2nd November 2007, 12:38 PM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 1
Karma Power: 37 Karma: 70
SAE AMS 2750D - Pyrometry - Heat Treating procedure wanted
Does anyone have a procedure for 2750 D?
Thanks!
James M. Warner
"Workaholic"
2nd November 2007, 12:43 PM
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
Re: AMS 2750 D Procedure
James, unfortunately we generally do not post copyrighted specifications like that here. That way we don't get yelled at too much!
However, if you are performing services for an aerospace company, they should provide you one.
I would also think you could ask your inspector who could get you one.
Brad
My idea of housework is to sweep the room with a glance.
2nd November 2007, 12:47 PM
Courtesy Access
Brad,
I am sorry for the confusion. I was looking for a procedure that was written to address 2750 not 2750 itself. Sorry for not being clear on this. Sometimes I write way to fast!
Thanks!
James M. Warner
"Workaholic"
2nd November 2007, 12:55 PM
Karma Power: 274
Ahh... sorry about that.
If I remember looking at it, I thought 2750D was fairly detailed in itself. What aspects do you feel are not addressed?
Are you looking for like a uniformity/ instrument calibration procedure?
Brad
Registered Visitor
Registration Date: Mar 2006
Thanks Given to Others: 5
Karma Power: 37
James
Since the procedure has to reflect your process and product there is not a single canned one that can work. You can use the AMS to create one if you are familiar with the process. If your are hitting this a bit cold I realy recomend that you take the PRI class on prometry since it will enable you to realy understand why your are doing what is in the procedure.
Trust me when I say that they will expect you to be able to know what you are doing when it comes to TUS and the SAT checks. These are key elements of the audit.
2nd November 2007, 01:39 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Originally Posted by andygr
James
For the sake of ignorant folks like me, what are PRI, "prometry," TUS and SAT?
2nd November 2007, 01:45 PM
Registered Visitor
Karma Power: 37
Since I serve as a VERY GOOD bad example and should have know better
PRI- Performance review institute who administers the Nadcap Program.
SAT- system accuracy test. This is where you show that you instruments are correctly reflecting the temperatures you think you have. This coverers all the various variations in the peices and parts of the system.
TUS- temperature uniformity survey. This is where you demonstrate that the temperatures in all the locations you could place your parts durring processing are with in specification. Basicly makeing sure that there are no hot or cold spots.
Thank You to andygr for your informative Post and/or Attachment!
2nd November 2007, 02:04 PM
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
Andy - did you mean -
pyrometer -
an apparatus for measuring high temperatures that uses the radiation emitted by a hot body as a basis for measurement.
CarolX
Theater is life, film is art, and television is furniture.
