30th January 2009, 12:56 PM
Shy Poster (1 to 5 Posts)
Registration Date: Feb 2006
Thanks Given to Others: 1
Karma Power: 16 Karma: 10
Calculating an AQL given a sample size, accept/reject numbers, and lot size
How do I calculate AQL given a sample size, accept/reject numbers, and lot size?
The company I work for manufactures suspension assemblies for hard drives. We employ a 0.10 AQL sample plan for lot sizes 3201 - 10,000 for critical attribute defects (c = 0, n = 125) and, for cosmetic defects, the acceptance number is 2 (using the same 125 pc sample). This is not a standardized AQL based on the ANSI Z-1.4 standard and I would like to convert the plan used for cosmetic defects into an AQL. Any suggestions on how I can do this?
30th January 2009, 02:39 PM
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Re: Calculating an AQL
You could use the the binomial distribution to "work backwards" to see what sort of defect rates would create such a sampling plan. (I posted a spreadsheet here: Sampling Spreadsheet to help determine the sample size for sampling plans that can help with the calculations).
Playing around with the numbers, I found that if you take a typical definition that AQL = "lots with this defect rate will be accepted 95% of the time", then for:
- c=0 for 125 pieces ==> AQL = 0.04
- c=2 for 125 pieces ==> AQL = 0.6
I should point out the the standard tables do no specifically try to meet the "will be accepted 95% of the time". It can be well below or well above 95% in the actual plans. So there is no way to definitive way to say what the AQL is if the plan is not on the tables.
Tim F
Thank You to Tim Folkerts for your informative Post and/or Attachment!
10th April 2009, 05:19 PM
Involved in Discussions
Registration Date: Mar 2007
Karma Power: 11 Karma: 40
Re: Calculating an AQL given a sample size, accept/reject numbers, and lot size
It would benefit you to actually plot the Operating Characteristic (OC) for a few sampling plans if you really are unfamiliar with the mechanism for determining AQL from a given sampling plan. All you need is a set of probability tables and some graph paper - and maybe a calculator if you are not to good at basic arithmetic. Doing this for yourself is more informative than simply looking at the curves an a textbook, or perhaps in documents similar to Mil Std 105
The comparison between curve shapes for differing values is also very informative.
Regarding the earlier comparison of C=0 and C= 2; Plotting the curve for each of these plans, on the same sheet, provides a view of the remote end of the curve, what happens when the product quality is actually way off the projected AQL.
Regarding the comment
Reason: Incomplete response.
