Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 30th August 2001, 01:24 PM
inspector1
Unregistered Guest
Posts: n/a
Please Help! As9100 4.10 - Identification of production inspection instruments
I am having trouble interpretating AS9100 element 4.10.1 "identification of production inspection instruments." I
am not quite clear on the intent of this statement.
Sponsored Links
Old 30th August 2001, 02:22 PM
BadgerMan's Avatar
BadgerMan BadgerMan is offline
Moderator
Registration Date: Feb 2001
Thanks Given to Others: 36
Karma Power: 64
BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.
Default
I believe that it is requiring you to list or describe (description or actual ID number?) the gage to be used for the inspection operation within the specific inspection work instruction. I have always prefered to have the actual ID number listed so there is never a question. However, my hunch is that only a good clear description is required. Any other opinions?
Sponsored Links
Old 30th August 2001, 04:38 PM
energy
Unregistered Guest
Posts: n/a
Default Two cents worth
What I would add to Badgerman's message, because I think he has already said it in his own words, you have to list critical dimensions that are flight safety, customer or your company driven. Any 1st piece or in-process Inspection requirements that would include any special gaging used to verify the same. There may have been previous non-conformances. The inspection checklist would list those things as part of the final inspection record for that particular part. The next time you make that part, the production/inspection frequencies/instruments are already defined. That should satisfy production inspection instruments requirements.
energy
Old 31st August 2001, 08:18 AM
inspector1
Unregistered Guest
Posts: n/a
Default 4.10.1
Is it necessary to have inspection sheets identifying inspection equipment for each product? We have over 5000 different part numbers and manufacture to customer prints as well. Would a procedure describing types of gaging for similarity of parts be in
compliance?
Old 31st August 2001, 02:03 PM
energy
Unregistered Guest
Posts: n/a
Default Yes, if applicable
Inspector 1,
Although I’m not the expert, I worked ( 18 months) at a sheet metal shop where they produced brackets for aircraft. The major Customers are Pratt & Whitney, US and Canada, Hamilton Sundstrand and several other Airline industry suppliers. They had source inspectors from these companies sampling product prior to shipping. The two main “documents” they concerned themselves with were the Operations Traveler and the Inspection records. The Operations traveler specified at each step of the operation, the process, the dimension sought, any special gaging, (no, they didn’t say to use a calibrated micrometer-they are trained operators), the inspection frequency (after 1st piece Inspection), and a place to put your little initials. The Inspection record listed the characteristics to inspect, any special gages to use, pass or fail boxes and the place for the Inspector to sign off. Yes, they made thousands of different parts and they have operation sheets for every part they ever made and an Inspection record for each. Once they are put into the database, whatever you use, it’s done. When you get the job, just print them and go. Of course, the closer to the engine you get, the more Customer involvement in determining critical characteristics. Many times they supply the tooling and gages for you to use. Your original post was referring to calling out instrumentation to inspect with. These operations would specify, Optical Comparator, Super Mike, CMM, etc. They did not address how to verify measurements for every dimension. This was considered a training issue. Special gaging is the what you worry about and specifying other instruments capable of meeting the tolerances that can not be measured by conventional equipment. I will add, there was no such thing as too much paperwork with these Customer QAR’s. If you are doing the same type of work, AS 9000 is the Standard, you probably already have many of the things I mentioned. Just look at each job as they come in, add your special gaging instructions and build your database. I wouldn’t worry about the 5000 parts you already shipped successfully, start now. You can do it. Sure you can.
energy
Old 6th August 2005, 09:09 AM
Hoeyster's Avatar
Hoeyster Hoeyster is offline
Involved - Posts
Registration Date: Jul 2005
Karma Power: 18
Hoeyster has less than 100 Karma points so far.
Default Hoeyster QM
OK let me get this straight, the inspection checklist only needs to contain the measurement device for special gaging required per AS9100? I am a new Quality Manager and I am headed down the path of identifying gaging in my facility by serializing them. I will then put that gaging on my IMS (inspection method sheet) being identified by the serial number. But, I was going to do it for every characteristic, critical or not. Am I going way over and above what I really need to do? Am I creating more work for myself than I need to?
Old 8th August 2005, 02:00 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is online now
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Default
It sounds like you are overworking it to me.
To satisfy the standard, I would list the gage serial numbers for critical characteristics as required only and, I hope I understand you right, at the point of inspection. I would not define these gages in a work order, procedure etc. by serial number unless there is never going to be a substitution without revising the document and/or you are being extremely careful to ensure only that exact gage will be used.
Stealth quality versus no quality
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
AS9100 7.5.3 Identification and Traceability - Difference between actual and agreed Buckyb AS9100 Aerospace Standard and Requirements 2 5th November 2009 10:12 AM
7.6.3 Internal or External Laboratory? Measuring instruments used in production Peters ISO/TS 16949 - International Automotive Quality Systems Standard 9 4th September 2009 03:52 PM
Deciding if Calibration is needed for Production Instruments Marcus CLF ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 3rd August 2007 09:42 AM
Identification and Traceablity - Audit Query - AS9100 REV B - Clause 7.5.3 Sohail AS9100 Aerospace Standard and Requirements 3 15th January 2007 10:28 AM
Inspection and Detection - Kit to production - Need an inspection routine Ross_Henderson Inspection and Test, Sampling and Related Topics 8 29th March 2004 07:57 PM
The time now is 08:02 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
