Go Back   The Elsmar Cove Forum > Quality Manager Issues > Quality Management Related Issues
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th April 2009, 05:10 PM
Tiger Woods Tiger Woods is offline
Shy Poster (1 to 5 Posts)
Registration Date: Apr 2009
Thanks Given to Others: 5
Karma Power: 3
Tiger Woods has less than 100 Karma points so far.
Please Help! Blueprint Notation Question - Print dimension like 4.312 g +.002 -.001
I could use some help with and issue on reading blueprints. I should probably know this, but haven't been formally trained and have never seen this before.
When you have a print dimension like 4.312 g +.002 -.001
I'm guessing that the "g" means ground
an "m" means milled
a "t" means turned
What would an "h" mean?
Any help is greatly appreciated.
Sponsored Links
Old 15th April 2009, 05:30 PM
True Position's Avatar
True Position True Position is offline
per ASME Y14.5M-1994
Registration Date: Feb 2005
Thanks Given to Others: 4
Karma Power: 46
True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.True Position is appreciated, and has over 900 Karma points.
Default Re: Blueprint Notation Question
While I've never seen that notation, h could be 'honed'. Odds would be against honing unless you're dealing with a surface where the finish was very important but it's the only process that comes to mind that starts with an h.
Normally I see just a dimension and a surface finish tolerance. From what I see when someone wants a specific process/machining direction they specify it fairly clearly on the drawing. 'Grind this surface counterclockwise' and the finish symbol 0.3. etc.
Thank You to True Position for your informative Post and/or Attachment!
Sponsored Links
Old 15th April 2009, 05:33 PM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,318
Karma Power: 377
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
an "m" means milled
a "t" means turned
Welcome to The Cove Forums!
Well.....let's not guess....
Can you attach the actual document or part of it so that we can take a look at the actual call-out?
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Old 15th April 2009, 05:42 PM
Karma Power: 3
Thanks for the quick responses and the welcome.
Let me see what I can do about getting a part of the actual call-out on here.
Old 15th April 2009, 05:56 PM
Karma Power: 3
Here is a portion of the blueprint that I can show.
I have circled the two dimensions that I'm not sure about.
One have an "h" and the other has an "N".
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 15th April 2009, 06:17 PM
Stijloor's Avatar
Karma Power: 377
OK. That clarifies it.
The letters do not indicate particular machining operations but are part of a call-out related to what "The Machinery's Handbook" calls "Allowances and Tolerances."
There is also an ANSI Standard for this: ANSI/ASME B4.2-1978(R2004)
In your example from the attached drawing....
100 N7 means the following:
  • "100" is the nominal dimension.
  • "N" Indicates the location of the tolerance zone relative to the nominal. You can see that the tolerance zone is located below the nominal. In addition, a capital letter also means that this applies to an internal diameter.
  • The number "7" indicates a tolerance grade.
Next:
112 h8 means the following:
  • "112" is the nominal dimension
  • "h" indicates the location of the tolerance zone relative to the nominal.
  • "8" indicates the tolerance grade. The larger the number, the more tolerance.
There's a lot more to it then I can explain here, but if you have access to "The Machinery's Handbook", it explains it in great detail.
Thank You to Stijloor for your informative Post and/or Attachment!
Old 15th April 2009, 07:00 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
This sounds a lot like the various classes of threads with letter designations for the fit and upper/lower case for internal/external threads.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thanks to Miner for your informative Post and/or Attachment!
Old 15th April 2009, 07:03 PM
Stijloor's Avatar
Karma Power: 377
That is correct. The 'Thread Standards" people borrowed some parts of the system for thread tolerance designations.
Stijloor.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Conversion Help!! Print with this dimension .2917+/-.0005 :1 CMfgT Inspection and Test, Sampling and Related Topics 9 24th April 2009 08:49 AM
What is Constrains k (dimension subject to law provision) - Characteristic on print? filcavalli Various Other Specifications, Standards, and related Requirements 1 22nd June 2006 08:52 AM
Resolution question - Measuring a product on a CMM - the tolerance is .000/.001 mtncrawler Inspection and Test, Sampling and Related Topics 3 5th June 2006 10:46 AM
Dimension Inspection - Results recorded on print - Seeking a better method Michael36 Inspection and Test, Sampling and Related Topics 1 31st March 2001 10:58 AM
PPAP submission level classification - One dimension on print is changed BrakeMan APQP and PPAP 16 28th February 2001 12:27 AM
The time now is 03:47 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
