30th October 2008, 11:32 PM
Getting Involved (6 to 9 Posts)
Registration Date: Oct 2008
Thanks Given to Others: 17
Karma Power: 5 Karma: 10
Should we make acceptance specification looser than customer’s specification?
The situation in our company is like this:
Customer gives us a lot of drawings. We forward the drawings to our suppliers and tell them to make parts according to the drawings. Suppliers agree.
The problem is: every time the parts sent by the suppliers have a large proportion (60% ~100%) that exceeds the tolerance limit. We accept them as concession each time because we conclude the suppliers don’t have the capability to meet the specification requirements. Besides, the parts, although exceeding tolerance limit, fit the assembly quite well. The customer, knowing the parts exceed tolerance limit, accept the finished product each time as concession.
Because it is common knowledge that we can not use the specification on the drawing to decide the acceptability of the incoming parts, each time we let QC inspectors do a preliminary inspection according to the drawing, then write a Discrepancy Report, then we let Quality Engineers do a second inspection on the defectives found, and make a judgment whether they can be used or not according to their manufacturability.
This process, of course, is wasteful, so I proposed to the quality manager that we should make incoming material inspection instructions for each part (currently they don’t exist), and the acceptance criteria on the inspection instruction should be slightly looser than the one provided by the customer’s drawing, so that the incoming parts can at least meet the tolerance requirements on our inspection instruction, although may not meet the tolerance requirements on the customer’s drawing.
My supervisor strongly opposes this idea, insisting that we can not change any customer specification. I argue that we do not change customer specification; we just change our specification, to make it closer to our actual capability. My supervisor disagrees, because our specification derives from customer’s specification.
What is your opinion? Any opinion is appreciated.
31st October 2008, 06:58 AM
Involved in Discussions
Registration Date: Sep 2007
Thanks Given to Others: 40
Karma Power: 24
Re: Should we make acceptance specification looser than customer’s specification?
It would seem to me that the tolerances were set too tight at the design stage. If the out of specification product is accepted every time without fail - that would sugest the tolerances permitted could be relaxed (assuming this doesn't have an impact further down the line) and that the manufacturing process wasn't taken into account when the customer designed the product (or you should change to a supplier who can meet the capability requirements)
I would have thought justifying a looser inspection criteria than the customer specified would be tricky at best in the event anything went wrong.
Have you discussed a drawing change with the customer? changing the drawing would ensure everyone was singing from the same sheet as it were & would avoid any complications later on.
Thanks to achorste for your informative Post and/or Attachment!
31st October 2008, 08:40 AM
Registration Date: Jan 2008
Thanks Given to Others: 8
Karma Power: 9 Karma: 65
Customer requirements are king - what they want, you deliver.
If the customer requirements are in reality so loose that they continually sign off concessions to accept parts with wider variations than the drawings state, then get this agreement formalized either permenatly through a change to the drawing or a by a process deviation (a limited in scope (by time, quantity or order number), pre-agreed concession). - If they suddenly get a new QA guy who sees things more black and white, you could be sitting on a hell of a lot of inventory which you cant sell and which you may struggle to get your suppliers to remake/rework
Or get better suppliers who are capable of building what you require.
It sounds like you should also be engaging in some DFM work with your customer to ensure that what they are asking is physically possible - there are potential cost savings for you, your customer and your supplier if they ask for what they actually need
Setting your own acceptance criteria lower than your customers has a huge potential come come back and bite you on the behind. It's just WRONG.
Thanks to Pistonbroke for your informative Post and/or Attachment!
31st October 2008, 08:50 AM
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
contract review.
Can you supply it? then do it and do it right. if you cannot supply it then enter into negotiations or no quote it.
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
Thanks to SteelMaiden for your informative Post and/or Attachment!
31st October 2008, 10:51 AM
Registration Date: Aug 2008
Thanks Given to Others: 236
Karma Power: 176
I don't have any good advice, other that to note that we've been there as well...with a very much larger customer with ponderous and ineffective internal systems, and out-of-date documentation for many of their accessory products. They originally brought these products to us when another vendor dropped the ball for them. Their direction to us was along the lines of "you guys are experts at this stuff, figure out what we actually need and make it, we'll eventually fix the documentation". That was many years ago, and they're just getting around to sorting out their drawings and label specs with our help. That help mostly consists of our sharing our drawings and label specs, which have actually been controlling the products.
At least for us, quality/regulatory consciousness is a means of increasing, not decreasing, sales. Therefore we hypothetically might no-quote a job if we thought a customer had actual devious intentions regarding regulatory requirements, but we don't no-quote jobs just because a customer's quality competence isn't as high as we'd like it to be. We'd rather take the work, help them meet their customers' requirements, and do our best to nudge them in the right direction with regard to compliance.
Thank You to MIREGMGR for your informative Post and/or Attachment!
31st October 2008, 03:07 PM
Karma Power: 255
Ah, but see, you are entering into negotiations.
31st October 2008, 03:14 PM
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Such a good discussion so far.
You can't change the customer specifications. No-no-no.
Nor can you make your specifications different and pass what I call the Straight Face Test.
You can, however ask for a waiver of specific requirements. Once permission to deviate from spec is received, it can be kept on file and your manufacturing tolerances set to match. The waiver would be expected to have an expiration point, or else a statement that it does not expire.
Stealth quality versus no quality
Thanks to Jennifer Kirley for your informative Post and/or Attachment!
31st October 2008, 04:37 PM
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 657
Karma Power: 191
Talk/communicate to your customer. That is the first thing that you need to do. Ask them to increase tolerances.
Give them the data that you have on:
1. the quantity rejected
2. the quantity they have accepted via a concession
3. recommend that they increase the tolerances since apparently it doesn't affect form, fit, or function or they wouldn't be accepting them via the concession.
One question though, why would you go to a supplier that is not capable of meeting the tolerances?
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
Thank You to Coury Ferguson for your informative Post and/or Attachment!
