Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Calibration Frequency (Interval)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th May 2009, 12:15 AM
Eloy Gomez Eloy Gomez is offline
Involved in Discussions
Registration Date: Apr 2009
Thanks Given to Others: 234
Karma Power: 4
Eloy Gomez has less than 100 Karma points so far.
Please Help! Possible escapes due to caliper out of calibration
Hello: during an external audit of the calibration system it was discovered that a caliper that was sent our for calibration returned not able to be calibrated. A C/A was issued because we were not able to determine on which units was this pair of calipers used and we could not determine if we sent non-conforming parts to our customers.
We would like to start monitoring this but we are not sure how or what controls should we have in place? What would be an appropiate root cause corrective action? and long term solution?
Sponsored Links
Old 29th May 2009, 12:36 AM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Default Re: Possible escapes due to caliper out of calibration
Hello Eloy!
Now when you sent the calipers out for calibration, were they able to get any as-found data? What happened to the calipers?
To me the question is whether it was possible that people were using the calipers with excessive error present.
As to the root cause, I would say it is dependent on the nature of damage to the instrument. Also, how has the calibration data looked each time it was calibrated? Was it close to being out? If so, you probably want to get shorter intervals.
Also, you might consider purchasing (and have calibrated) a few gauge blocks to check them out periodically to see if they are drifting.
Have you analyzed the historical data? That should give you an indicator as to how the instrument has been performing.
Hope something here is of help.
Brad
My idea of housework is to sweep the room with a glance.
Thank You to BradM for your informative Post and/or Attachment!
Sponsored Links
Old 29th May 2009, 01:01 AM
harry harry is offline
Registration Date: Sep 2005
Thanks Given to Others: 572
Karma Power: 231
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.harry is appreciated, and has over 1700 Karma points.
Brad had covered most of the areas. A recent and related thread worth reading is: What to do with Prior Analysis after instrument was Out Of Calibration (OOC)?
Thanks to harry for your informative Post and/or Attachment!
Old 29th May 2009, 02:37 AM
howste's Avatar
howste howste is online now
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
It's not clear to me exactly which of several problems you are trying to prevent from recurring. I think you need to start by defining which problem(s) you are trying to solve.
Problems I see:
- A set of calipers went out of tolerance
- The out-of-tolerance calipers were not detected before calibration
- Although the calibration source found that the calipers were out of tolerance, the external auditor identified the problem before internal personnel did
- It's unknown how far out of tolerance the calipers were
- Which product was checked with the calipers and the risk of nonconforming product is unknown
Each one of these problems could have separate root causes and actions
Thank You to howste for your informative Post and/or Attachment!
Old 29th May 2009, 03:01 AM
arios's Avatar
arios arios is offline
Your Mexican Amigo
Registration Date: Aug 2004
Thanks Given to Others: 210
Karma Power: 39
arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.arios is appreciated, and has over 700 Karma points.
Hi Eloy
You have received great feedback from the other folks.
If I can help a bit I would just add that a risk assessment would be beneficial. I mean, think on the worst case scenario considering the product that would have the greatest impact based on its tolerances and determine how severe the impact could had been. Also consider if there were reduntant tests either upstream or downstream in the process that could serve as a reference for your rationale.
I hope this situation had not a severe impact. In most of the cases I have seen there is not and I hope this is the case
Greetings paisano!
Alberto
Thanks to arios for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type Lundberg ISO 17025 - Calibration, Measurement Gages and Test Laboratories 53 29th September 2008 03:39 PM
Late calibration (Calibration Past Due Date) - What do I do now? dbulak ISO 17025 - Calibration, Measurement Gages and Test Laboratories 32 25th May 2007 10:18 AM
Caliper Calibration Instruction - Example Caliper Calibration Procedure Wanted janah214 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 11th July 2005 05:57 AM
Digital Caliper Calibration vs. Verification - Full Scale vs. Used Range JSmith ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 7th January 2005 03:06 PM
Electric 0-8" Caliper Calibration Tolerance Question. Bob_M ISO 17025 - Calibration, Measurement Gages and Test Laboratories 9 11th August 2003 01:39 AM
The time now is 01:43 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
