| DNV Forum SideBar |
New Threads Feeds
Sponsor Links
10th December 2008, 06:58 PM
Rubber, Too Glamorous?
Registration Date: May 2005
Thanks Given to Others: 53
Karma Power: 20 Karma: 85
Making the Transition to AS9100 Rev C.
I'm revising our internal audit procedure for an improvement unrelated to AS9100B requirements. I see that AS9100C will remove the bold typeface requirements for "Detailed tools and techniques ... " and "Internal audits shall also ... ".
Will our auditor declare a finding if I remove those requirements from our procedure after AS9100C is issued but before we are certified to AS9100C?
I just want to get a head start and not revise the procedure a second time when Rev C is issued.
10th December 2008, 07:43 PM
Involved - Posts
Registration Date: May 2004
Thanks Given to Others: 69
Karma Power: 46
Re: Making the Transition to Rev C.
I would not make any changes to your procedures until you perform a gap analysis between your current Rev. B QMS to the requirements of AS9100C once it has been published. My feeling is that the driver for the your QMS migration should be Top Management via your management review process.
I have not heared of the formal migration plan for AS9100C from my registrar yet but I am sure it will be announced shortly after standards' publication. Having a documented (output from management review meeting) plan, should lessen any concerns your customers or registrar will have as your make your changes to the documentation.
Thanks to Jeff Frost for your informative Post and/or Attachment!
10th December 2008, 10:45 PM
Post responsibly
Registration Date: Oct 2001
Thanks Given to Others: 688
Karma Power: 467
Re: Making the Transition to AS9100 Rev C.
If the audit criteria is Rev. B of AS9100, the auditor will expect to see conformity of the system against that specific version of AS9100.
Fighting organizational dysfunction, one post at a time.
Thank You to Sidney Vianna for your informative Post and/or Attachment!
11th December 2008, 12:02 PM
Involved - Posts
Karma Power: 46
Sidney has a very good point about which revision of the standard would be the audit criteria. It might be better to wait for your next scheduled surveillance audit to occur and then start implementing the migration to Rev. C.
11th December 2008, 04:07 PM
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
You can't be audited, and you will not get registered to something that doesn't exist.
None of us is as smart as all of us...Ken Blanchard
20th January 2009, 11:58 AM
Post responsibly
Karma Power: 467
Recently, I heard of a case where an auditor, by mistake, performed a stage 1 audit against a draft of AS9100 Rev. C. The issue ended up with a complaint to the CB. It is critical that audit criteria is well defined.
22nd September 2009, 07:55 PM
Getting Involved (6 to 9 Posts)
Registration Date: Sep 2009
Karma Power: 1 Karma: 10
(time frame) Re: Making the Transition to AS9100 Rev C.
This may have been answered already....but as i'm new to AS9100 i see that the AS9100C standard has been published and the AS9101D is not available for purchase on the SAE website.
i've come across a timeline frame that indicates company's are to transition within 30 months of implementation. So as a company, although we need to prepare for Rev. C, if we want to get certified by early 2010, can we just go with Rev. B for now and then follow that with Rev. C?
thank you
22nd September 2009, 08:16 PM
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
Re: (time frame) Re: Making the Transition to AS9100 Rev C.
Yes. The only version available for certification in early 2010 will be AS9100 rev B. It appears that the earliest that 9101 rev D could be published is November, so six months from then (May) would be earliest possible certification date for 9100 rev C.
I'm not going to hold my breath for the 9101 release though. It could certainly be delayed further.
