DNV Private Forum Header
Go Back   The Elsmar Cove Forum > Company Specific Forum(s) > DNV Client Forum
DNV Forum SideBar
New Threads Feeds
RSS FeedRSS Feed
Sponsor Links
Reply
Old 5th August 2008, 07:51 PM
WCHorn's Avatar
WCHorn WCHorn is offline
Rubber, Too Glamorous?
Registration Date: May 2005
Thanks Given to Others: 53
Karma Power: 20
WCHorn has less than 100 Karma points so far.
Default OASIS supplier administrator
I am a registered contact for Parco, Inc., but I can't tell if I am classified as the Supplier Administrator. How do I determine if I am classified as the Supplier Administrator?
Sponsored Links
Old 5th August 2008, 07:58 PM
Sidney Vianna's Avatar
Sidney Vianna Sidney Vianna is offline
Post responsibly
Registration Date: Oct 2001
Thanks Given to Others: 688
Karma Power: 467
Sidney Vianna is appreciated, and has over 1700 Karma points.
Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.Sidney Vianna is appreciated, and has over 1700 Karma points.
Default Re: Oasis supplier administrator
Hi Carl,
I went to the OASIS database and found your entry.
The public information in OASIS does not disclose who the administrator is, but allows for a contact request: The following was cut and pasted from your entry in OASIS:
Currently you do not have access to view this supplier's Assessment Details. Access to this information can only be granted by the supplier's OASIS administrator.
If you want to request access, please use the contact information below to contact the supplier.
Parco, Inc.
1801 South Archibald Ave.,Ontario, CA 91761 United States
(909) 947-3540 ext 362
This supplier has a designated IAQG OASIS administrator. If you want OASIS to send a request on your behalf (including your personal contact information) to the IAQG OASIS administrator for this supplier, please click here. OASIS recommends you follow up with the supplier, using the above supplier contact information, to confirm the receipt of the request.
If you click on the "click here" and you are the administrator, you should receive an email, automatically generated. If you don't receive an email, then you are not set-up as the administrator.
Hope this helps.
Fighting organizational dysfunction, one post at a time.
Thanks to Sidney Vianna for your informative Post and/or Attachment!
Sponsored Links
Old 6th August 2008, 03:41 PM
WCHorn's Avatar
Karma Power: 20
Thank you Sydney, it worked. I received the request and therefore I am identified as the administrator.
Old 6th August 2008, 07:23 PM
Post responsibly
Karma Power: 467
You are welcome. You should also have received the Advisory Notice we sent to our Aerospace clients, attached below.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Reply
Bookmarks
Tags
oasis database
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
New OASIS database feature - Contact the CB with concerns about a supplier Sidney Vianna AS9100 Aerospace Standard and Requirements 25 9th November 2009 05:49 PM
Job responsibilities of a project administrator funmi Occupation Discussions 4 13th May 2009 12:29 PM
OASIS database - deadline for setting up an administrator is fast approaching Sidney Vianna AS9100 Aerospace Standard and Requirements 1 4th August 2008 09:13 AM
AS9100 vs. AECMA vs. Oasis (Online Aerospace Supplier Information System) Angelika AS9100 Aerospace Standard and Requirements 1 5th November 2004 06:35 PM
The time now is 09:34 AM. All times are GMT -4.
no new posts
