The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 10th July 2008, 07:13 AM
dvd101 dvd101 is offline
Registered Visitor
Registration Date: Dec 2004
Thanks Given to Others: 18
Karma Power: 36
dvd101 has less than 100 Karma points so far.
Question Self define the UCL and LCL instead of by Calculation
Hello all,
I am using X and Moving R chart due to only 1 data per date.
Can I just simply default the UCL, LCL = +/-1% of Mean X and MR Limit will default by 1% Center line of Mean of X instead of calculate the UCL and LCL???
Any concerns if auditor look into such SPC Chart? How about if I address this issue in MRM, make sure them have considered and agreed on such SPC monitoring practice, is it okay to the auditor?
The SPC always out of control (UCL , LCL, and MR Limit) if we use the calculated UCL,LCL and MR Limit.
Regards,
David
Sponsored Links
Old 10th July 2008, 07:48 AM
justncredible justncredible is offline
On Holiday
Registration Date: Nov 2006
Thanks Given to Others: 8
Karma Power: 0
justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.justncredible is appreciated, and has over 400 Karma points.
Re: Self define the UCL and LCL instead of by Calculation
My guess is your useing the wrong chart, have you tried a weighted moving range, a IWMR chart?
As for what the auditor questions, I do not think a auditor will double check the math of a chart. Even if it is out of control your customer has agreed to use it.
Thanks to justncredible for your informative Post and/or Attachment!
Sponsored Links
Old 10th July 2008, 09:03 AM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 29
Karma Power: 148
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
I suppose you could use something like +/-1%, but that removes most of the purpose of SPC.
SPC is designed to help you understand and control your process. The rules are designed to alert you to the possibility of unusual, non-random occurrences. By widening the control limits, you decrease the probability of noticing those occurrences.
And just because a point is OOC (out of control) doesn't mean you have to change or adjust something. There will be occasional OOC indications even for a process that is perfectly in control. The OOC indication is a reminder to check the process. Hopefully nothing is wrong and the process is fine. But perhaps there is a problem that needs fixing. If the process is often OOC, that is an indication that you might want to address the underlying problems that are causing the process to perform erratically.
But remember, it is ultimately a question of moeny and value. If the process is often OOC according to the rules, but still well within the spec limits all the time, then there is less cause for correction. On the other hand, if you can identify and eliminate the causes of the OOC, you may be able to improve the process further - potentially gaining new customers or lowering costs.
Tim F
Thanks to Tim Folkerts for your informative Post and/or Attachment!
Old 10th July 2008, 01:56 PM
bobdoering's Avatar
bobdoering bobdoering is offline
Stop X-bar/R Madness
Registration Date: May 2002
Thanks Given to Others: 1,242
Karma Power: 447
bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.
bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to bobdoering
In Reply to Parent Post by justncredible View Post
My guess is your useing the wrong chart.
I agree. What is the process, what is the distribution?
Thanks to bobdoering for your informative Post and/or Attachment!
Old 10th July 2008, 09:11 PM
Registered Visitor
Karma Power: 36
It is the Testing Process, we need to establish the SPC for the Tester which use to sort out the good and bad units.
In general, I think the tester may not need to perform the SPC since "Tester" will not mfg / fabricate anything just sorting. Am I right?
Old 10th July 2008, 10:59 PM
bobdoering's Avatar
Karma Power: 447
In Reply to Parent Post by dvd101 View Post
There is something to be said about that, although there may need to do attribute charting if there is a customer requirement for recording the trends. It would be "report card" charting for all practical purposes. Not the best use of SPC, but a use nonetheless.
Let's not forget that X-bar/R is not the only SPC chart!
Old 10th July 2008, 11:52 PM
Karma Power: 148
When assessing test units or meters, Gage R&R is often a more appropriate and valuable approach than SPC.
Thank You to Tim Folkerts for your informative Post and/or Attachment!
Old 11th July 2008, 12:18 AM
Registered Visitor
Karma Power: 36
The GR&R was performed, however, the stability of the Tester also need to perform. Therefore, we use SPC to monitor the Tester's stability.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
How to calculate for LCL and UCL for Schedule Deviation vanitha250 Quality Tools, Improvement and Analysis 2 11th November 2010 12:16 PM
What is the difference between UCL, LCL and Cp, Cpk blue moon Capability, Accuracy and Stability - Process, Machine, etc. 3 12th February 2009 08:07 PM
When to change UCL and LCL - SPC Software war-eagle SPC Monitoring and Statistical Analysis Techniques 4 15th December 2008 12:50 PM
Calculation of UCL and LCL for SPC charts (Xbar-s) with sub-group sample of 32 pcs. ISO MAN SPC Monitoring and Statistical Analysis Techniques 1 6th November 2006 09:08 AM
One sided Control Chart with only UCL or LCL lwquality SPC Monitoring and Statistical Analysis Techniques 2 25th October 2006 09:31 AM
The time now is 05:05 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
