Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
31st July 2000, 08:15 PM
Work Instructions 4.9.1 - Work instructions must be readily accessible
We have recently incorporated a "paperless" system for our QS program. Element 4.9.1 states that the work instructions must be readily accessible at the work station without interrupting the work. Would we meet this requirement by having our work instructions available through our paperless system with the supervisor of each department able to print the work instructions if the employee requested them? We still have the hard copy of the work instruction for each department on the information board within each department. The employee must go to that board and get the hardcopy if they want to read them. What does the phrase "work station" actually mean? Can we define the work station as the computer that the supervisor uses to cover this issue and remove all hard copies of work instructions from our facility? Will we meet the intent of "at the work station" if we don't have individual copies of the work instruction at each machine? Your comments are welcome!!
1st August 2000, 11:12 AM
An Early Cover
Registration Date: Mar 1999
Karma Power: 0 Karma: 25
Our auditor indicated that if the employee had to leave his workstation (the place he performed his work), to view a work instruction, it did not meet the standard.
His feelings were that going to another location, no matter how close, would negatively affect productivity and be in violation of the standard.
1st August 2000, 11:32 AM
Tom is correct, this issue is more than just the auditor's interpretation. This topic was defined in a (one of the first) Sanctioned Interpretation. The auditor made the right call.
1st August 2000, 06:28 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,443
Karma Power: 400
If you are currently not keeping 'work instructions' at the work station, there must be a reason. Often companies train their employees such that work instructions are not always necessary - employees only reference them if they have a question. I have done several implementations where there were no work instructions at any station. None were necesasary.
I suggest you take a step back and ask yourself what you are defining as work instructions and when operators use them.
I went thru an ISO (!) registration back in 1997 where the auditor complained because work instructions were not 'readily' available because the operator had to turn around to see them. The operators faced an assembly line standing up. Assemblers were on either side of the line. The auditor said it would be acceptable if they posted work instructions on the opposite side of the line so the assemblers didn't have to turn around.... Never mind the fact they would have to walk across the line to the other side to be able to read them, that people were working opposite them who blocked the view from time to time, etc.
Before you run out and change your system, ask why you don't currently have them at the individual work stations. Apparently the operators do not use them all the time. Why not? When do they use them? How often?
This is not a black-and-white issue. But - the 'work station' is where the work actually takes place.
More info about the process (Assembly? Lathe? Paint? Metal forming press?) would help a lot if you want more detail.
[This message has been edited by Marc Smith (edited 01 August 2000).]
3rd August 2000, 09:22 AM
E-Mails Invalid or Rejected by Recipient System
Registration Date: May 2000
Karma Power: 0 Karma: 10
The company I am currently working for has there operator instructions, machine settings, packing plan etc. all printed out automatically with the workorder. so when the workorder is taken into production there is a instruction readily available.
Thing is that those few pages don't weight up to having someone leaving his workspace, communicating his/her problem, retrieving the operator instruction and than walk back. This would take so much time on the long run.
I must say that a automatic process that doesn't need a operator maybe shouldn't have all instructions but what could those 4-8 pages matter in a facility. For instance if a Workorder runs for 6 days and has a 6 page workinstruction we utilize 10 machines that is 10 pages a day. one copy screw-up takes more than 10 pages and if it helps the product quality.... I would just post them on a clipboard or have them readily available on a MES terminal.
3rd August 2000, 11:47 AM
Tom, what did you do with your Work Instructions? I know you have a paperless system for the Procedures, are you using the same system for your Work Instructions? What software are you now using? Perhaps these questions belongs in the 'Quality Assurance Software' forum instead of this one, oh well.
4th August 2000, 12:46 AM
An Early Cover
We actually have very few formal work instruction documents. Those that we do have are located at the work station where they are used.
We rely on the training and skills of our employees as they build our product from the drawings, wiring diagrams, schematics, etc. These documents, which are delivered with the shop paper to the floor, are the "work instructions" which the floor uses.
Our "paperless" system is nothing more that a read only set of files on our computer network. I did have them in an Outlook folder, but a drive on the network which everyone has access to proved to be more accessible. There are terminals scattered throughout the shop from which all employees have access should they need to access the documents, and I am out on the floor everyday, so I am available to answer questions that might come up.
Tom Goetzinger
4th August 2000, 09:12 AM
We use a system similar to Tom's in that we have very few written work instructions. We use blueprints to the latest revision level and the approved first piece sample as our basic work instructions in our processing, welding, paint and assembly departments.
Jim
[This message has been edited by Jim Evans (edited 04 August 2000).]
Forum Posting Settings
