10th February 2009, 06:05 AM
Involved in Discussions
Registration Date: Jun 2008
Thanks Given to Others: 55
Karma Power: 25
I cannot access some parts of the site - It says my security token has expired
Hi All
I cannot access some parts of the site. It says my token has expired. i didn't realise I was on a meter
Anyone know if it is something at my end. I tried searching for it to no avail.
Peter
"One often meets his destiny on the road he takes to avoid it"
Reason: Post #1 & #2 moved from Coffee Break and Water Cooler Discussions forum
10th February 2009, 06:11 AM
Registration Date: Aug 2006
Thanks Given to Others: 854
Karma Power: 100
Re: Token expiration
Hi Peter,
Did you contact Marc about this? I had a similar experience recently while trying to upload photos. Use the Contact Marc link at the bottom of the page, or the Report This Post button (the red and white triangle) in the upper right hand corner of the topics list. Be sure to describe exactly what your experience was so he will be able to investigate.
Hope this helps.
Gidget Stough, ASQ CQA
"It's easier to do a job right than to explain why you didn't." - Martin Van Buren
Reason: clarification
Thanks to GStough for your informative Post and/or Attachment!
10th February 2009, 01:26 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 604
This is almost always a cookie and/or cache issue. Each 'session' has a 'security token' to ensure no intercept of the exchange or code injection can take place.
The first thing to do is to try what you were doing on another computer and/or in another browser. If what you were doing fails on a different computer and/or browser contact me with as much detail as possible including any error messages.
If it does work on another computer, or on the same computer using a different browser, clear the browser cache and cookies, shut down the browser and reopen it and try again.
This is rare - This is only the second complaint I've had, but then again it's the second complaint within about a week. The first one was a computer issue. I'm betting this is as well. Browser caches and cookies can become corrupted.
If it continues and you can't figure out the problem let me know and I'll try to help.
