Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th December 2000, 03:37 PM
Wendy
Unregistered Guest
Posts: n/a
Clown Addressing nonconformances
Does every nonconformance require a corrective action? Such as every data entry error?
If yes, can you offer some suggestions on how to handle types like these?
If not, what is a good way to document the fact that you looked at the nonconformance and decided it was not practical to address it?
Can anyone recommend a place to go to get ideas for a good Corrective action system, that isn't frowned upon by all employees?
Thanks.
Sponsored Links
Old 7th December 2000, 05:22 PM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
Wow, there is a lot of information in this forum on that question!! I would suggest that you do a search on CAs for the various responses. The basic answer, though, to your first question is no. You don't need a CA for every nonconformance, as the standard states that your decision about this should be based on the risk involved with the nonconformance. However, before I answer anymore, do a search and I think you'll find what you're looking for.
Sponsored Links
Old 7th December 2000, 05:27 PM
Jim Triller
Unregistered Guest
Posts: n/a
Not every "nonconformance" requires a specific corrective action, at least not with the registrars I have worked with. Consider the (potential) impact of the nonconformance on the customer and on the financial well being of your organization. If it does make sense (perhaps according to managerial judgment) take immediate action.
Where it doesn't make business sense to take immediate action trending may be used. I recommend using a "tally sheet" for capturing the less significant nonconformances and then periodically analyzing the data using some of the basic quality tools (Pareto analysis, cost/benefit analysis, root cause analysis, etc.). Then, based on this analysis, perform a corrective action to resolve what is determined to be the most pressing problem. I have found this approach to work well.
Old 8th December 2000, 06:41 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
Date: Thu, 7 Dec 2000 14:24:57 -0600
Subject: Re: Q: Nonconformances /Maseman/Andrews
>From: "Wendy Maseman"
>every data entry error? If yes, can you offer some suggestions
>on how to handle them?
>If not, how do address the fact that you looked at the
>Is there a web site that would help with setting up a good
>corrective action system?
>Any help would be welcomed.
>-Wendy Maseman
Wendy,
NO - every nonconformance does NOT require a corrective action. If a system is established that requires a corrective action for EVERY nonconformance, that system is soon bogged down with investigations, corrective action requests, etc. for a large number of INSIGNIFICANT happenings. Save the corrective actions for the SIGNIFICANT items. Determination of what is SIGNIFICANT is entirely up to you and your organization. It can be based on impact to product quality, safety, customer satisfaction, bottom line, undesirable trends, etc. or anything else that YOU decide. If corrective actions (and all that they entail) are reserved for REAL problems then they will get the attention and resources that they deserve.
My thoughts - hope it's helpful,
Ethan Andrews
Date: Thu, 7 Dec 2000 14:28:52 -0600
Subject: Re: Q: Nonconformances /Maseman/Blair
A single data entry level would not be a nonconformance. If there are a number of data entry errors, then it is reasonable to assume there is a root cause for all the errors, for example, incomplete or confusing work instructions. Rewriting the work instructions would address the root cause, merely correcting the data errors would not. If not, how do address the fact that you looked at the nonconformance and decided it was not practical to address it?
An example that comes to mind would be to find a single error on an internal audit, e.g. a control chart with points out of control. The auditor could request in the nonconformance an examination of a additional charts to see if there was a more extensive problem. If no such pattern was found, then it would be reasonable to document this and close the NCR.
Grant Blair
Date: Thu, 7 Dec 2000 14:31:22 -0600
The ISO model addresses this topic in section 4.14, allowing for corrective action appropriate to the nonconformance. It would seem prudent to expend resources where effectiveness is maximized. Isolated or sporadic errors on a manual process such as data entry are going to happen. The cost to eliminate the errors may not be in line with the value of the task.
