Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
2nd September 2008, 12:56 PM
Involved in Discussions
Registration Date: May 2008
Thanks Given to Others: 44
Karma Power: 28 Karma: 31
Internal Audit - Process based vs. Procedure based
When conducting internal audits we have used AS9101. Our auditor tells me that we need to use a process based audit procedure - not audit to standard requirements. I was hoping I could get some help on how you conduct this type audit. Does anyone have a process based audit checklist?
2nd September 2008, 12:59 PM
Forum Administrator
Registration Date: Sep 2006
Thanks Given to Others: 1,302
Karma Power: 400
Re: Internal Audit-Process based vs. procedure based
 I changed the title for clarification. Let me or another moderator know if you would like it re-worded.
Now, 75 years later in an abundant society where people have laptops, cell phones, iPods and minds like empty rooms, I still plod along with books. ”
—Harper Lee
Thanks to BradM for your informative Post and/or Attachment!
2nd September 2008, 01:20 PM
Registration Date: Jan 2004
Thanks Given to Others: 2,980
Karma Power: 612
In Reply to Parent Post by ValleyGirl
To make my audits process based, I make special checklists for each process based on the procedures, and use "Plan-Do-Check-Act" as a basic framework for asking questions. I ask about inputs, activities, improvements, how success is understood, how corrections are done, specific controls, and the essentials like awareness and communications.
Sometimes I use a turtle diagram and make a process flow chart.
I don't post checklists because using them too often steers the auditor back to what amounts to inspection versus true process auditing.
"If you only have a hammer, you tend to see every problem as a nail." Abraham Maslow
Thanks to Jennifer Kirley for your informative Post and/or Attachment!
2nd September 2008, 02:10 PM
Registration Date: Jun 1999
Thanks Given to Others: 47
Karma Power: 895
1st...he would need to show me a solid "shall"
But....What type of process is he referrining to? If one carefully and objectively looks at the requirements of AS9100 (basically ISO 9001 on steroids) one would see that every requirement from 4.1 to 8.5.3 has the needs for input, creates an output and does something in between (oh my gosh, that's the definition of process  )
As for a process checklist.........never happen. Why? Because the process most likely being referred to is that of "YOUR" system and organization so any checklist must be tailor made for you and you alone.
This isn't rocket science...I know because I worked with rocket scientists at Aerojet and Northrop Grumman and they didn't do this. Simply identify what it is you do (or in this case want to audit), what are the necessary inputs, what are the desired outputs, how do you make it all happen, and how do you monitor or measure everything to show effectiveness of the whole mess. Then just get the evidence that it is occuring as planned. TA-DAAAAAAAAAAAA! Process Approach.
Take something simple like the document control process.........break it all down (maybe use a Turtle to help) and go for it.
We who have seen war, will never stop seeing it. In the silence of the night, we will always hear the screams. Joe Galloway
Thank You to Randy for your informative Post and/or Attachment!
2nd September 2008, 05:10 PM
$ Contributor
Registration Date: May 2004
Thanks Given to Others: 108
Karma Power: 101
When my organization started to wean itself from clause based (like AS9101) to process based audits we used sticky notes. First two notes contained the input and output information. We then went through our process documentation and wrote short to the point statements about what was required of the process referencing the procedure number and paragraph number.
After completing this exercise we then grouped together stick notes with similar requirements and then created simple flow chart combining the similar requirements into even more simplified to the point statements that we use to audit the process.
As we gained experience with process based auditing we moved away from creating flow charts and now follow a standard format which we complete. Our format consists of ten informational boxes which are group as follows:
Process Name
Process Owners
Top Level Control Procedures
Sub-process Procedures
Key Personnel
Inputs to Process
Summary of Process Steps
Output from the Process
Next Step in the Process
Documents and Records Reviewed By the Auditor.
This standard format is used to collect audit information that we use to complete the audit report and it is not retained. When a process procedure changes we update this information for the next audit of the process.
Thanks to Jeff Frost for your informative Post and/or Attachment!
2nd September 2008, 05:18 PM
Registration Date: Feb 2005
Thanks Given to Others: 4,002
Karma Power: 773
Re: Internal Audit - Process based vs. Procedure based
Your auditor did you a favor! AS9100 internal audits aren't clause or element based. Since AS9100 is ISO 9001 based, internal audits should be process based.
You are going to be auditing a process-based qms, so you should - as we've posted here countless times - not be auditing to the standard, but auditing what your qms descriptions are. Hence, your planning for your audit should be based on whatever your process documentation says, plus some other considerations like customer requirements, FAA regs etc. Throw in there the organizations own objectives etc. for the process, plus its current performance and we might be humming........
Take a look in the attachments for my audit 'football' (Randy forgot to mention it - he's an animal lover) and see if that helps you.......
'Cause you know sometimes words have two meanings.....
Thanks to AndyN for your informative Post and/or Attachment!
2nd September 2008, 05:31 PM
Take a look in the attachments for my audit 'football' (Randy forgot to mention it - he's an animal lover) and see if that helps you.......[/quote]
I must know - what do you mean Randy is an animal lover??
I'll take a look at the "Audit Football" attachment.
2nd September 2008, 05:35 PM
Karma Power: 773
I'll take a look at the "Audit Football" attachment.[/QUOTE]
He mentioned 'Turtles'..........
Forum Posting Settings
