Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Definitions, Acronyms, Abbreviations and Interpretations
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 2nd May 2001, 12:47 PM
qaadrian
Unregistered Guest
Posts: n/a
Question Out of Tolerance (OOT) Condition - What is an Out of Tolerance Condition?
We are having a 'spirited discussion' about what constitutes on out of tolerance (OOT) condition for the calibration of customers standards and equipment. As QA I say it's any condition that does not meet the customers contractual requirements, or pass our calibration procedure. This is generally agreed to except in the case when the equipment is in operative. If its inoperative, then some people say its not an out of tolerance condition. Where can I find a clear definition for OOT? I'm interested in learning about other peoples views on this topic. Thanks for the feedback.
Sponsored Links
Old 2nd May 2001, 06:32 PM
Al Dyer
Unregistered Guest
Posts: n/a
Question
I guess I need to ask, how does your group define non-operational and if you are talking about a gage being non-operational?
As an example, on occasion we take perfectly good gages out of circulation and tag them as "idle".
Is it operational? I guess it depends on the wording in your system documentation.
As for out of tolerance, your right on the mark.
Maybe some more examples from the Cove Group?
ASD...
Sponsored Links
Old 2nd May 2001, 09:12 PM
Dan Larsen
Unregistered Guest
Posts: n/a
My two cents...
"Out of tolerance" would be unable to meet the customer requirements (defined contractually). I'd be careful about using "my own" tolerances to define out of tolerance. In fact, ISO 17025 prohibits the cal service from making a judgement call of "in" or "out" unless the customer has requested this.
As for inoperative, I guess you could make a case for the gage being OOT; if it can't be used to measure, then it can't measure within the tolerance. In effect, the "as found" would be OOT. However, as a calibration consumer, I think I'd prefer the "as found" to show "Damaged" or "Not Operative" instead of "Out of Tolerance". The statement that the gage is damaged may help me in validating a review of previous results.
Old 2nd May 2001, 09:42 PM
qaadrian
Unregistered Guest
Posts: n/a
Sorry, I should have been a bit more specific. We calibrate electrical equipment for customers. We don't have a definition for "non-operational" because not everyone can reach a consesus (its a stubborn group). Thats why I say if you can't take a reading, then it's OOT. Good point about making judgements. We are going to 17025 in the near future. Last bit of info: I did grant certain exceptions - if a fuse is blown or the battery is dead or if it's a typical user function/adjustment, then it's not an OOT. The tech is allowed to fix the problem and then proceed with taking As Found data. Thanks for the feedback so far. I hope I can get a couple more points of view.
Old 3rd May 2001, 11:19 AM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
I have a question - if the unit is inoperative, how can you call is out of tolerance? If it doesn't work, how can you check it against a standard? We work with standard measuring equipment, i.e. micrometer, calipers. If a set of calipers is dropped, or the gears become jamb, we repair the unit and then subject it to a full calibration.
And for Dan - is your 2 cents worth adjusted for inflation and/or the rising porice of fuel??? LOL
CarolX
Old 3rd May 2001, 10:50 PM
Dan Larsen
Unregistered Guest
Posts: n/a
To CarolX...
I generally make it a point to gas up BEFORE a trip to Chi Town. It doesn't save a lot, but it gives me a few extra cents to spend on the Illinois lottery! (I figure you Flatlander's have pulled enough of out of Wisconsin...it's MY turn! )
Old 4th May 2001, 11:46 AM
CarolX's Avatar
Karma Power: 176
Dan...
LOL!!!!
Shall we confuse the rest of the contributors with a Flatlander vs Cheesehead debate??????
Have a good day!
CarolX
Old 4th May 2001, 12:53 PM
qaadrian
Unregistered Guest
Posts: n/a
Thumbs up
Appreciate all of the feedback. I've decided to define, in writing, "Inoperative" and "Out-of-Tolerance" conditions for the lab using their suggestions. Basically, if you can't perform the cal, it's inoperative. If you can do the cal and the results do not meet the customers or the calibration procedures acceptance criteria, it will be an OOT. Of course, the final decision rests with the customer. Have a good weekend everybody.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Thermoplastic Elastomer Tolerance Table - ISO 3302 / RMA tolerance question QMMike Other ISO and International Standards and European Regulations 2 6th November 2009 01:07 AM
Root Cause Condition / Corrective Action Condition LexieB Problem Solving, Root Cause and Failure Analysis 2 18th September 2009 05:20 PM
Gage R&R Total Tolerance question - Use the full process tolerance? 02SCvette Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10 4th August 2008 11:18 AM
Determination of M&TE out of tolerance condition and what to do when found Charles Wathen ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 16th April 2004 04:55 PM
Out of Tolerance Condition - Definition of *Significant* Out of Tolerance Condition MRagman Definitions, Acronyms, Abbreviations and Interpretations 2 15th May 2001 10:49 AM
The time now is 06:35 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
