Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Misc. Quality Assurance and Business Systems Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th September 2001, 05:25 PM
Anton Ovsianko
Unregistered Guest
Posts: n/a
Please Help! Control and registration of weight measurement results data
Hello, all,
I have been guessing where to post this post... Chose this forum...
It is a practical matter. A medium-sized company manufactures hydro isolation material. Main production process is mixing liquid and dry substances. Critical factors determining end product technical quality during the production itself are:
- duration of the process
- temperature of mixing
- exact proportion of components (measured by weight)
The first two parameters are comparatively easy measured. The results of measurement can be also easily registered where necessary (for example with the use of simple devices, alarm systems etc.).
It is a little bit harder to control the third factor, as it is done manually with the use of electronic scales.
How would you suggest, that control and registration of measurement results should be organized?
Should it be a kind of a journal for self-control or what?
Thank you in advance for you help!
Anton
Sponsored Links
Old 7th September 2001, 07:19 PM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default
Anton - We do material mixing and also record the weights. We maintain lot traceability of the mix components, record the weight of each component and the final mix weight. The resulting mix is given an internal lot number specific to that mix. All this is kept in a "Mix Log". Also included are: date, mixer, and MSDS label codeing.
Dave
Sponsored Links
Old 8th September 2001, 07:46 AM
Anton Ovsianko
Unregistered Guest
Posts: n/a
Default
Thank you, Dave!
It is more or less clear now what you are measuring and recording. How is it organized? Is a Mixer doing it him-self?
In the company I am speaking about they weigh things manually on scales and then put the mixture into the mixing machine with the use of a dosing device. Should the responsible worker write down the results of measurement in a journal himself?
There is a risk that a worker too sure of his skills and attentiveness will write everything down beforehand, as it would improve his productivity. However it is rather a question of motivation, not of the technology...
Thank you once again!!!
Any more comments from someone?
YS Anton
Old 8th September 2001, 09:01 AM
D.Scott's Avatar
Karma Power: 149
Default
Our mixing is done in a lab setting by trained mixers. Yes, they record all their own info. The integrity of the mix rests with the integrity of the mixer.
As in all our lab procedures, the employees are trained and evaluated for competence.
The log is just as described - we use a loose leaf binder kept in the lab. Each of our mixes (final resulting product) has its own section in the binder.
As long as you don't have an employee or security problem, I suggest you keep it as simple as possible.
Dave
Old 8th September 2001, 01:32 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
I Say...
If this happens, then the employee should be subject to reprimand (at a very minimum) or dismissal. There is a recent thread here that dealt with this same subject - a manager was involved, however (try a Forums search for 'fraud' and you'll find it). S/he was completing forms prior to the actions. This is nothing less than (in my opinion) Fraud. From a legal stand point, most companies - when you 'sign on' - have some type of clause whereby fraud is grounds for immediate dismissal.
I have worked with some chemical companies in implementation and they handled this in the same way D.Scott describes. If you have a good group of folks, falsifying data (which is what pre-entering data is - and again I use the word Fraud) should not be an issue.
I have seen auditors ask how you know employees are not pre-entering data (or entering the correct data) - either because of the reason you cite (lack of motivation) or because of employee sabotage. Be ready with an answer, but don't go over board.
I was once, probably 20 years ago, working for a company that closed off sections of Interstate 75 and did vibration analysis on the concrete sections to see if the dirt and crushed rock was being erroded from under sections of the concrete. It was a start at 11 PM and finish at 6 AM job. The data was so similar each night I started a 'secret' watch. I found employees were writing in 'normal' values and not even taking the measurements. When brought to task, they explained that the equipment was 'flakey' and they got tired of complaints about how slow things were going. These fellas were given problematic equipment, were not properly trained to begin with and then, to top it off, was badgered by management to 'get the job done faster'. I add this only to point out sometimes management pushes employees to a point where they have little or no choice.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
A little weight on my mind for New Year's - Measurement Uncertainty ScottBP Measurement Uncertainty (MU) 3 12th January 2009 01:47 PM
Fish Oil Capsule Weight MSA (Measurement Systems Analysis) sidit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9 28th August 2008 06:04 AM
Weight Measurement Uncertainty - F1 10 Kg weight comparison with 10 Kg E2 weight ahmadfy2003 Measurement Uncertainty (MU) 4 5th January 2007 03:30 PM
Weight Calculations - What is 100-600 u/ft2? What are these units of measurement? dbulak Misc. Quality Assurance and Business Systems Related Topics 12 16th December 2004 04:43 PM
Data Measurement - Where can I purchase a data recording system? murban Records and Data - Quality, Legal and Other Evidence 2 12th February 2002 07:49 PM
The time now is 08:09 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
