Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
5th December 2008, 05:39 PM
Involved in Discussions
Registration Date: Jul 2008
Thanks Given to Others: 5
Karma Power: 22 Karma: 10
Validate 99.5% reliability 90% confidence - Sample size calculation
If I state a component is 99.5% reliable at 90% confidence, I can calculate the sample size needed to validate the R&C target is 460 samples. I would expect to see .5% cumulative failures in the field for the life of the product. Sample size = ln(1-C)/ln(R)
Someone has stated if the test is performed using the 95th percentile usage profile (more harsh usage profile than the median user), then I can validate the same reliability using a smaller sample size. For example, I can use a sample size of 22, to meet 99.5% reliability with 90% confidence if I use a 95th percentile usage profile. I expect .5% cumulative failures in the field for the life of the product?
Are the previous statements correct? Can I reduce the sample size from 460 to 22, and validate 99.5% reliability of the population by adjusting the usage profile?
Calculation:
I test to R90/C90, I need 22 samples.
Population Reliability = 1-(1-95th percentile user)(1-Reliability)
=1-(1-.95)(1-.9)
=R99.5%
8th December 2008, 06:14 AM
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 941
Karma Power: 474
Re: Validate 99.5% reliability 90% confidence - Sample size calculation
Can someone help here?
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
Thanks to Coury Ferguson for your informative Post and/or Attachment!
12th December 2008, 05:03 PM
Willy Grunfeld
Registration Date: Jul 2005
Thanks Given to Others: 18
Karma Power: 55
I never heard of 95th percentile usage profile and don't know what is meant by that. It doesn't sound right to me. The word harsher sugests you are referring to some accelaration factor. Other than temperature which can be used as an acceleration factor and for which the relationships are known I don't know of any acceleration factor that can be used readily.
Assuming that you are referring to accelerated testing, the test time can be reduced or conversely the sample size if the test time remains unchanged. I wouldn't take that formula as correct unless you have the full reference how is it derived. ooks suspicious to me
Willy Grunfeld
RAMSQ Consultant
Thanks to w_grunfeld for your informative Post and/or Attachment!
12th December 2008, 05:18 PM
Willy Grunfeld
Karma Power: 55
"If I state a component is 99.5% reliable at 90% confidence, I can calculate the sample size needed to validate the R&C target is 460 samples. I would expect to see .5% cumulative failures in the field for the life of the product. Sample size = ln(1-C)/ln(R)"
99.5% reliable means there is a 0.995 probability it will fail at time t. You can't "expect" =calculate the number of failures without knowing the failure rate and the time.
90% confidence is just what it sounds- that there is a 90 %probability that the actual reliability will indeed be 99.5% and a 10% chance that it won't.
I don't know where did you take that formula to calculate the sample size....you can't talk about sample size without taking time into consideration. The assumption (for constant failure rate) is that 100 parts operating for 1,000 hours is the same as 1000 parts operating for 100 hours.
Willy Grunfeld
RAMSQ Consultant
23rd December 2008, 10:53 AM
w_grunfeld, Thanks for your reply!
The sample size equation comes from the number of samples for the lower binomial confidence bound, for a zero failure test. The R&C are life targets, and the zero failure test is for 1 life. I should have clarified.
Thanks again for your response!
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Sample Size and Confidence question for Small Sample Size on Large Lots
RMedrano |
Inspection, Prints (Drawings), Testing, Sampling and Related Topics |
8 |
17th March 2008 08:01 PM |
Finding sample size by using confidence level and probability
Nissim Shaked |
1 |
19th September 2006 10:04 AM |
Sample size selection to make sure 95% confidence detectability
rexlee |
5 |
14th November 2005 10:57 AM |
Sample size to determine confidence interval
Benoit |
Quality Tools, Improvement and Analysis |
5 |
21st January 2005 09:38 AM |
Testing for Process Confidence - Sample Size
Mark Smith |
SPC Monitoring and Statistical Analysis Techniques |
3 |
22nd July 1999 10:52 AM |