Tom Bliven
Date: Thu, 7 Dec 2000 14:35:25 -0600
Subject: Re: Nonconformances /Maseman/venkatasamy
The ISO 9001:1994 says:
"Any corrective or preventive action taken to eliminate the causes of actual or potential non conformities shall be to a degree appropriate to the magnitude of problems and commensurate with the risks encountered"
So, the idea is to "attack the vital few, and hold the trivial many". What you need is the analysis, to classify the non conformances as "Vital" or "trivial". i.e) it is not required to have a CA for every non-conformance, provided you have proper analysis (magnitude/risk).
The data entry error in a transaction processing system, may not be vital, since you can validate it subsequently and also the effect may not be significant. How ever you find these errors quite often, it could be a chronic situation which may require a CA
However in automated production centers, any data entry error will be vital, since it could lead to rejection of the output and a CA also PA may be a must.
One method I follow is to classify the nonconformance as follows:
V - vital
E - essential
D - desirable
V will qualify for a CA & PA
E will qualify for a CA
D is further indexed as Sporadic and Chronic (that means such occurrences need to be analysed over a period of time) and a chronic D will qualify for CA, and for a sporadic D, there are no CAs, (atleast immediately)
This you need to spellout in your procedure
Regards
Venkatasamy
Date: Thu, 7 Dec 2000 14:38:42 -0600
Subject: Re: Nonconformances /Maseman/Bartschenfeld
We log every occurrence in which product was dispositioned (ie, scrapped, reworked, returned from customer). The Quality Manager assigns a responsibility to determine the root cause, if possible. If the root cause is systemic, we require a corrective action. If it appears not to be systemic, the responsible Manager may state that and the CAR is closed out. This allows us to track root causes as well as symptoms of nonconformances (we have a lot). We use an intranet database for the tracking.
Bob Bartschenfeld
Old 8th December 2000, 07:37 AM
Marc's Avatar
Karma Power: 605
Default
Also see:
http://Elsmar.com/ubb/Forum1/HTML/000016.html
http://Elsmar.com/ubb/Forum1/HTML/000330.html
http://Elsmar.com/ubb/Forum2/HTML/000036.html
Edited 2 January 2002
I can't re-lookup and change every old link to posts in the old forums. Most of them *should* still be there. If you want to find the post in the New forums, if the link to the thread in the old forums works (most of them should...), look at the thread (topic) title and what forum it is in. Then back here in the New forums - go to that forum and look for the thread topic title - OR - do a Search for the key words from Title (Note - you can search entire threads or just the 'subject' or 'title' - if you look in the Forums search page you'll see the options.
Call me lazy...
Old 19th January 2001, 03:23 PM
jdkilp
Unregistered Guest
Posts: n/a
You already have a number of very good answers to your question, but keep in mind that all Registrars are not created equally. Be sure to ask your Registrar the question. Although we all agree here that a single data entry error is not a nonconformance, you registrar might disagree with this - we're all unique.
If your registrar makes a big deal about it, you can get around it by stating specifically in your documentation system something to the effect that "...single data entries are not considered nonconformances..."
Jerry
Jerry Kilpatrick & Associates
Fax: 413-556-5711
jkilpatrick@ureach.com
Old 1st March 2001, 10:11 PM
Darrell Wenrich
Unregistered Guest
Posts: n/a
Actually, Auditors that have been involved with describe the approach of applying C/A to every issue is found to be what many have termed a "knee jerk" reaction. I agree with the earlier comment that a tally sheet can be used for tracking Non-Conformances.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Non-Conformance Reports require Corrective Action? Waterjetter06 ISO 9001 - Quality Management Systems Standard 7 28th October 2009 01:35 PM
When (criteria) to Require a Corrective/Preventive Action? (Industry Standard?) SoCalGlenn Nonconformance and Corrective Action 11 4th December 2008 10:10 AM
Corrective Action and Preventative Action cover Control of Nonconformance? filebase Nonconformance and Corrective Action 13 18th July 2007 03:46 PM
Nonconformance Corrective Action Software - Has anyone researched? Sean Kelley Quality Assurance and Compliance Software Tools / Solutions 2 9th January 2004 02:18 PM
Does every Nonconformance Require a Corrective Action? KenS Nonconformance and Corrective Action 4 8th April 2002 12:31 PM
The time now is 03:17 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
