Go Back   The Elsmar Cove Forum > Aerospace and Aviation Requirements > Federal Aviation Administration (FAA)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th August 2008, 01:51 PM
jameslaz jameslaz is offline
Involved in Discussions
Registration Date: Jan 2008
Thanks Given to Others: 15
Karma Power: 8
jameslaz has less than 100 Karma points so far.
Please Help! PMA Approval Based on Test & Computation OEM Requirements
I am developing a new PMA based on Test and Computation and I have a question about the OEM parts used for testing. FAA order 8110.42C, Chapter 2, 6 Special Requirements for Test and Computation Applications, b, (1) Comparative Test and Analysis states “Side-by-side testing of proposed and original parts with zero service time”. That is a fairly clear statement that would infer a new OEM part must be used fro comparison. Then the same order under Chapter 2, c (1) Sample Size states “Sampling used parts may provide some characteristics that do not deteriorate during use, such as material composition, grain size and grain flow”. My problem is some of these parts are extremely hard to come by, is there a precedent for the use of used parts for dimensional inspections for reverse engineering. If I have a used OEM part that is not altered by time installed would it be acceptable to use such a part for dimensional checks on any detail of the part that does not wear.
PMA = Parts Manufacturing Approval (FAA approved replacement parts).
Thanks you for any help,
James
Last edited by Wes Bucey; 26th August 2008 at 10:32 AM. Reason: substituted "precedent" for "president" for clarity
Sponsored Links
Old 25th August 2008, 05:43 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default Re: PMA Approval Based on Test & Computation OEM Requirements
Originally Posted by jameslaz View Post
I am developing a new PMA based on Test and Computation and I have a question about the OEM parts used for testing. FAA order 8110.42C, Chapter 2, 6 Special Requirements for Test and Computation Applications, b, (1) Comparative Test and Analysis states “Side-by-side testing of proposed and original parts with zero service time”. That is a fairly clear statement that would infer a new OEM part must be used fro comparison. Then the same order under Chapter 2, c (1) Sample Size states “Sampling used parts may provide some characteristics that do not deteriorate during use, such as material composition, grain size and grain flow”. My problem is some of these parts are extremely hard to come by, is there a president for the use of used parts for dimensional inspections for reverse engineering. If I have a used OEM part that is not altered by time installed would it be acceptable to use such a part for dimensional checks on any detail of the part that does not wear.
James
Tests and Computations is a difficult route to PMA. I suggest you discuss your plan with the Aircraft Certification Office (ACO). You may want to engage the services of a Designated Engineering Representative (DER) as well.
Al
Thanks to Al Rosen for your informative Post and/or Attachment!
Sponsored Links
Old 26th August 2008, 08:53 AM
andygr's Avatar
andygr andygr is offline
Registered Visitor
Registration Date: Mar 2006
Thanks Given to Others: 5
Karma Power: 37
andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.andygr is appreciated, and has over 700 Karma points.
Chapter 2, c (1) is covering part features that are constant over time with a design. Metal Alloy does not change, HT condition the same. They drive the zero time requirement to ensure that there is no posability of any degradation for any reason from what they classify as a New part. The same emphisis applies to the issuing of the 8130-3 for a new part.
You will have a hard time to objectivly show that you have validated to a approved type design if you can not show that you used a "new" part (and of course do not have access to the approved design data so can not validate to that).
Keep in mind that the current owner of the design is going to defend their market make sure that these types of concerns are put forth to the FAA.
A long shot but you can try a freedom of info request for the data from the FAA.
Reply
Bookmarks
Tags
faa, parts manufacturing approval (pma)
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
PMA Test and Computation Question - FAA order 8110.42C Chapter 2 section 6 b jameslaz Federal Aviation Administration (FAA) 3 1st July 2009 12:06 PM
PMA (Premarket Approval) - Will inspection of Component Manufacturers occur? jscholen Medical Devices (21 CFR part 820) 1 4th November 2008 07:14 PM
PMA (Parts Manufacture Approval) Dimensional Inspections jameslaz Federal Aviation Administration (FAA) 6 23rd July 2008 06:29 PM
PMA (Parts Manufacturer Approval) FAA Submittal jameslaz Federal Aviation Administration (FAA) 7 15th July 2008 10:01 AM
Approval For Standard OEM Parts - I am never quite sure how we should submit approval SMcD Customer and Company Specific Requirements 3 17th June 2003 09:55 AM
The time now is 03:23 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
