Go Back   The Elsmar Cove Forum > Quality Manager Issues > Customer Complaints including ISO 10002
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th March 2009, 09:12 PM
beluga123 beluga123 is offline
Shy Poster (1 to 5 Posts)
Registration Date: Mar 2009
Thanks Given to Others: 2
Karma Power: 3
beluga123 has less than 100 Karma points so far.
Please Help! Allergic reactions complaints for a protective apparel (impervious gown)
Several months ago, we received a few allergic reaction complaints for a protective apparel (impervious gown) made with PE laminated SPP (Polypropylene) fabric. This is the only material used in this gown. No thread, latex elastic...etc. is used on this gown. The customers complainted about redness, itchness...etc. allergic reactions on the face. The gown is worn on the body only. There was no contact with the face under normal user condition. We sent complaint samples to an US lab for the Cytotoxicity and Skin Irritation Tests. Both Test passed. A few days ago, our factory reported that 6 workers (out of 60) complained about the similar allergic reactions when they were making the same gown. The fabric supplier said that they did not make any change in the materials or manufacturing method. Our factory checked possible environmental factors and could not find an assignable cause. The production resumed with another lot of the same fabric yesterday, but there was no worker complaint so far. I would appreciate if anyone can share their experiences on any allergic reaction to this type of material. Any suggestion for investigating this issue is greatly appreciated. Thanks!
Sponsored Links
Old 12th March 2009, 09:27 PM
GStough's Avatar
GStough GStough is offline
Registration Date: Aug 2006
Thanks Given to Others: 854
Karma Power: 100
GStough is appreciated, and has over 1700 Karma points.
GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.GStough is appreciated, and has over 1700 Karma points.
Send a message via AIM to GStough Send a message via MSN to GStough
Default Re: Allergic reactions complaints
Hi beluga123,
My former employer had a similar situation a number of years ago with certain types of fabrics from one supplier. After a series of tests, it was determined that this fabric had been exposed to higher than usual levels of formaldehyde during one of the supplier's processes. This exposure to an increased level of formaldehyde resulted in several employees complaining of skin and eye irritations; skin from coming in contact with the fabric for extended periods of time, and eye irritation from the strong fumes present in the fabric.
After some back and forth communication and corrective action with the supplier, the issue was finally resolved. Regular monitoring of the air quality was a direct result of this experience, which was a good thing.
However, it doesn't sound as if this is the same kind of situation in your company. I'm not sure what else it might be, but perhaps the supplier of the fabric may be able to visit your facility and determine what the problem is and the options for resolution.
I hope this helps. Good luck to you...
Gidget Stough, ASQ CQA
"It's easier to do a job right than to explain why you didn't." - Martin Van Buren
Thank You to GStough for your informative Post and/or Attachment!
Sponsored Links
Old 13th March 2009, 12:03 AM
MIREGMGR MIREGMGR is offline
Involved in Discussions
Registration Date: Aug 2008
Thanks Given to Others: 236
Karma Power: 176
MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.
MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.MIREGMGR is appreciated, and has over 1700 Karma points.
Default Re: Allergic reactions complaints for a protective apparel (impervious gown)
Three thoughts:
1. "...PE laminated SPP (Polypropylene) fabric. This is the only material used in this gown. No thread, latex elastic...etc. is used on this gown."
With all due respect, that sounds like "the spec sheet says it's pure, so it must be pure." Have you had a chemical analysis done to determine whether something else is present in micro quantities? Keep in mind that a sensitization effect could be due to something present in the parts-per-million range.
If the PE is laminated to the PP via a flame technique, it's guaranteed that complex organics are present. If the fuel-gas for the flame-lam line was unusually heavily loaded that day with odorant, there will be sulfur and nitrogen present in the complex organics as well as C, H and O.
2. "We sent complaint samples to an US lab for the Cytotoxicity and Skin Irritation Tests. Both Test passed."
It's conceivable that the guinea pig model used in ISO 10993-10 isn't effective for your sensitizer, if what's occurring amounts to an allergic or immune reaction.
This comment was made some time ago about 10993-10 by experts from NAMSA, an experienced lab:
"The guinea pig sensitization tests described above are useful methods for eliminating the possibility that patients will be exposed to strong sensitizing chemicals extracted from medical device materials. However, these methods are far from perfect in their ability to detect weak sensitizers or chemicals, or those present in low concentrations, and they do not detect chemicals that act as adjuvants, enhancing an immune response to other chemicals to which a patient might be exposed. Nor are they able to detect responses to antigens such as plant proteins (...) "
"Additional test methods currently under development may prove useful for evaluating biomaterials for sensitization. One test that shows promise is the local lymph node assay in mice. In this method, the ears of mice are treated and then the surrounding lymph nodes are examined for a lymphocyte proliferative response as demonstrated by an accumulation of a radio-labeled marker."
3. One interestingly useful, quick and free contamination test on polyethylene-film-laminated material is for someone with a sensitive sense of smell, and some experience using it in a materials-engineering sense, to sniff a swatch that's just been unrolled. Pure polyethylene should have zero smell at room temperature...but industrial-sourced material (or even food grade) is almost never that pure. Tiny percentages of contamination in polyethylene can be detected by smell.
Sense of smell is gender-dependent, though the oft-mentioned 10x greater average sensitivity of females over males is unreliable because it's an average and because sensitivity differences actually depend on the chemical being smell-detected. It's pretty effective, though, to just ask people who has a sensitive sense of smell. Most of the volunteers will be women, and their self-evaluation will be pretty reliable in my experience. In a production context, this can be used as a material QC tool by just having a designated individual sniff each roll of material after a couple of layers have been unrolled to detect if it's "different" and needs to be investigated by a materials engineer.
Thanks to MIREGMGR for your informative Post and/or Attachment!
Old 13th March 2009, 03:26 PM
Karma Power: 3
Dear Ms. Stough,
Thank you very much for your input!
We will definitely look into the formaldehye issue. We will also look into the possibility of obtaining a formaldehyde detector to monitor the air quality in our production room.
Again, I greatly appreciate for your valuable inputs.
Best regards,
Beluga123
Old 13th March 2009, 03:38 PM
Karma Power: 3
Dear Miregmgr,
Thank you very much for your inputs.
We ran the FTIR and DSC Analysis on these fabrics previously, but did not find anything unusual. We also used Scanning Electron Microscope to check the fabric structures, but it also did not show anything abnormal.
Any suggestion for performing other chemical analysis is greatly appreciated.
Best regards,
Beluga123
Reply
Bookmarks
Tags
allergic reactions, polypropylene, protective apparel
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Inspecting subcontracted manufacturing of garments, wearing apparel KN Quality Manufacturing and Related Processes 5 27th August 2009 11:33 AM
ASTM b137 - Is protective value equal to protective capability? guoyiivan Various Other Specifications, Standards, and related Requirements 3 20th May 2009 01:08 AM
Anyone know how to establish one piece flow in apparel industry? RaymondC Lean - Lean in Manufacturing and Services 9 2nd April 2009 08:30 AM
Reactions to out of control X bar and R charts? Josh Smith SPC Monitoring and Statistical Analysis Techniques 10 2nd July 2008 09:20 AM
Corrective Actions for Customer Complaints - Do ALL complaints have to be Answered? dbulak Customer Complaints including ISO 10002 8 20th November 2002 02:07 PM
The time now is 04:22 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
