Elsmar Cove Quality DiscussionsHow Can I Create a Bell curve in Excel 2007The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
2007, bell curve, microsoft excel .xls .xlsx spreadsheet
Reply
  Post Number #1
Old 21st August 2008, 05:44 PM
bbrandon's Avatar
bbrandon
Please Help! How Can I Create a Bell curve in Excel 2007
I need some help can someone show me how to create a Bell curve that contains the following information in the attachment that I have posted, I have not done this before. I have attached my data to the post. I have excell 2007 and I can not figure out how to create a bell curve with this data or how to set it up. Very confusing. Can someone help me or show me how to do it.
Thank you
Brian
Attached Files: 1. Scan for viruses before opening, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Sponsored Links
  Post Number #2
Old 21st August 2008, 05:54 PM
Stijloor's Avatar
Stijloor
Re: How Can I Create a Bell curve in Excell 2007
In Reply to Parent Post by bbrandon View Post
Thank you
Brian
Brian,
I did an advanced search on: "Normal distribution in Excel."
Look and see if there's some info you can use.
Stijloor.
  Post Number #3
Old 21st August 2008, 09:17 PM
Tim Folkerts's Avatar
Tim Folkerts
Brian,
There are two challenges before even getting started with fitting a bell curve to the data.
* The data does not seem to follow a bell curve to begin with. There is perhaps some slight rise in the middle, but there are larger variations from one bin to the next.
* The bins are different widths. The narrowest bins are about 1/3 the width of the widest bins. This would naturally put more items into the wide bins (although that does not necessarily be the case in the actual data). Figuring out how to properly fit a bell curve in that case will be CONSIDERABLY more difficult than if the bins are the same width.
Tim F
P.S. I am assuming that the "OD Size" is the way you are sorting the items (the 'bins') and the "Footage" is how much you got of that category.
  Post Number #4
Old 22nd August 2008, 04:57 AM
mclaubee
If you just want to "draw" a bell curve, you may try to add a 4th or 5th order polynomial trendline to you data.
  Post Number #5
Old 22nd August 2008, 09:22 AM
bbrandon's Avatar
bbrandon
Re: How Can I Create a Bell curve in Excel 2007
Thank you for quick responses, it did shine some light on the issue. Does any body know where I can locate the Analysis Tool pack to be loaded.
  Post Number #6
Old 22nd August 2008, 08:00 PM
S Johnson
Try "Tools", "Add Ins" and select it from the list. I think it is built into all Excel Programs, but it must be added using the Add In menu.
  Post Number #7
Old 26th August 2008, 03:12 AM
sathis's Avatar
sathis
Thumbs up Re: How Can I Create a Bell curve in Excel 2007
Hi
Attaching a write up on " Excel For Statistical Data Analysis"
Hope this helps
Sathish
Thank You to sathis for your informative Post and/or Attachment!
  Post Number #8
Old 15th February 2009, 08:00 PM
bobdoering's Avatar
bobdoering
I guess my question is what is the process? Maybe it should not fall into a normal distribution. Just seeing the term "O.D." makes me suspicious....
Sawtooth curve in a bell shaped hole? Doesn't fit...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
How can I add a Normal Distribution Bell Curve to an Excel Histogram? Manix Excel .xls Spreadsheet Templates and Tools 20 14th August 2014 12:36 PM
What is the formula to create a bell curve? mi06rasja Excel .xls Spreadsheet Templates and Tools 8 26th July 2013 06:47 PM
How to create Drop Down Box in Excel 2007 amariepsu Excel .xls Spreadsheet Templates and Tools 2 11th July 2011 08:12 PM
Process capability worksheet - how to create the Bell Curve? Mezzaluna Capability, Accuracy and Stability - Processes, Machines, etc. 6 5th November 2007 12:53 AM
Help me make a normal bell curve on my histogram Indul Statistical Analysis Tools, Techniques and SPC 1 26th July 2005 01:28 PM
The time now is 01:36 AM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
