Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
17th April 2009, 01:31 PM
Involved in Discussions
Registration Date: Feb 2009
Thanks Given to Others: 145
Karma Power: 29 Karma: 180
Russian Roulette - Interviewer suggests to play imaginary Russian Roulette with you
Hi everyone,
This one is not very difficult, but I really like it (perhaps, because I'm Russian?  )
Anyway, this is one of the (in)famous Microsoft's interview brain teasers that I think is actually quite good for an interview (assuming that the interviewee is expected to know the basics of logic and probability theory): Interviewer suggest to play imaginary Russian Roulette with you.
Interviewer takes an imaginary revolver gun with 6 empty chambers, and loads 2 adjacent chambers with bullets.
Interviewer has the first turn: rolls the cylinder, puts it to his head, and pulls the trigger... no shot.
The lucky interviewer passes the gun to you and gives you two options before you put the gun to your head and pull the trigger: (a) to roll the cylinder again
or(b) not to roll the cylinder
Which option would you choose?
Bonus questions: Which option would you choose if 2 bullets were placed into non-adjacent chambers?
Which option would you choose if it was a classic Russian Roulette - that is, if only one chamber was loaded?
Good luck,
Yarik.
17th April 2009, 02:01 PM
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 170
Karma Power: 284
Re: Russian Roulette
Neither - I would flee from the interview the minute I saw a gun.
17th April 2009, 02:03 PM
Registration Date: Jan 2002
Thanks Given to Others: 323
Karma Power: 262
OK, we know where one empty chamber is, and there are 3 remaining. The other two have a little surprise in them, but they are together, so only 1 counts. That means that there is a 1 in four (25%) chance that things will end badly if we do not spin.
On the other hand, if we re spin the cylinder, there is a 2 in 6, or 33.3%, chance that the thing will go boom. So, do not re spin.
If the bullets are separated, there will be a bullet next to 2 of the empty chambers. We already know where one of the empties is. If we do not spin, then the chance of a bad outcome on the next try is 2 out of 5, or 40%. If we do spin, the chances are 2 out of 6, or 33.3%.
Similarly, with 1 bullet, the interviewer "used up" one empty chamber, so spinning improves the odds from 1:5 to 1:6.
Right?
17th April 2009, 04:45 PM
In Reply to Parent Post by Craig H.
Right?
Well, not exactly...
Would you like to try to reword (or revise) your reasoning? For example, the statement "we already know where an empty chamber is" is not correct. All you know is that "a chamber that is currently facing the barrel is next to an empty one".
17th April 2009, 04:53 PM
Karma Power: 262
In Reply to Parent Post by Yarik
In a revolver, we would know that the chamber under the hammer after the trigger is pulled is empty. As the trigger is pulled (for a double action revolver anyway) the cylinder advances to the next chamber. Of course for many revolvers you could just look at the back of the cylinder and see if there is daylight or not...
17th April 2009, 07:42 PM
My bad. Did not hold a revolver for quite some time.
All right, you do know where the empty chamber is. And my suggested correction wasn't a good one, anyway. Moreover, all the final choices that you came up with are correct. But... the probability of dying without spinning in the second scenario (the scenario with two bullets in non-adjacent chambers) was calculated incorrectly, which makes the correctness of your logic in all scenarios questionable. That's why I said that your answers are "not exactly correct"...
Yeah, that's true. That's one of the reasons why our imaginary revolver is so much better for Russian Roulette: (1) you can't cheat by looking at it; (2) it can't kill anybody.
4th June 2009, 03:02 PM
Registration Date: Jan 2007
Thanks Given to Others: 72
Karma Power: 42 Karma: 157
Re: Russian Roulette - Interviewer suggests to play imaginary Russian Roulette with y
you should spin in the second scenario. if the two bullets are not adjacent you only have a 50% chance of the next cylinder being empty. spinning with two of 6 loaded would be the 66% chance of being empty.
if you really were asked this question or one close to it in an interview would it be bad to ask for scratch paper?
4th June 2009, 11:38 PM
In Reply to Parent Post by Neil V.
Yep, exactly.
First, it depends on the interviewer, of course. If I were the interview er, I wouldn't mind at all. Maybe it's just me, but during interviews I am much more interested to see how people approach the problem and think than to get correct "end results" from them.
Also it may depend on how you (as an interview ee) estimate your chances to solve the problem (or at least explain your thinking) without scratch paper. If such chances are low you might want to take the risk and ask for scratch paper. The additional bonus would be that you'd get a chance to learn something extra about your current interview er...
It's not the plan that is important, it's the planning. (Graeme Edwards) -- Perfect is the enemy of good. (Russian saying)
Reason: Fixed quote.
Forum Posting Settings
