Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
18th August 2008, 09:28 PM
Registration Date: Feb 2007
Karma Power: 26 Karma: 10
Fish Oil Capsule Weight MSA (Measurement Systems Analysis)
Hi everyone:
I am Sidit and I am new in Quality and in Forum too.
I am trying to do a MSA for capsules weight It is a destructive test and I don't know which capsules to select for weigh.
Capsules are produced from two rotating dies with a capacity of 240 capsules in one minute
18th August 2008, 11:24 PM
Registration Date: Apr 2002
Thanks Given to Others: 555
Karma Power: 389
Re: MSA for fish oil capsules
Why is weight a destructive test?
If you have access to the AIAG MSA 3rd edition manual, there is a section on destructive MSA. I need more information to better assist you. There are several possibilities for destructive MSA that depend on the actual situation.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
19th August 2008, 08:10 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
In Reply to Parent Post by Miner
We'll wait for more input from the OP, but I'm guessing it's "destructive" in the sense that the capsules, once removed from a controlled production stream, are intact but no longer saleable.
We aim to please. You aim too, please.
19th August 2008, 07:15 PM
Karma Power: 389
Re: Fish Oil Capsule Weight MSA (Measurement Systems Analysis)
You may be right. However, from an MSA perspective that is not destructive and the standard crossed method may still be used even if the capsules cannot be sold.
19th August 2008, 08:10 PM
Forum Administrator
Registration Date: Dec 2005
Thanks Given to Others: 1,471
Karma Power: 400
In Reply to Parent Post by sidit
Hi everyone:
Fish Oil capsules will be categorised under Dietary supplements and you need to have a look at the pharmacopeial requirements. For eg, USP (United States Pharmacopeia) has a section <2091> on Weight Variation.
Pl ensure that those requirements are met first.
Well done is better than well said - Benjamin Franklin
19th August 2008, 09:05 PM
Sidit
Thank you for trying to help me with fish oil capsules MSA. It is my fault that I wasn't clear in explaining the process of weighing.This process consist in weighing first the entire capsule and than destroy it and merge in alcohol to remove the remaining fish oil. The difference between the weight of entire capsule and the shell weight is the fill weight.Fill weight has a tight tolerance and even we use an accurate scale we might be unaware that we have gone out of specifications.
19th August 2008, 10:42 PM
Karma Power: 389
See Measurement System Analysis and Destructive Testing. If consecutive samples are homogeneous in weight, a nested MSA study as described in the article should work for you.
25th August 2008, 06:01 PM
I read the MSA and destructive testing that you recommended
I am still uncertain what method to use, Crossed or Nested Anova
If I consider a batch all capsules produced by one row or further more by one pocket this will be a very large batch and we can consider this batch homogeneous, So I can use crossed Anova instead of Nested. I am not sure
Forum Posting Settings
