27th August 1998, 08:23 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
TPM (Total Productive Maintenance) - What is TPM?
Check out this pdf file. It gives the basics. In part it is courtesy of Motorola.
http://Elsmar.com/pdf_files/ - Look for TPM.pdf - TPM Basics
27th August 1998, 02:50 PM
Thanks Marc.
13th March 1999, 10:10 AM
Karma Power: 605
In part, I'm surprised no one has commented on this. I've seen TPM and it's impressive.
1st September 1999, 06:43 PM
Registration Date: Nov 1998
Karma Power: 45 Karma: 10
I suspect you have heard so little about TPM because companies seem to stumble on it only after starting some type of lean production effort.
Not many companies implement lean manufacturing correctly, so not many run into equipment issues that can (must?) be solved with TPM techniques.
1st September 1999, 07:16 PM
Karma Power: 605
I was working with Motorola in Guadalajara. They were silmultaneously going through a TPM implementation and a QS9000 implementation. What they were doing with old equipment with TPM impressed the hell out of me. They took it to the extreme of altering equipment in ways where I sat back and thought "Why didn't the equipment manufacturer think of that???" I was, and am, impressed. But then it's base is close to my heart. Preventive maintenance and improvement. There are so many companies which run equipment to death. The sad thing is it's the old story. Wait till it dies and survive the downtime costs. It's like keeping a balance on a credit card. Every year - more interest costs.
I really thought there would be more interest in a TPM forum, but it was obviously my personal excitement.
3rd September 1999, 10:17 AM
Marc!
Any chance you can give a more specific example of what Motorola was doing with the equipment related to this topic?
Thanks in advance
joe
Joseph Lucas
3rd September 1999, 03:46 PM
Karma Power: 605
Equipment was all on a list with a 'schedule'. Each piece of equipment went thru 'phases' of evaluation and action. At one point you would walk up to a machine and post-it notes with a name and date were everywhere. Operators would make up these notes as well as engineers and such. What they did - well, there were many things. One machine had a guard on a pully system which to get to before you had to remove several bolts and such to inspect and/or change. They put a hinge and quick fasten tie-down mechanism on it and even cut a hole in the guard (solid metal) and put in a plexaglass 'window' so you could immediately see the belt condition and pully position.
They took all the post-it notes, listed them and discussed the suggestions. None were overlooked. The operators were immediately involved in all discussions and decisions. The maintenance schedule for several months were posted on the machine.
The whole thing was a great exercise in understanding the equipment.
3rd September 1999, 03:54 PM
Karma Power: 605
Did you review the pdf file?
