Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 14th September 1999, 03:28 PM
Steven Sulkin
Unregistered Guest
Posts: n/a
Desensitizing to reduce variation
Any examples of how process desensitization has been used to reduce variation? Desensitization is the technique of making a process more robust to input variation. You may have heard it called something else? I believe this is a Taguchi technique. Any examples, even made up would be helpful.
Thanks in advance,
Steve.
Sponsored Links
Old 16th September 1999, 11:15 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Lightbulb
I had not heard of 'desensitization,' but I think I know what you may be talking about.
Controlling input variables (temperature, cycles times, feed rates, etc) generates a great deal of cost (less than sorting good from bad, however). But many companies fail to identify key inputs from the less critical ones. One particular case I know of was in chemical deposition. The bath had to start at a certain temperature, ramp up to another temperature within a given amount of time and end at another temperature. Typically, this ramp would look a little like a backwards 'Z' stretched vertically slightly.
According to theory, the start temperature had to be 'X' +/- 'A', the ramp had to be 'Y' +/- 'B' and the end temperature had to be 'Z' +/- 'C.' Any depositions that failed to meet this criteria were considered bad, but experimental test results of the finished product had failed to correlate this. So, basically they were controlling the process exactly as they wanted, but could not correlate it with results.
After reviewing the information, I asked to see the validation results from which they arrived at the process control variables. After review, they had verified the process with yield data (percentage passed) rather than variable data (how well they passed using LSL tolerances).
I designed an experiment and asked them to run it for me. Using the results of the experiment and the variable data (rather than attribute that was used before), I found that the only key input was the start temperature. Using ANOVA, it was determined that, in order of key, start temperature was first, ramp was second and end temperature was third (end temperature contributed nothing to the variable data). Based on these results, I requested they tighten the tolerance on start temperature, leave ramp where it was and remove the end temperature tolerance entirely. After some additional runs, tolerances were adjusted slightly, then made standard practice.
The results were they could use finished depositions for continued processing without reducing the quality of product (increase yield, decrease costs). It should also be noted that the finished product yield also increased (decrease costs).
By removing the tolerance on end temperature, control methods for this input could be removed (decrease costs).
Thus it was revealed that by allowing greater variation in end temperature, there was a decrease variation in quality of end product. Is this what you were asking?
Regards,
Don
Sponsored Links
Old 14th November 2001, 02:12 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Question
Anyone heard anything about this recently? Or have anything to add?
Old 14th November 2001, 03:45 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
I have on my company site, one case study you may find useful:
Making Filter Paper Slitting Process Robust
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Last edited by Atul Khandekar; 1st April 2005 at 08:43 AM. Reason: Corrected the URL
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process Variation and Total Variation - Relationship and Definitions 9876543219 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9 5th March 2009 05:07 AM
Attempting to reduce sample size - The "best" statistical technique to use Patzer SPC Monitoring and Statistical Analysis Techniques 10 21st January 2009 04:38 AM
Reducing Equipment Variation - Appraisal Variation - Newly developed product naveenattri Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 23rd May 2008 04:26 PM
Gage R&R - Tolerance vs. Total Variation - Process Variation vs. Gage Variation Jrodrigu Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 29th August 2002 09:09 AM
Case in RR studies:Can we MARK the measurement point to reduce within part variation? MSAFAI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12 28th March 2002 06:30 AM
The time now is 07:38 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
