Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th May 2009, 12:16 AM
damienbechaux damienbechaux is offline
Shy Poster (1 to 5 Posts)
Registration Date: May 2009
Karma Power: 3
damienbechaux has less than 100 Karma points so far.
Question Problem with AQL (Acceptable Quality Level)
I am currently using the AQL system for my work but I think there is a problem with this system.
This system gives acceptance or rejection thresholds for major and minor defects but sometimes it can lead to an incherence.
Let me explain this problem with an exemple:
If we have for instance:
-Minor defects: acceptance 7, rejection 8
-Major defects: acceptance 2, rejection 3
If we find 8 minor defects and 0 major defects we reject the production.
If we find 7 minor defects and 1 or even 2 major defects we accept de production.
I think this is a real problem because the second case is more serious than the first one and we accept it while we reject the first one.
The proof of this problem is that we can easily put in order the different cases bellow, from de least serious to the most serious:
8 minor defects and 0 major defects < 7 minor defects and 1 major defect < 7 minor defects and 2 major defects.
Can someone help me to understand why AQL works like that?
Thanks a lot.
Damien
Sponsored Links
Old 11th May 2009, 12:33 AM
howste's Avatar
howste howste is online now
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default Re: Problem with AQL
It works that way because your organization has agreed to accept a certain level of defects (the Acceptable Quality Level). If you really can't accept that level of defects, you need to change and use a plan with a lower AQL. You might also choose to use a "C=0" sampling plan which will never accept a lot with known defectives.
Sponsored Links
Old 11th May 2009, 12:54 AM
Karma Power: 3
First, thanks for you answer.
What I say is wathever the levels of defects chosen by the organization, this system can allow the organization to accept a production worse than a production it would reject (see my example above).
And "mathematically", this is due to the separation of major and minor defects.
Old 11th May 2009, 01:28 AM
harry harry is offline
Registration Date: Sep 2005
Thanks Given to Others: 572
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Default Re: Problem with AQL (Acceptable Quality Level)
I find your reasoning to be without logic.
If your acceptance criteria is not more than 7 minor and not more than 2 major, then one minor is equivalent to 2/7 major.
Therefore, Conditions for acceptance should be:
not more than 1 major + 3 minor
anything more - reject.
But this is just looking from the logical point of view.
Old 11th May 2009, 04:44 AM
brahmaiah brahmaiah is offline
Quality veteran
Registration Date: Mar 2009
Thanks Given to Others: 10
Karma Power: 18
brahmaiah is appreciated, and has over 400 Karma points.brahmaiah is appreciated, and has over 400 Karma points.brahmaiah is appreciated, and has over 400 Karma points.brahmaiah is appreciated, and has over 400 Karma points.brahmaiah is appreciated, and has over 400 Karma points.
The sampling tables work well in ideal situations.They are pure theory, basesd on probability.We can neither ignore the sampling tables nor strictly adhere to them. The quality inspector has to use lot of his experiance and discretion in using the tables.The Quality plan /control plan specification on AQL has to be fixed carefully, because Control Plan is mandatory.
V.J.Brahmaiah
Old 11th May 2009, 09:38 AM
Geoff Withnell's Avatar
Geoff Withnell Geoff Withnell is offline
Involved in Discussions
Registration Date: Jul 2007
Thanks Given to Others: 2
Karma Power: 34
Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.Geoff Withnell is appreciated, and has over 900 Karma points.
Originally Posted by damienbechaux View Post
Thanks a lot.
Damien
When using attribute inspection, and an AQL, one has sevral choices to make. One can determine what is the acceptable AQL for major defects and apply this sampling plan. One can also determine what is the acceptable AQL for minor defects, and apply this plan. These are two separate actions, and do not "add" together, so the mathematics of the situation is irrelevent. If you wanted to have a quality level score that included major and minor defects together, you could decide that, one major defect was equivalent to, say 3 minor defects. And then decide what was the appropriate AQL and sampling plan for this "blended" score. AQL works the way it does because the tables were set up to look at one AQL and sample at a time, not to "add" results of different samples and AQL levels.
Geoff Withnell
Old 11th May 2009, 11:15 AM
Karma Power: 3
Thanks for your answers. It is more clear now.
Damien.
Old 11th May 2009, 11:24 AM
howste's Avatar
Thaumaturge
Karma Power: 206
This may or may not be true. If the inspector has experience, we may allow the person to use that experience to influence the decision. If the inspector doesn't have the right experience, we shouldn't rely on their experience to make judgment on the lot. More often than not, I see that the rules are set by the organization and must be followed.
V.J.Brahmaiah
Control plans are mandatory only for TS 16949. I'm not aware of any other standards or regulations that require them. Of course, TS 16949 only allows acceptance with zero defects (C=0) for attribute sampling.
Thanks to howste for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
AQL - How do I find Acceptable Quality Level? qmslady AQL - Acceptable Quality Level 72 8th June 2009 05:07 PM
Setting AQL (Acceptable Quality Level) on C=Zero inspections Norman V AQL - Acceptable Quality Level 16 6th December 2006 10:41 AM
AQL - Acceptable (Assured) Quality Level Marc Definitions, Acronyms, Abbreviations and Interpretations 0 29th December 2005 02:44 AM
Custom hardware product - What acceptable quality level (AQL) is expected in the US? apestate AQL - Acceptable Quality Level 4 14th May 2004 09:55 AM
AQL (Acceptable Quality Level) vs. PPM (Parts per Million) - Equivalences? Marc AQL - Acceptable Quality Level 16 20th June 2002 04:19 PM
The time now is 01:35 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
