Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
26th February 2009, 12:10 PM
Shy Poster (1 to 5 Posts)
Registration Date: Feb 2009
Karma Power: 18 Karma: 10
Removal of Obsolete copies of Controlled Documents
I have a very simple question but I just want to get some different ideas.
How do you ensure that all obsolete versions of a document are destroyed to prevent their use inadvertently?
26th February 2009, 12:15 PM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,974
Karma Power: 1438
Re: Copies of controlled documents
In Reply to Parent Post by pinnochio
Don't print/copy them.
Stijloor.
26th February 2009, 12:30 PM
Registration Date: Apr 2001
Karma Power: 72
Track their distribution.
26th February 2009, 12:33 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,547
Karma Power: 400
Re: Removal of Obsolete copies of Controlled Documents
More information is needed, but I assume you are referring to paper documents. Correct?
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
26th February 2009, 12:44 PM
Registration Date: Jan 2005
Thanks Given to Others: 1,805
Karma Power: 1451
The title of your post alludes to "controlled documents." If the documents in question are controlled you will know to whom copies were issued, and you should be able to retrieve them when new versions are issued. Verifying locations of controlled documents should be included in your internal audit process.
Everyone has a plan until they get punched in the face (Mike Tyson)
1st March 2009, 07:48 PM
Appreciated Member
Registration Date: Sep 2005
Thanks Given to Others: 45
Karma Power: 94
Destroying all obsolete versions of a document within the timeframe you are legally obliged to retain them (e.g. 5 years for manufacturing procedures under the MDD) would be a bad move....
Destroying all copies, whilst retaining the master original in a secure, traceable location, would be a good move....
I work for SGS Notified Body 0120. I generally post in a private capacity.
1st March 2009, 08:38 PM
Appreciated Information Resource
Registration Date: Aug 2008
Thanks Given to Others: 1,044
Karma Power: 355
Back in the Bad Old Days before we had an effective QMS, we occasionally discarded All Of The Prior Versions Of A Document, only to subsequently discover that we needed one of those versions for a valid reason.
For instance, because an auditor wants to review the state of a requirement at a prior time, or because that prior version is relevantly referenced in the specifications of a process or product that we hadn't run in a while.
Now we definitely don't discard prior documents.
We do of course maintain proper controls over where and why paper copies exist, and over their use for controlled purposes. For all documents that might be subject to later review, we also maintain a chronological effectivity record.
2nd March 2009, 01:46 AM
Forum Administrator
Registration Date: Dec 2005
Thanks Given to Others: 1,481
Karma Power: 400
I suppose you would have a distribution matrix listing where the controlled copies have been distributed, right ? This
So when a new version is available, replace the old ones with new ones.
Retain the master copy for future reference and shred the remaining copies.
Well done is better than well said - Benjamin Franklin
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Controlled Documents - How many copies can be stamped "Controlled Document"?
roadrunner5_2000 |
Documentation Control Systems, Procedures, Forms and Templates |
12 |
21st January 2013 03:10 PM |
How long do you keep copies of your obsolete documents, not records just documents?
kmyers |
ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions |
11 |
10th August 2010 12:52 PM |
Electronic Copies of previous versions of Controlled Documents in editable format
bonnieblue |
3 |
30th October 2009 12:29 PM |
Printed Copies of Controlled Documents
bonnieblue |
9 |
22nd July 2009 10:06 AM |
Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained?
jdipira7 |
7 |
10th January 2005 10:55 PM |
