The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
Out-of-Specification (OOS) / testing deviation / failure SOP required?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Reply
  Post Number #1
Old 26th May 2009, 06:12 AM
jane lai
Question Out-of-Specification (OOS) / testing deviation / failure SOP required?
Hi! My lab is going to apply ISO 17025 testing lab. I'm confuse about Out-of-Specification(OOS)/testing deviation/failure SOP.
Do ISO 17025 require any of these SOP? Or is it all of these cases can be classify under NONCONFORMANCE (NC) and take an CORRECTIVE ACTION (CA) to solve it?
Thanks!
Sponsored Links
  Post Number #2
Old 26th May 2009, 10:00 AM
BradM's Avatar
BradM
Re: Out-of-Specification(OOS)/testing deviation/failure SOP
Hello Jane!
Your out of specification procedure should contain appropriate action for when your instrument exceeds the specified tolerance.
It should specify how the out of tolerance is documented, who is alerted, and how investigation (if any) is to be conducted. Hopefully you have an electronic system, where you can easily verify which instruments have been calibrated by that equipment (if any- reverse traceability).
Essentially you want an action plan when the instrument fails. Hopefully while writing your out of specification procedure you conduct adequate risk analysis, where the actions equal the level of risk.
I'm not sure if I am addressing your question. Please feel free to post and let me know if that covers your issue or not.
Sponsored Links
  Post Number #3
Old 26th May 2009, 09:11 PM
jane lai
Please Help! Re: Out-of-Specification(OOS)/testing deviation/failure SOP
Dear Brad,
Thank you for your kindly recommendations. For equipment/instrument failure, I do have a written SOP for equipment failure as discussed by you.
My concern is the testing being carried out. Maybe I should give an example here. We got two departments (TESTING SERVICE TEAM and QA/QC TEAM) are responsible to generated a testing report. Testing results from both departments must tally/conform before a testing report can be generated. Let say, TESTING SEVICE TEAM detected the sample result as positive but QA/QC TEAM detected as negative. Should both departments solve the issue by entries of corrective action procedure? Or a SOP (OOS/testing deviation) is needed to solve the deviation between these two different results?
Thanks!
  Post Number #4
Old 27th May 2009, 09:47 AM
BradM's Avatar
BradM
In Reply to Parent Post by jane lai View Post
Dear Brad,
Thanks!
Jane, in my opinion, there is a more fundamental issue of determining why one unit is passing the test, and the other unit is rejecting. Have you conducted uncertainty analysis? Is it that the acceptance criteria may be too tight, given the uncertainty in both methods?
Let's keep it simple and say that you are performing some test, and the results must be within 6% of the target. If each test method has 3% of error, then it could be the flip of a coin whether it will pass both tests or not.
Have you addressed this, or am I still missing the issue?
  Post Number #5
Old 30th May 2009, 02:44 AM
Hershal's Avatar
Hershal
Re: Out-of-Specification (OOS) / testing deviation / failure SOP required?
Jane, there is more than one Clause that may be effective here.
In terms of documenting the steps taken to correct any issue encountered, then use the Corrective Action system that is documented under Clause 4.11
However, given what you describe this may actually be a case of non-conforming work which is described under Clause 4.9
The documentation of steps taken is the same, but Clause 4.9 has some very specific requirements, such as defining who can stop work and specifically stating who has responsibility and authority to resume work (state the authority by position, not by name of person).
You might also ask your accrediting body (AB) about their policy regarding the procedures.
Hope this helps.
  Post Number #6
Old 30th May 2009, 03:02 AM
Ajit Basrur's Avatar
Ajit Basrur
Dear Brad,
Thanks!
Hi Jane,
I am not sure if this will help you - referencing a Guidance document on OOS from Food drug and Administration (FDA) that is being used for Pharmaceuticals - http://www.fda.gov/downloads/Drugs/G.../UCM070287.pdf
  Post Number #7
Old 10th June 2009, 12:41 AM
jane lai
Thumbs up Re: Out-of-Specification (OOS) / testing deviation / failure SOP required?
Thanks for all of your comments & recommendation. This forum really great!
I think Hershal’s recommendation is works to me. I may prepare a OOS SOP to describe the procedure & scope. Any OOS/deviation should consider as NC and solve through the Corrective Action.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Corrective Action - Product failure during testing qahardlife Nonconformance and Corrective Action 7 9th April 2014 10:02 AM
New product testing for CE marking - Required FCC testing Robbin CE Marking (Conformité Européene) / CB Scheme 4 30th April 2013 09:39 AM
Process Control/Standard Deviation Question on a One Sided Specification jkittle Capability, Accuracy and Stability - Processes, Machines, etc. 6 15th April 2010 12:14 PM
The difference between Deviation and Failure - Creating an SOP to handle them rika_ndry Food Safety - ISO 22000, HACCP (21 CFR 120) 24 24th March 2009 04:57 PM
Potential Failure Mode - Machine Stroke not in specification wanamir FMEA and Control Plans 7 22nd May 2006 10:20 AM
The time now is 02:46 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
