2nd June 1999, 11:40 AM
Quality Manual Change History - Can I eliminate the revision record from the manual?
The ISO standard states that the changes to the Quality Manual should be available for review by the use of attachments or visible on the page itself "where Practicable". My quality manual INCLUDES all of the quality system SOP's as part of the manual and each time one of these is revised it must be reflected on the change record page of the manual. My question is this "can I eliminate the revision record from the manual itself and keep all changes available for review in my Change Notice files (ECO's)?" Any change as in the past needs to be approved through the document change system anyway and the revision record in the manual is redundent!
2nd June 1999, 12:59 PM
Hmmmm, interesting question. I would say that you should talk with your registrar. I would think that the revision record is not optional. Even if it were, I would keep it anyway. It never hurts to CYA.
Then again, I'm a packrat
2nd June 1999, 04:10 PM
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Mark,
I believe that this is a personal preferrence your documentation person must make (perhaps you). I keep a database online with changes made to documents under control. As my personal preferrence, I keep the change details separate from the details I want the reader to read and act on. Reduced clutter and increased understanding I think.
Regards,
Kevin
2nd June 1999, 09:56 PM
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0 Karma: 40
I don't put revisions in the manual. I only reference the SOP number. This number never changes regardless of how many revisions we go through. The SOP table of Contents states the revision. Hope this helps.
3rd June 1999, 01:17 AM
In our manual we footnote the latest revision only, and refer to the files for a full revision history. In our opinion it is both impractical and redundant to retain a complete revision history in the manual itself, and our registrar has not had a problem with this.
14th June 1999, 11:10 AM
Why do we keep the record? It's to facilitate the requirement of 4.5.3, paragraph 1, ie; those doing the review and approval (and, not stated but more important, the guy making the change) should ensure that the change does what it is intended to do without diminishing other aspects of the procedure.
So you need to keep it. "Where practicable", put it in the document or attachments. Where this is not practicable, or you have some other method which is more practicable, then do what you like. But be able to explain why. And don't lose sight of the basic intention of the requirement of the clause. (as above)
If procedures are to be good, they should state the important thing, not the obvious or mundane thing - we'll manage that anyway. The most important thing, when changing a procedure, is to understand how and why the procedure got to be the way it is. Otherwise you may be re-introducing problems already eliminated or undermining basic principles behind the design of the original procedure.
To make the information easily accessible helps ensure it is used. To document the need and (if necessary) say where the information is available, is a simple, but critical piece of documentation. Show this and explain it and no registrar can have anything but respect for the way you deal with the issue.
rgds, John C
22nd June 1999, 03:44 PM
I never, ever, ever, ever, ever, ever show the "nature of the revision" within the documents of our Quality System.
Our docs simply detail the revision level of the document. If anyone, including a registrar wants to see the revision history, they can page through my book of DCO's (Document Change Orders) which contain the change request and details, and a marked up copy of the previous version (appropriately labeled as OBSOLETE).
I have never had a problem with our registrar(s).
ALM
22nd June 1999, 10:19 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
If a rgistrar asks for more than that they should be challanged.
