A Peachfarm Internet Property
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
En Number - Reference that explains En Numbers Theory & Application
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
calibration (general topics)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
  Post Number #1
Old 17th August 2008, 09:58 PM
blueicecube
Please Help! En Number - Reference that explains En Numbers Theory & Application
Hi Everyone,
I was unable to find any reference that explains En numbers theory & application except for in ISO/IEC Guide 43.
When I googgled, there is a NCSLI conference proceeding in 2006 entittled En Number 101. However, I need to pay to view the paper.
Advice anyone? Thanks in advance.
Sponsored Links
  Post Number #2
Old 18th August 2008, 02:40 PM
Coury Ferguson's Avatar
Coury Ferguson
Re: En Number - Reference that explains En numbers theory & application
Can anyone help?
Thanks to Coury Ferguson for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 18th August 2008, 02:46 PM
jfgunn
You might try the following link. In the 8 page document, there is a description of how to calcualte the En.
http://www.proficiency.org/Portals/0...yandHowsV2.pdf
Note that this is taken from one of the proficiency test providers. Other providers may have good explanations on their websites as well.
Thank You to jfgunn for your informative Post and/or Attachment!
  Post Number #4
Old 18th August 2008, 08:27 PM
Hershal's Avatar
Hershal
I believe another source is APLAC PT001 or APLAC PT002, both available at no charge.
http://www.aplac.org
Thanks to Hershal for your informative Post and/or Attachment!
  Post Number #5
Old 18th August 2008, 10:06 PM
blueicecube
...most of the references explained on how its calculated but not on why is it used.
Just in case there is a limitation for the use of En numbers that I need to be aware of.
Because of limited number of PT provider here and cost (if were to do it overseas), our lab send our own instruments to the National Lab (if they have the capability) or to our competitors as our own mean of interlaboratory comparisons. Hence, we produce our own interlaboratory comparison report and judge our capability based on the result.
Due to this, we need to know the reason behind En numbers and its scope of application to make sure that it is valid for our own application.
I hope in the future, we will have more PT providers here, if only someone could realize that quality is as important as producing goods..
  Post Number #6
Old 19th August 2008, 05:16 PM
Hershal's Avatar
Hershal
The why is actually pretty simple: To let the participant know when the reported value, plus/minus the uncertainty, is what is known as an outlier. That means the value is outside the acceptable limits and a corrective action has to be initiated and investigated.
APLAC and the ABs have the ability to offer PT/ILC and also measurement audits. Having said that the availability does appear to be somewhat limited.
An ILC with the NMI and/or competitors is perfectly valid, but yes, the En score does have to be calculated and a report prepared. Contact me off-line and I may be able to refer someone to you to do the reporting, even perhaps run an ILC for you, located in India. No idea as to cost.
Hope this helps.
  Post Number #7
Old 19th August 2008, 09:01 PM
blueicecube
My concern on the self-calculated En value is that the measurement uncertanties factors taken into consideration maybe different from NMI/our competitors lab. Whereas in format PT program, well at least most of them, specify which factors are taken into consideration for a particular PT/calibration.
Thus, if the abs(En number) is more than 1, we are unable to identify whether there is an underlying problem or it is merely different considerations taken in regards to the measurement uncertainty calculation.
Any views on this? Or am I merely mistaken lol
  Post Number #8
Old 4th December 2013, 10:42 AM
MotorCityQuality
I realize that this is over 5 years late, but if you deal with 17025 PT issues, this becomes important, and it's never the wrong time to bone up on 17025 issues!
Buckle up, folks!
The En number is merely a percentage of your measured value to the reference value, corrected with the square root of the sum of the squares of your uncertainty and the uncertainty of the reference value.
If your absolute En number is over 1, then your corrected measurement is GREATER than your uncertainty. That would indicate 1 or a combination of four causes, assuming your reference value and reference uncertainty are valid:
1) Your uncertainty is incorrect
2) Your measurement is incorrect
3) Your measurement equipment is faulty
4) Your measurement procedure is faulty
1 and 2 are most often typos on your part, and are easily corrected. 3 and 4 are system issues that MUST be addressed in some way prior to your next 17025 audit, and would ultimately require a corrective action.
Also, the .pdf posted above is a good calculation reference. I recommend saving it for your convenience.
I hope this helps someone save some time and heartache!
Thanks to MotorCityQuality for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Calibration Service Suppliers refuse NIST reference numbers on C of C aavtqa General Measurement Device and Calibration Topics 21 20th May 2014 07:46 PM
Reference Numbers or Titles for a Nonconformance Report? Rachelly Nonconformance and Corrective Action 6 10th January 2012 01:28 PM
Application of IAF MD 5 - Clause 2.3 Effective Number of Personnel Velika Auditing Discussions 14 4th November 2010 07:37 AM
21 CFR 820 - Missing Numbers - I have a reference to 820.84 Debbie Kerr 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4 7th November 2008 11:07 AM
Automotive Headunit Sizes - Standard Numbers - DIN size with No Document Reference Manix Other ISO and International Standards and European Regulations 2 11th August 2006 04:40 AM
The time now is 12:19 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
