Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th July 2008, 09:00 AM
Wesley Lai Wesley Lai is offline
Registration Date: Jul 2008
Karma Power: 6
Wesley Lai has less than 100 Karma points so far.
Please Help! How to choose the correct General Inspection Level & AQL level...?
I hope somebody can help me out with this main question:"How to choose the correct General Inspection Level & AQL level and what is the reliability of the outcome?"
We do many inspections by General Inspection Level II + AQL 2.5. Only knowing that this standard is commonly used.
Correct me if I am wrong. AQL 2.5 means that we can accept a defect rate of 2.5%, which means 97.5% of the goods are non defect.
And by choosing General Inspection Level II, means doing a sample inspection and the result compared with the AQL table will determine rejection or acceptance of the goods. What is the reliability of the decision based on these statistics?
Let's say, I do non destructive tests on a batch of 151-280pcs. I choose to accept AQL level 1.0. My test results should be 95% accurate/reliable. Which General Inspection Level must I choose?
Looking forward to have your opinion.
Thanks in advance~!
Sponsored Links
Old 13th July 2008, 04:08 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default Re: How to choose the correct General Inspection Level & AQL level...?
Hi Wesley, and welcome to the Elsmar Cove.
Unfortunately, there is no simple answer to your question. The Z1.4 (formerly known as MIL-STD-105) sampling plans are not based on specific statistical criteria.
The AQL level is a defect rate that will usually get accepted. So if your have AQL = 2.5, then lots with 2.5% defective will probably get accepted. (The probability depends on all sorts of factors. For normal inspection, the number is typically around 95%, it can be from roughly 90-98% as I recall). The batches have to be much worse (typically 3-10 times worse) before you can be moderately sure of rejecting them.
The only real way to judge the sampliong plans is to look directly at the OC curves and tables at teh back of the standard.
"a batch of 151-280pcs...AQL level 1.0 ... 95% accurate/reliable. Which General Inspection Level must I choose?"
For a given AQL, you can look up all the different sampling plans, then find the defect rate that will be accepted 95% of the time and the defect rate that will be rejected 95% of the time.
CODE..SAMPLE...AC..RE...95%......95%
..........SIZE................ACCEPT.REJECT
E.........13..........0....1...0.394....20.6
H.........50..........1....2...0.715....9.14
J..........80..........2...3....1.03.....7.66
K.........125.........3...4....1.09.....6.20
L.........200.........5....6...1.31.....5.26
For your example, the only sample sizes you would get for a batch of 151-280 are 50 (Level II & III) or 13 (all the other Levels)
for normal inspection. That doesn't give you very much flexibility!
Another option is to design you own sampling plan. Select the defect rate you will accept 95% of the time, the defect rate you will reject 95% of hte time, adn find a sampling plan that will work for your needs.
Tim F
Thanks to Tim Folkerts for your informative Post and/or Attachment!
Sponsored Links
Old 20th November 2008, 12:20 PM
gglntn gglntn is offline
Registration Date: Nov 2008
Karma Power: 5
gglntn has less than 100 Karma points so far.
Concerning AQL, we use 1 gallon plastic bottles to package product. Currently bottles are simply brought in the door with no incoming inspection, sent to the production floor, and used, generally within 24 - 48 hours. During production, as the operator manually puts the bottles on the conveyor belt leading to the fill station, (S)He inspects each one for defects, debris, etc. Defective bottles are immediatlely counted and discarded.
Should QA be doing incoming inspection, and if so, how would we go about chosing an accept/reject level for the lot, knowing that further down the line bottles will be 100% inspected by the production operator.
Why would be ned to develop an AQL to reject the lot? All that would do would be to add an additional step. Thnx
Old 9th December 2008, 09:20 AM
davidzhao davidzhao is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jan 2007
Karma Power: 12
davidzhao has less than 100 Karma points so far.
Send a message via MSN to davidzhao
AQL is related to you and your supplier also.Let's say AQL was set to 1.0,if the vendor's quality level is 5%(reject ratio),you'll not get approval of inwards.
So when you set the AQL,check how much failure you can accept(normally the failure will be graded as A,B,C etc which related to safe/regulator,function/dimension,appearance,etc), and check with vendor where vendor is. If vendor can not meet the AQL you set and you insist on that,need vendor do 100%inspection before deliver.
As long you have a inspect station(visually) on site,you can accept more which kind of failure will be caught up by inspector.
Any way,it's related to your company, and also your vendor,and it's active and will be updated when things improved.
Old 25th February 2009, 10:46 AM
Renaud Renaud is offline
Registration Date: Feb 2009
Karma Power: 3
Renaud has less than 100 Karma points so far.
I agree with Tim's response.
To complement it: about your sentence "by choosing General Inspection Level II, means doing a sample inspection and the result compared with the AQL table will determine rejection or acceptance of the goods":
The general inspection level II is what the norm calls the "normal" level. If you go to a reduced (I) or tightened (III) level, the discriminatory ability of your inspection will be different. You can switch to one of these levels if you have strong hints--one way or another--about the quality level (e.g. if the same supplier's goods were rejected more than twice over the last 5 inspections, you should go to level III.
I hope it helps.
Old 25th February 2009, 12:56 PM
SteveK's Avatar
SteveK SteveK is offline
Involved in Discussions
Registration Date: Nov 2007
Thanks Given to Others: 35
Karma Power: 28
SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.SteveK is appreciated, and has over 700 Karma points.
Lurker Re: How to choose the correct General Inspection Level & AQL level...?
In the past for plastic moulding etc the AQL level allowed different AQLs for different defect levels i.e. Critical (e.g. 0.65), Major (e.g. 2.5), Minor (e.g. 6.5). This miight give you some extra flexibility, depending on how you classify the defects. Or am I just complicating matters?
Reply
Bookmarks
Tags
aql, aql level, inspection level
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
AQL - How to calculate aql and aql level moonlight AQL - Acceptable Quality Level 3 6th November 2009 09:50 PM
AQL - AOQL - What % equals a certain level of AQL miss quality AQL - Acceptable Quality Level 10 21st August 2009 03:57 PM
Difficult Inspection Level/AQL - Verifying it is the correct part Doctor Pig AQL - Acceptable Quality Level 5 25th November 2008 03:51 PM
What is AQL, Inspection Level, and Type of Inspection tahashamim Inspection and Test, Sampling and Related Topics 15 21st December 2007 09:29 PM
Using AQL to get true random sampling using General Inspection Level II Shasta Ell AQL - Acceptable Quality Level 4 17th May 2006 12:27 PM
The time now is 04:51 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
