There are diffrent levels so if your not sure contact your supplier engineer and make sure you are using the right spec.
Maybe another can expand on it more since it has been a long time since I worked in electronics. And we only potted for auto apps.
Sponsored Links
Old 16th June 2008, 10:48 AM
Umang Vidyarthi Umang Vidyarthi is offline
Involved in Discussions
Registration Date: Mar 2007
Thanks Given to Others: 189
Karma Power: 44
Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.Umang Vidyarthi is appreciated, and has over 1100 Karma points.
Yin Yang Re: PCBA (Printed Circuit Board Assembly) Comformal coating material and thickness?
Originally Posted by Nicco View Post
Hi, friends,
Best regards,
Nicco
IEC 61249-2-12 is applicable for PCBs/PWBs.
Also have a look here for more standards & guidelines. :
http://www.thetestlab.com/data/june99.pdf
Umang
Quality has to be caused, not controlled.-Philip Crossby
Success comes in cans, failure in can'ts
Old 17th June 2008, 02:40 AM
Involved - Posts
Karma Power: 15
Umang
Hi, Umang and justncredible,
Thanks !
my question is PCB have been mounted components (passitive and active), and I used epoxy with spray coating in components surface to prevent any humidy and temperature damage. I dont' know have any standard or protocol has demand the thickness for automotive/vehicle application. Maybe IPC-A-610D has been defined, I need to check it.
Best regards,
Nicco
Old 17th June 2008, 08:25 AM
e006823 e006823 is offline
Registration Date: Nov 2003
Karma Power: 33
e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.e006823 is appreciated, and has over 300 Karma points.
Default Re: PCBA (Printed Circuit Board Assembly) Conformal coating material and thickness?
Thickness can range from .0005" to .005", depending on material. I don't believe IPC-610 will address thickness. You may want to look at IPC-HDBK-830, IPC-CC-830 (or Mil-I-46058)
Regards,
Old 18th June 2008, 07:00 AM
w_grunfeld w_grunfeld is offline
Willy Grunfeld
Registration Date: Jul 2005
Thanks Given to Others: 17
Karma Power: 35
w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.w_grunfeld is appreciated, and has over 700 Karma points.
Nicco,
Probbably IPC-CC-8308:2002 is what you need.
However bear in mind that coating thickness is hard to control, especially when applied by spraying, and in any case coating thickness cannot be measured directly. All specs that I know, involve spraying special test specimens (flat glass) at the same time as the actual board and measuring the thickness on the glass specimen.
It is kind of b...t , since it all depends on the skill and steadiness of the operator's hand. Making a few samples that pass the test is no guarantee for production units.
Much more critical than thickness is coverage, and to achieve that make sure your coating material is UV fluorescent-means it is visible when inspected under a UV light.
I am guessing here, but I doubt there is a thickness requirement specific for automotive. I think in automotive you will have to pass humidity and salt spray test of the finished board to indirectly qualify the coating.
Willy Grunfeld
RAMSQ Consultant
Reply
Bookmarks
Tags
conformal coating material, conformal coating thickness, printed circuit board, pcb assembly (pcba)
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Frustrated with Printed Circuit Board Assembly Suppliers JkelleyCDS Supplier Quality Assurance and other Supplier Issues 11 12th June 2009 07:58 PM
PCB (Printed Circuit Board) Assembly Inspection Checklist aeroqual Inspection and Test, Sampling and Related Topics 5 23rd March 2009 09:44 AM
Auditing PCB (Printed Circuit Board) Assembly Lines - Fire And Safety Systems joebrown ISO 9001 - Quality Management Systems Standard 21 19th June 2008 08:50 AM
I need to make an MSDS for PCB (Printed Circuit Board) Assembly Product Phyllis ISO 14001 and Environmental Related Standards 5 4th June 2004 12:25 PM
PCB (Printed Circuit Board) Assembly - Wave Solder Capability Chris May SPC Monitoring and Statistical Analysis Techniques 6 2nd April 2002 10:38 PM
The time now is 08:27 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
