Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Calibration Frequency (Interval)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th February 2009, 01:49 PM
Bob the QE Bob the QE is offline
Involved in Discussions
Registration Date: Mar 2008
Thanks Given to Others: 45
Karma Power: 15
Bob the QE is appreciated, and has over 200 Karma points.Bob the QE is appreciated, and has over 200 Karma points.Bob the QE is appreciated, and has over 200 Karma points.
Look! Traceability to the Thimble of ID (inside diameter) Micrometers and Depth Micrometers
I am looking for ideas on how to make stems for depth mic's and ID mic's traceable back to the thimble. Or maybe they don't need to be but I would think they would. You covers always provide great information and ideas so I am sure I will get either or from you.
Thanks in advance.
Sponsored Links
Old 18th February 2009, 01:41 PM
Coury Ferguson's Avatar
Coury Ferguson Coury Ferguson is offline
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 657
Karma Power: 191
Coury Ferguson is appreciated, and has over 1700 Karma points.
Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.Coury Ferguson is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Coury Ferguson
Default Re: Traceability to the Thimble of ID (inside diameter) Micrometers and Depth Microme
Any comments?
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
Sponsored Links
Old 9th March 2009, 10:51 PM
brobinson brobinson is offline
Registration Date: Apr 2007
Karma Power: 12
brobinson has less than 100 Karma points so far.
Yes, you are absoutely correct on your traceability assesment. Each depth rod and each id rod from a set are calibrated to a single micrometer head.
So, a set of depth mics has a micrometer head and typically 3, 6 or 9 rods. Each rod has the zero setting adjusted at the low end with the micrometer head.
For every ID mic set, wether it be tube mics or rod mics, each rod is has the zero setting adjsuted at the low end with the micrometer head.
For tracability, we acid etch a control number on every rod and the micrometer head in a set. It is actually a very easy process.
Do Not!! use a rod from someone else's set for measuring or calibrating purposes. You will have false readings.
In addition to setting the zero on each rod, the calibration for a gauge set should include a lead error check on the head itself. This will verify the integrity of the gauge by checking for wear or slop on the lead screw. I've seen some ID mic sets have lead error readings up to .0008". ID mics should have a slight drag on the turning of the head as opposed to smooth movement on a depth or od micrometer. We have a lot of operators that will loosen the lead nut on the shop floor, essentially voiding the calibration.
If you have any other questions, or I just confused you please let me know and I'd be glad to help.
Thanks to brobinson for your informative Post and/or Attachment!
Reply
Bookmarks
Tags
micrometers, traceability
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibrating 4" and larger Micrometers ascint1 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 7th February 2009 01:29 AM
Gage R&R for Uni-Micrometers on a rod or bar OD (Outside Diameter) chasf Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 28th February 2008 11:33 AM
Using Gage Pins - Inside diameter - Interference fit jkittle ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 18th December 2006 10:13 AM
Measuring Method - Inside diameter is off set from the outside diameter Jim Howe ISO 17025 - Calibration, Measurement Gages and Test Laboratories 11 7th September 2004 09:26 AM
Microfinish conversion - Micrometers (?) to microinches? Proud Liberal Manufacturing and Related Processes 3 18th May 2004 09:36 AM
The time now is 12:42 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
