Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > Other ISO and International Standards and European Regulations
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st November 2000, 03:21 AM
Vash Stampede
Unregistered Guest
Posts: n/a
Question What is in an ESD Check List?
What are ESD Checklist? Is it really included in this element? Two months ago, were been audited by one of our customer, and they were asking on how do we specifically check our ESD groundings and etc. Does this ESD checklist determines and make use on how do we audit some items for the ESD, e.g. on Protective flooring, smocks, shoes and the like? Please comment.
Thanks in advance.
Vash Stampede
Sponsored Links
Old 21st November 2000, 10:59 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
An ESD check list? Just like any other checklist... alist of requirements to verufy.
There is a mil standard/handbook that details requirements for ESD sensitive material. You (your cusromer?) determine the level required for your product by design/reliability etc...IF you have to ask, it probably isn't very ESD sensitive??? What is the product and its typical uses?
The levels range from a grounded work site to a full system with deionizers and conductive flooring.....same goes for material used in the system....ESD dissapative to insulating...so the check list would vary accordingly.
There is a book out there (saw it at Barnes and Nobel and ASQ publications) called Auditing Cleanroom and ESD programs. Its about $25 and is a good resource...BEWARE..not all companies need to adhere to all the requirements !!!!!! As a matter of fact.. MOST need very little.
Typical minimum requirements could be a grounded worksite and equipment, verified periodically. A personal ground strap verified daily. And a work site 12 inches around the product clear of static generating stuff. Protective transport containers (as in a faraday cage?) and shipping material. And lets not forget warning labels......to remind everyone of the use of caution?
So the check list may say. What is the evidence of grounded workstations? How often are they verified? How are they verified (traceable to NIST?)? By whom? How was he/she trained? Is there an ESD training program? ARE the operators working current to this training? Do operators check their straps daily? What is the evidence? Pull a sample list of operators from the worksheets....are they checked in on the days they performed the work? Are packaging materials ordered to a specification? Are they verified? Is material that is reused verified periodically to see that the integrity of protective coating is still valid? Are ESD sensitive packages clearly labeled? Any scotch tape, general plastic/ cellophane at the work station? Styrofoam? Eating/drinking? Nylon clothing? Is material moved within an enclosed package? And so on.....
Any specific concers....ask away...one of my "training course offerings" so I won't be too far off base....
But again I caution you....impose only what is necessary for your product.
go to "http://esda.org/pdf_files/s2020std.pdf" for a free download
[This message has been edited by barb butrym (edited 21 November 2000).]
Sponsored Links
Old 21st November 2000, 07:04 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
1. Ask the customer involved what systems and checklists they have with regards to Electro Sensitive Devices. If they don't handle printed circuit boards (PCB) directly, they won't have anything either.
When I was working with the US Air Force they had reg's and checklists for all this stuff. Check out their websites.
If you buy you PCBs, you should be asking your suppliers how they handle this topic. (this may even be why your second party audit was conducted in the first place - who knows?)
Electronic Engineers - If your manufacturing with PCBs you must have at least one kicking around the place who can set you on the right path. If not, (last resort) you could always get a consultant in who could assess the risks and advise on elimination/reduction strategies.
Old 21st November 2000, 09:24 PM
CJacobsen
Unregistered Guest
Posts: n/a
Default
You should be able to find everything you wanted to know about ESD from this page:
http://www.reade.com/Safety/esd.html
After the text at the top there quite a few links at the bottom.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ESD Training - Meeting ISO 9001 & ANSI/ESD 20.20 Icy Mountain Training - Internal, External and Distance Learning 7 22nd May 2007 01:13 PM
Quality Audit Check List needed Reggie Documentation Control Systems, Procedures, Forms and Templates 2 15th September 2006 05:16 PM
Can anyone help with ESD Protection (PCBA)? How is ESD generated? Phil mil std Inspection and Test, Sampling and Related Topics 8 1st March 2006 10:45 PM
ESD Work Instruction or ESD Process Flow Chart - Seeking example Barbara Various Other Specifications, Standards, and related Requirements 5 29th January 2006 12:38 AM
The time now is 05:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
