1st June 2006, 06:52 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Searches in Posts - Putting 'Search' links within posts
If you do a search and post the link that comes up in your address bar, it will not work for others.
Remember, search terms must be at least 3 letters.
The 'correct' way:
Search for terms in thread titles ONLY:
Single search term:
Code:
http://Elsmar.com/Forums/search.php?do=process&titleonly=1&query=term1
or multiple search terms:
Code:
http://Elsmar.com/Forums/search.php?do=process&titleonly=1&query=term1+term2+...termx
To search all posts in all threads (not just the titles):
Code:
http://Elsmar.com/Forums/search.php?do=process&query=term1
or
Code:
http://Elsmar.com/Forums/search.php?do=process&query=term1+term2+...termx
1st June 2006, 02:40 PM
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Marc, what do you add to limit the search to a particular forum or to two forums?
Al
1st June 2006, 02:50 PM
Karma Power: 605
I don't know of any way to search 1 forum only. I'll look into it though. It's running a script so I'm relatively sure there is a query modifier, just like there is for searching titles only (&titleonly=1).
1st June 2006, 03:07 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Originally Posted by Marc
If you do a search and post the link that comes up in your address bar, it will not work for others.....
OK. I read this once without coffee, then I took a cup and read it again. Then I proceeded to do an advanced search by clicking on Advanced search in the navigation bar ("whistle blower" for author Wes Bucey) The first item came up with the shortcut
http://elsmar.com/Forums/showthread....wer#post149322
clicking on that brought me to
http://elsmar.com/Forums/showpost.ph...22&postcount=6
If someone else clicks on either of the above links, what happens?
- How can I replicate the effect for other Covers?
Do I have to sign in as someone else?
- Can non-registered viewers do searches?
- Is anyone else using this system? How does it square with the directions in Marc's posts?
1st June 2006, 03:21 PM
Karma Power: 605
I posted this because Randy posted a search link in a post, which you can do and which I do a lot. But when you do a search you get a link in the navigation box of your browser which looks something like this:
Code:
http://elsmar.com/Forums/search.php?searchid=448582
showing in the browser navigation box. Note the 'searchid'. This is only good for that user for that search (it is caching the results for a few minutes). Any other user clicking the link will get an error page. To see what I mean, click the following link: http://elsmar.com/Forums/search.php?searchid=448582
Let's say you're posting and want to make it easy for someone to find information on quality manuals. You can form a search query as a link within the post:
Code:
<url=http://Elsmar.com/Forums/search.php?do=process&titleonly=1&query=quality+manual>Quality Manuals</url>
NOTE: In this example I used < and > instead of [ and ] because even in the 'code' box' the string will appear as a clickable link like this: Quality Manuals instead of your being able to see the code - In this example I am searching for the two words 'quality' and 'manual' and I'm limiting the search to thread titles only.
"Can non-registered viewers do searches?" Yes - They have full search capabilities.
1st June 2006, 03:36 PM
Quality Manager
Karma Power: 397
Point I was making is the results of my searches using the advanced search do NOT have "search ID" What happens when YOU click on the two separate links posted?
1st June 2006, 03:45 PM
Karma Power: 605
The key word is the RESULTS of your search. It is correct that the results page gives you a list of clickable links to threads and/or posts. What you put in your post above were from the search results, not from the url in the address bar that you see after you did the search.
I usually just embed the search query so the person clicking the link can see all the threads that they would see if the person did the search manually.
How is this different? You are choosing one or a few threads to link to that are in the Results of the search you did. If you embed the search query they will see all the relevant threads just as if they had done the search manually. Sometimes one way makes more sense than another. It's up to any one of us which makes more sense in the context of the post / thread.
I'm not asking you folks to do this. I just wanted to show you how. Now and again I see someone post a link something like
Code:
which, as I pointed out, will only give an error page.
1st June 2006, 07:13 PM
Quality Manager
Karma Power: 397
"I see!" said the blind man.
