Elsmar Cove Quality and Medical Device Discussions
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
Starting up a new Calibration Laboratory
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
calibration (metrology) laboratories
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 20th May 2009, 03:40 PM
SGCalLab
Please Help! Starting up a new Calibration Laboratory
Hello everyone,
I just got hired on to a company and have been tasked with creating a calibration lab from the ground up. They have not had a need for a real cal lab before, but some customers and other regulations are pushing them to create one and start using it. It will need to be FDA compliant.
From what I know right now (only my third day) Iíll be calibrating lotís of temperature indicators, thermocouples (J/K), RTD, pressure gauges (air/liquid), vacuum gauges, RPM (converting Hz to RPM), compound pressure sensors, etcÖ
Iíve been tasked to buy equipment to calibrate with. Mindful, I have to keep it in reason.
Some of the equipment I was looking at are:
  • Process Calibrators (Fluke 743b or 725)
  • Temperature Calibrators (Fluke 724)
  • Pressure (Fluke 718)
  • Loop Calibrator (Fluke 707)
  • Power supply
  • RPM Calibrator
  • Field (portable) Metrology Well (for thermocouples)
These donít have to be all Fluke. I am familiar with Fluke more than some others like Omega for instance, but I donít have to stick with Fluke if others are better.
Looking for suggestions on what equipment to buy.
Thanks!!
Sponsored Links
  Post Number #2
Old 20th May 2009, 03:57 PM
Coury Ferguson's Avatar
Coury Ferguson
Re: Starting up a new Cal Lab
In Reply to Parent Post by SGCalLab View Post
Hello everyone,
From what I know right now (only my third day) I’ll be calibrating lot’s of temperature indicators, thermocouples (J/K), RTD, pressure gauges (air/liquid), vacuum gauges, RPM (converting Hz to RPM), compound pressure sensors, etc…
I’ve been tasked to buy equipment to calibrate with. Mindful, I have to keep it in reason.
  • Power supply
  • RPM Calibrator
These don’t have to be all Fluke. I am familiar with Fluke more than some others like Omega for instance, but I don’t have to stick with Fluke if others are better.
Thanks!!
Here is a Manual that I found while looking for something similar. It is the NIST's and it is a template. I didn't see any "Copyright" statement on the Manual. I have split it into two parts, because the file size exceeds the upload limit.
Maybe it may help you.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
File Type: pdf Pages from ISO17025 Manual-Pages 1-55.pdf (2.80 MB, 1619 views)
File Type: pdf Pages from ISO17025 Manual-Pages 56-110.pdf (1.85 MB, 1116 views)
Thank You to Coury Ferguson for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 20th May 2009, 04:02 PM
Jeff Frost
Re: Starting up a new Calibration Laboratory
Hello everyone,
  • Power supply
  • RPM Calibrator
Thanks!!
What is your background in calibration?
Before you purchase calibration equipment you will need to review process equipment to understand the equipment accuracy you will be calibrating and what accuracy the actual process requires.
Since you are working with process equipment that contain multiple elements such as display modules and thermal couples you will also need to determine total system accuracy which is not the adding together of the display unit accuracy and thermal couple accuracy.
Calibration equipment itself should have a system accuracy at a minimum 4:1 to a preferred 10:1 ratio to the unit under test with calibration certification reflecting actual results traceable to a national or international standard body.
When calibrating pressure gauges the actual calibration standard should have a 1/4 of 1% accuracy over the most accurate process gauge using nitrogen as a calibration media.
Last edited by Jeff Frost; 21st May 2009 at 10:22 AM. Reason: Rewrote last sentence to improve clarity
Thanks to Jeff Frost for your informative Post and/or Attachment!
  Post Number #4
Old 22nd May 2009, 09:14 AM
SGCalLab
In Reply to Parent Post by Jeff Frost View Post
I had calibration lab experience and training in the military. I'm new to this type of enviroment.
Most of what I have found out thus far, is the the tolerances on the process is between 1 - 3%.
  Post Number #5
Old 22nd May 2009, 10:00 AM
BradM's Avatar
BradM
Look at my response in your other thread. Before you buy anything...
You need to make a thorough (and accurate) inventory of the equipment. The labor you will need to do the work is going to need to be sold to management. Also, you will need to evaluate vendors, audit them, etc. Thus, you need to determine what is before you.
As far as standards, look at buying the standards that are critical for your process. Or more simply put, get the most bang for your buck.
Starting off, you may want to qualify some vendors, and have them calibrate the equipment for you. It's going to take you some time to get things going. So assure the equipment is calibrated and tagged properly first.
Then, you can work on setting up your calibration system.
  Post Number #6
Old 22nd May 2009, 05:57 PM
Hershal's Avatar
Hershal
Step number one is to join NCSLI www.ncsli.org and get the Recommended Practices (RPs). There is a RP specifically for how to set up a cal lab.
Make sure you control both temp and RH.
Also, get a copy of ANS/ISO/IEC 17025:2005 whether you intend to get accreditation or not as it will help develop a good management structure to maintain control and provide services. If you intend to seek accreditation don't just pick any, shop around a bit first.
If your parent organization has Government contracts, join GIDEP www.gidep.org to have access to military calibration porocedures and avoid validation issues.
Get training in the specific types of calibration you will be doing and make sure it is documented. There are NIST sessions and similar at NCSLI in San Antonio end of July.
Hope this helps.
Thank You to Hershal for your informative Post and/or Attachment!
  Post Number #7
Old 26th May 2009, 02:34 PM
SGCalLab
Hershal, what's the difference between NCSLI and ANSI? (as for becoming members of).
  Post Number #8
Old 27th May 2009, 10:45 PM
Hershal's Avatar
Hershal
NCSLI is a membership organization of Metrology professionals.....for calibration, this is the better organization.....
Thanks to Hershal for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Starting ISO 17025 Accreditation from scratch - Petroleum Laboratory mtak33 ISO 17025 related Discussions 3 23rd February 2013 01:38 PM
Starting a new Calibration and Repair Laboratory kd818 General Measurement Device and Calibration Topics 15 31st July 2011 01:18 PM
Starting an ISO 17025 Accredited Laboratory kat.k. ISO 17025 related Discussions 15 10th February 2011 01:21 AM
Starting a Calibration Laboratory in State College, PA fortyfour73 Career and Occupation Discussions 4 24th February 2007 05:41 PM
Internal Laboratory - Defining the Laboratory Scope - Inspection, Test, Calibration DJN Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18 7th March 2005 12:20 PM
The time now is 11:12 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
