15th January 2009, 01:51 AM
Involved in Discussions
Registration Date: Aug 2005
Thanks Given to Others: 7
Karma Power: 18 Karma: 10
Short molding issue - Plastic injection molding from a multi cavity mold
I'm a quality Engineer of a connector manufacturing company.
We do plastic injection molding parts and this particular prduct that we are producing is from a multi cavity mold. As the parts are quite small, there bound to be short shot parts (imcomplete filling of the plastic resin) being produced. The problem is that the defect rate is very very low and now we are performing 100% screening before we derive with a solution. Out of 220K of goods, we only detected 4 pcs.
Is there a way to implement some form of control charts or sampling plan without the need to perform 100% inspection.
Please help.
Regards.
15th January 2009, 02:16 AM
Email Activation Not Completed
Registration Date: Jun 2007
Karma Power: 0 Karma: 15
Re: Short molding issue
You are running at 5.6 to 5.7 sigma and it is at the good position. With your continous improvement, the next 3 lot you will produce, you will achieve 6 sigma.
There is a lot of sampling standard that you may can follow. Such as ANSI, JIS or DN sampling standard. You also can develop your own reasonable sampling standard as long as your confident level is high (base on your back history, observation, experience..etc).
Even, you have perform 100% with your part, can you ensure it was 0 defect? So to shorten your inspection period, use sampling standard. Normally people will accept ANSI.
Thanks to nurshafie for your informative Post and/or Attachment!
15th January 2009, 07:47 AM
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Re: Short molding issue - Plastic injection molding from a multi cavity mold
When you are at such low levels of defects, throw your sampling plan away. It is not worth the electrons that it is stored on.
You have two choices:
100% inspect like you are doing now, or do zero inspection. The choice should be based on the economical risk of missing the defects.
Do you have any options of automating the inspection?
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
15th January 2009, 10:06 AM
Registration Date: Sep 2005
Thanks Given to Others: 571
Karma Power: 231
Welcome Shafie,
Good to see your post and please continue with your active participation.
15th January 2009, 10:23 AM
Registration Date: Dec 2005
Thanks Given to Others: 674
Karma Power: 176
Originally Posted by philiplim
Please help.
Regards.
Thats not a problem - if I was a Customer, I would immediately ask your organization name and address and have my parts manufactured there
I have no special talents. I am only passionately curious - Albert Einstein
Thanks to Ajit Basrur for your informative Post and/or Attachment!
15th January 2009, 12:09 PM
Not possible to automate the inspection as it is very costly to incoporate vision checking system.
15th January 2009, 01:17 PM
Registration Date: Apr 2006
Thanks Given to Others: 30
Karma Power: 22
What is the risk of shipping a short shot? What is the severity associated with short shot from your PFMEA? If risk or severity is high, you must continue to sort. If that risk is acceptable, then you may be able to alter your detection routine.
What have you done to prevent the short shots? Have you conducted a mold balance analysis? Has the tool been optimized? Has the process been optimized by using decoupled molding? Don't get hung up on improving detection if you haven't exhausted your options in fixing the root cause of the issue. Why is the process producing short shots?
Once your process is set up and is validated, you can do some machine monitoring to predict shots which contain suspect parts. This may reduce the population which needs sorted.
Thank You to rmf180 for your informative Post and/or Attachment!
15th January 2009, 01:55 PM
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
rmf180 gave an answer similar to what I was thinking.
If the consequence of shipping a short shot is not severe, see if your customer will accept a few extra parts per shipment to replace any potential short shots.
Thanks to howste for your informative Post and/or Attachment!
