19th April 2001, 01:27 PM
QA-LA
Registration Date: Jan 2000
Thanks Given to Others: 5
Karma Power: 71
Root Cause Analysis
Help! What can anyone tell me about Root Cause Analysis. I need some type of training to be able to give to our company.
19th April 2001, 01:44 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Take a read through the 8-D (Eight Disciplines Problem Solving) guide preview at http://Elsmar.com/8D/
19th April 2001, 01:47 PM
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
Technicomp has some good training that I have used in the past for problem solving. I know that isn't exactly what you asked for, but to my mind it goes pretty much hand in hand.
For root cause analysis, you need to remember these steps:
1. Define the problem. The problem as seen by the initiator may not be the "Whole" problem, it may not be anything more than a minor symptom.
WHAT went or could go wrong
WHO is affected, try to include every possibility
Is it sporadic or continuous, WHEN does it happen?
HOW did it happen (see step 2, this is the beginning of the identification of root cause)
2. Identify the cause. WHY did it happen, why did it not get caught etc. A lot of systems work using the 5Ys. Ask yourself why after each why you come up with for at least five whys. In other words, until you can no longer come up with any more answers.
A great way to use root cause analysis is to get others involved when you perform it. Get input from all or many departments.
If you do a good job of getting many areas involved and show that the company (management) is interested in looking into change and implementing what they can, you often end up with a staff of people who find it is much more satisfying to identify the root causes before a nonconformance happens (preventive actions).
19th April 2001, 10:35 PM
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Root Cause Analysis most of the time is used to fix blame. This is not as it should be. RCA involves identifying those factors which contributed to the occurance of an event and then determining the primary or major factor that lead up to it. Stay away from personalities and only look at fact.
20th April 2001, 02:15 AM
QA-LA
Karma Power: 71
Well thats a big part of the problem, we don't have Management Support, hence that is why we received a NC during our Surviellance Audit to element 4.1. The feel that if we have root cause analysis that people will respond to the CAR's, they said the reason they dont now is becuase they don't know how to determine root cause, at which point i had to bite my tounge. I have explaind to people that you need to ask why as many times as it takes to find out why it really happen. I will take a look at the 8-D in the fourm Marc, and thanks for your input also Steel it was very helpful.
20th April 2001, 04:40 PM
Karma Power: 255
Randy, you are right, like any tool, root cause analysis is often used for purposes that were improper, I myself often use table knives as screwdrivers. That doesn't make it right, and it sure isn't the best use.
ISO Guy, I've been exactly where you are. And I do mean exactly, we were a hair's breadth from loosing our cert due to commitment issues. Can I help you in any way?
[This message has been edited by SteelMaiden (edited 20 April 2001).]
20th April 2001, 05:15 PM
QA-LA
Karma Power: 71
Steel tahnks for the offer I do appreciate it. The only way you could help me is if you know of any companies in the Upstate NY are that are looking for a Quality Manager. I know what needs to be done, I have showed and explained to them what they need to do, do they listen no of course not. To tell you the truth if they lose their Cert. I could give a rats a$$, it will only hurt them. I was told by our Registrar (the auditors) that they were very confident in my abilities and knowledge, but they had questions abouit our Quality Managers at ou other facilities. The did ask me why I was still working here (they even told my upper Mgmt this), I told them I am not the type of person to jump ship and also that I have only been with the Company 1 1/2 years and I dont want to make it seem that i jump around fom job to job. I approached my boss for a raise at least what the incompetent QA managers of our other facilities (who have not been here as long as I have)and I was told I would need to put on a paper a justification for my raise before they would even consider it. I should just tell them give me a raise or I will leave and you will not have a prayer of maintaining your cert. LOL.
20th April 2001, 06:06 PM
Karma Power: 255
Good Luck ISO Guy. Don't know too many companies in your area...
As I said, I have been where you are (including the wage thing), we did manage to clear up the problems for the most part but in the long run, I put in for the first available transfer I could after we were out of danger of cert loss. I ended up with more than I had asked my previous mgt for, and all in all we are all happier. As my dear old Granny used to say, "This too shall pass"...but she was usually talking about something my brother swallowed. Have a good one!
