Go Back   The Elsmar Cove Forum > Aerospace and Aviation Requirements > Federal Aviation Administration (FAA)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th June 2009, 11:02 AM
big rob big rob is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jun 2007
Thanks Given to Others: 2
Karma Power: 10
big rob has less than 100 Karma points so far.
Angry Control of Non-certificated maintenance contractors
We are a part 145 repair station, and have been found to have discrepancies in our QCM on Contracted Maintenance,Non Certificated repair stations. How do I remain Directly in charge of the work being performed at the Non certificated shop?
Please help: (
Sponsored Links
Old 25th June 2009, 11:19 AM
BadgerMan's Avatar
BadgerMan BadgerMan is offline
Moderator
Registration Date: Feb 2001
Thanks Given to Others: 36
Karma Power: 64
BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.BadgerMan is appreciated, and has over 900 Karma points.
Default Re: Contracted Maintenance
Do you specify quality system requirements for your non-certificated contractors?
Do you specify that your non-certificated contractors maintain a D&A program?
Do you then test and/or inspect the product repaired by non-certificated contractors prior to approving it for return to service?
Quando Omni Flunkus Moritati
Sponsored Links
Old 25th June 2009, 11:30 AM
Karma Power: 10
Please Help! Re: Contracted Maintenance
1) Yes, we specify Quality System requirements
2) No, we do not specify they maintain a D/A program.
3) Yes, we test and inspect.
Old 25th June 2009, 11:34 AM
BradM's Avatar
BradM BradM is offline
Registration Date: Sep 2006
Thanks Given to Others: 814
Karma Power: 274
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
Please help: (
Hello big rob! Thank you for dropping by the Cove! We're sure glad to have you.
First, I am not that proficient in aviation, so discount it as such. I have worked in the environment before though. I have seen (typically medium size operations) that perform a number of different services on aerospace parts. Usually, they have a portion of their services certified due to it's nature, but the other portions are not. Does that sound like your situation?
Now to your question... I'm not sure I understand. if you are the supervisor; you are the supervisor. Why do you feel a need to distance yourself from the non-certified work? I would think you would be more concerned with creating separation in other ways than supervision.
Not sure my question makes sense. Let me know what you're thinking.
Brad
My idea of housework is to sweep the room with a glance.
Old 25th June 2009, 11:35 AM
BradM's Avatar
Karma Power: 274
Sorry badgerman, I was putting together my post while you were helping out.
Add edit: I revised the title a bit, so that it might be a little more clear. Let me or any moderator know if it is not suitable.
Brad
Last edited by BradM; 25th June 2009 at 11:38 AM. Reason: Added line about changing title
Old 25th June 2009, 11:40 AM
BadgerMan's Avatar
Moderator
Karma Power: 64
We do specify that non-certificated contractors maintain a D&A program.
The main difference I see is that we test the product and approve for return to service with non certificated sources whereas with certificated contractors, they can approve for return to service.
Was this an audit nonconformance? Can you ask the auditor for clarification?
Thanks to BadgerMan for your informative Post and/or Attachment!
Old 25th June 2009, 11:53 AM
BadgerMan's Avatar
Moderator
Karma Power: 64
I changed it again to add further clarification.
The question deals with (sub) contracted maintenance not "maintenance"......…LOL!
When an FAA approved repair station sub-contracts/out sources repair of a product returned from the field because they don’t have the capability, they can use another approved repair station or a non-approved (certificated) source. The two options require different levels of control from a QMS perspective.
Clear as mud, eh?
Thank You to BadgerMan for your informative Post and/or Attachment!
Old 25th June 2009, 12:00 PM
Karma Power: 10
Thumbs up Re: Control of Non-certificated maintenance contractors
Yes, this was an audit non conformance. The auditor is a fast talker and confuses me sometimes. He is helpful but seams to be one that likes verbage to be specific. We try to use certificated stations as much as possible but sometimes it just can't be done.
Thanks for your help.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Medical Gases Installation - Can be classified as MD and ISO 13485 certificated? instorer ISO 13485 - Medical Devices - Quality Management Systems 5 23rd July 2008 12:16 PM
14001 Suppliers and Contractors - What control do you have? mjohnson ISO 14001 and Environmental Related Standards 7 15th February 2007 05:13 AM
Competence (4.4.2) Records - Contractors who carry out skilled maintenance tasks Spanner ISO 14001 and Environmental Related Standards 8 2nd February 2005 09:17 AM
Control of Suppliers & Contractors Cheryl Supplier Quality Assurance and other Supplier Issues 4 19th April 2003 06:30 AM
Preventive Maintenance & Machine Manual Control Marc QS-9000 - American Automotive Manufacturers Standard 0 27th June 1999 10:47 PM
The time now is 04:16 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
