The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Wooden Line
p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
crossed gage r&r, gage r&r (repeatability and reproducibility), p-value, anova (analysis of variance)
Reply
  Post Number #1
Old 29th June 2009, 11:29 AM
straetfeild
Please Help! p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies
Good day all,
I've had discussions with colleagues of mine here at work debating whether or not an acceptable p-value is required to use a given set of data for a GRR study (10*3*3). I can't find where MSA or any other documented parameters require me to do so. The experience of one of my peers is that his customer (a Big-3 automotive manufacturing company) required this in person, so we should have this as our standard accross the board.
Mathematically speaking, does an unacceptable p-value (p>0.05) automatically render the data unacceptable for an ANOVA-crossed GRR, and if so, is the reason because it is an ANOVA-based study?
I appreciate any advise and/or thoughts you may have, and I apologize in advance for any breach in established posting protocol.
(Edit: I tried to copy-paste the data, but was unsuccessful.)
Thanks!
Sponsored Links
  Post Number #2
Old 29th June 2009, 11:18 PM
Miner's Avatar
Re: p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies
I love this question. This is the first NEW MSA question that I have seen in a long time.
To start, the current MSA methodology as defined by AIAG, endorsed by the automotive industry and codified by the statistical software companies totally ignore the p-values with one exception.
That exception is for the Operator x Part interaction. In Minitab, if the Op x Part interaction p-value is greater than 0.25 (default value), the interaction is then pooled with the ANOVA error term thus becoming part of Repeatability. If it is less than 0.25, it is shown separately as a sub-item under Reproducibility. Why 0.25? Minitab says to stay consistent with AIAG. AIAG wanted to be extremely conservative about pooling the interaction in error.
Technically, if the Reproducibility p-value is greater than alpha (usually 0.05), it also should be pooled into the error term becoming part of Repeatability. It is only when it is less than alpha that Reproducibility can be distinguished from Repeatability. However, AIAG is silent on this matter and the canned MSA routines in software do not allow it. To do it yourself, you would have to run the standard ANOVA routines and manually generate the graphs.
The p-value for Parts also provides information. If the p-value of Parts is greater than alpha, the part variation is indistinguishable from Repeatability variation. If the p-value is less than alpha, the gage can distinguish at least one part as different from the rest. Not definitive that the gage is good (p < alpha), but conclusive that it is not good (p > alpha).
Thank you for this question.
Thank You to Miner for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 5th May 2013, 03:22 AM
Piotr Stoklosa
In Reply to Parent Post by Miner View Post
Does it mean that 0.25 is another rule of thumb? Or maybe it has any statistical background? Sometimes I suspect that it has something to do with alpha level: because the interaction is part * oper, so it's like squaring 0.05 * 0.05, but it gives only 0.0025, not 0.25.
  Post Number #4
Old 5th May 2013, 01:49 PM
Miner's Avatar
Look! Re: p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies
It does have something to do with alpha. AIAG has arbitrarily established an alpha = 0.25. This means that there is a 25% chance that if the null hypothesis (there is no interaction) is correct you will mistakenly reject that hypothesis in favor of the alternate hypothesis (there is an interaction).
I strongly disagree with this approach. The alpha risk for the interaction should be the same as for the operators.
Thanks to Miner for your informative Post and/or Attachment!
  Post Number #5
Old 21st October 2014, 02:04 PM
Piotr Stoklosa
Good news for everyone. In Minitab 17 they lowered default "alpha to remove interaction" to 0,05 which is now explicable with CI :-).
To Miner: In your previous message you say that AIAG requires 0,25 (I can't find a source of this information, whould you be so kind to give me the reference?). Does it mean that AIAG changed its mind and accepted recognized statistical approach?
Thank you for comments.
  Post Number #6
Old 21st October 2014, 05:22 PM
Miner's Avatar
I took a quick look through the MSA manual versions 3 & 4 and could not find anything either. I cannot remember whether this was in an earlier version and was dropped, but it appears to be a non-issue now.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Ingo1966 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 4th October 2011 07:11 AM
MSA when neither Nested nor Crossed Gage R&R is Applicable 2wrongsmake1right Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 27th July 2011 01:25 PM
What is a Nested GR&R and Crossed GR&R (Gage R&R) Calibrator24 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 26th October 2010 06:10 AM
ANOVA Method for MSA studies JeffOng Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 18th August 2008 06:58 AM
When to use a Nested Gage R&R vs. a Crossed Gage R&R Bookworm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 30th December 2005 04:30 AM
The time now is 09:41 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
