Elsmar Cove Quality DiscussionsHow to differentiate between monitoring and measurement devices?The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
measurement device(s), monitoring device(s), monitoring and measurement, measurement and monitoring and test devices
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 15th December 2008, 08:31 AM
dalezhou
Please Help! How to differentiate between monitoring and measurement devices?
How to differentiate the monitoring and measurement? Also,the differences between the monitoring devices and measuring devices?
Sponsored Links
  Post Number #2
Old 15th December 2008, 10:32 AM
Duke Okes
Re: How to defferentiate the monitoring and measurement?
In Reply to Parent Post by dalezhou View Post
How to defferentiate the monitoring and measurement? Also,the differences between the monitoring devices and measuring devices?
Technically they're the same, but one way to think about it is for a heat treat process an organization would monitor the temperature in the oven, and measure the hardness of the part after it has been treated. However, one must measure in order to monitor, and measuring parts is monitoring how well the process is meeting specs. Semantics.
Thank You to Duke Okes for your informative Post and/or Attachment!
  Post Number #3
Old 15th December 2008, 11:20 AM
CalRich's Avatar
CalRich
Re: How to differentiate the monitoring and measurement?
You may have gages to monitor inputs in your process, (temperature, pressure, time). These help you monitor machine set up. The outputs of the process are measured (with calibrated gages). From your measurements, you determine compliance to specifications.
Thank You to CalRich for your informative Post and/or Attachment!
  Post Number #4
Old 15th December 2008, 01:01 PM
Paul Simpson's Avatar
Paul Simpson
Why would you want to differentiate between the two types?
  Post Number #5
Old 15th December 2008, 01:14 PM
CalRich's Avatar
CalRich
In Reply to Parent Post by Paul Simpson View Post
9001 & 16949 mention both in 7.6, so there must be a need to make the distinction, eh?
Main reason that comes to my mind is to avoid spending money needlessly on controls (e.g. calibration) for items that simply monitor a process. We have some test equipment that uses hydraulics. A pressure gauge is installed, but we don't have it calibrated as it is not related to measurement of the final product. (or even components)
Thanks to CalRich for your informative Post and/or Attachment!
  Post Number #6
Old 15th December 2008, 01:39 PM
Paul Simpson
In Reply to Parent Post by CalRich View Post
Nope! I think you are giving standard writers credit for too much subtlety. The reason for listing 2 types is probably so people are aware that both types have to be managed - there is no distinction written in to standard requirements for how you deal with each 'type' if your 'monitoring' equipment is used to 'measure.'
I'm not sure what your test equipment is doing - perhaps you can enlighten us. Certainly if the pressure gauge is not used as part of a measurement activity then it doesn't have to be calibrated but I'm still not sure what this equipment is doing and how that relates to the monitoring / measuring question.
  Post Number #7
Old 15th December 2008, 01:55 PM
CalRich's Avatar
CalRich
True, the standards mention both to indicate that both have to be managed. Then stated is that, "...where necessary to ensure valid results, measuring equipment shall..." (emphasis added). These requirements do not relate to monitoring equipment.
The equipment has a hydraulic arm that moves in and out for a product-specific destructive test. The pressure gauge is there to monitor the pressure in case it should fail to operate correctly.
Let's say we've making a valve in a factory, and we have to measure the pressure that the relief opens at. We would want to use a pressure gauge as well, but this is a calibrated measuring device.
On the whole, managers should understand what in their process is being monitored and what is being measured, don't you agree?
  Post Number #8
Old 16th December 2008, 02:34 AM
Paul Simpson
OK. Here's the nub. What monitoring equipment is there out there that doesn't measure? I can't think of an example.
So would you class this equipment as monitoring equipment? Are there any criteria for the destructive test that require measurement such as the gauge pressure at point of failure?
Again if the great and good from the cove can give them a steer as what we mean by the two terms then all well and good.
If however they are two catch all terms then we just need to take out the jargon and present managers with a case for each piece of equipment as to what needs to be done.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... pangchiaboon ISO 13485:2016 - Medical Device Quality Management Systems 3 7th January 2015 05:27 AM
8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement morteza IATF 16949 - Automotive Quality Systems Standard 10 5th September 2012 04:30 PM
Maximum Permissible Error for Monitoring and Measurement Devices mickng General Measurement Device and Calibration Topics 19 22nd July 2009 03:33 PM
Including multimeters and network testers as monitoring and measurement devices Ashley Cardin ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5 1st June 2006 03:43 PM
What are monitoring devices? ISO 9001 Clause 7.6 - Control of ... monitoring devices eee ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8 22nd June 2001 03:47 PM
The time now is 01:32 AM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
